Results 1 to 12 of 12
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Question How to clean dirt/rust contaminant from stainless steel exhaust pipes?
    Is there a product that works?
    I have not found any discussion about this as most people are looking to clean and polish their exhaust tips. I would like to remove rust/dirt contaminants from the actual pipes under the car and restore the SS pipe look or get close to it. Is that even possible?
    I have found the Borla Exhaust Cleaner and Eagle One Nevr-Dull, but I'm not sure those would work.
    Is it OK to use one of those iron decontamination washes? Will that remove rust and not damage the SS under it?
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Some good Ole elbow grease with 0000 steel wool and follow up with a polish product from pinnacle or p21s. I got a small tube of Simi chrome that stuff works real good.but any good polish after the steel wool should do the trick.i have even done 3000 grit but that exhaust was really bad.
    May 13 2016
    atl
    I like to use apc and iron x with a 0000 steel wool pad
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Flitz polish. A large tube will last a long time.
    Jan 13 2016
    I've had luck with both never dull and buffing compound to clear off exhaust particles and tiny rust spots
    Aug 13 2015
    NS
    Thanks for the tips.
    My plan is to try some oven cleaner for the rough stuff and then try one of the SS cleaners to buff it clean.
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Bro when you get them nice and clean how you want them to look do yourself a favor and seal them with optimum gloss coat.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Veteran Member Three Rings Diamond Dog's Avatar
    Feb 02 2014
    My Chicks Camry
    Orange County, CA
    Use bar keepers friend. You buy it at the grocery store for around 2 bucks. Works awesome and does not scratch
    Sent from my iPad using Audizine mobile app
    Jul 14 2010
    SF,CA
    P21S polishing soap & MF towel on my AWE tips
    '11 S5
    '08 A4QT3.2
    Active Member Two Rings ShanesArt's Avatar
    May 15 2008
    Colorado
    Not sure if it will remove rust but I use Meguiar's All Metal Polish. Rub it in with a sponge applicator then wipe clean with a microfiber towel.
    B8 S4 DSG | BLACK | B/O | SPORTS DIFF | STASIS PACKAGE
    PREVIOUS:
    B6 A4 6MT | USP
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    a good metal polish and steel wool #0000 should do the trick like many of said here and showed.
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    Do the same suggestions above apply to stock exhaust tips? Mine have been neglected by the previous owner
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
