Results 1 to 30 of 30
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Running E85 all stock
    What are the pros/cons of running E85 in an otherwise stock (except ECS intake) B8.5 S4? Its hot here and Im looking to take my car to the track before stage 2 to get some base times. TIA.
    Nov 02 2015
    Orlando, FL
    Cons, your car will run like crap since you need to be able to deliver 30% more fuel. You wont be able to run straight E85 effectively without upgrading your fuel pump / injectors, etc
    I'm tuned and have mixed in upwards of 4 gallons of E85 into a tank of 93 octane and have had pretty good success there, but have never run an entire tank of E85.
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Unless your motor is tuned and e85 compliant, it's worthless for you to run e85.
    Jul 04 2008
    York, PA
    Quote Originally Posted by chrisucf99 View Post
    Im not looking to run an entire tank of it, just a mixture with 93. Tunes dont upgrade fuel pumps or injectors so why would I need to?
    Apr 04 2012
    MSP
    If you are going to the track to run baselines why would you want to burn a fuel which your car is absolutely not designed to burn? Just run 93.
    Sent from my SM-G925P using Tapatalk
    Jul 04 2008
    York, PA
    Quote Originally Posted by zcspec View Post
    So running some E85 in with 93 octane won't just raise the octane?
    Senior Member Three Rings migo1980's Avatar
    Sep 05 2007
    Raleigh, NC
    My friend runs 4-5 gallons of e85 and the rest 93 and has seen some good improvements.
    Jun 12 2015
    CA
    EPL's E85 Stage 1 tune utilizes the OEM HPFP. Anything past that (Stage 2, dual pulley, etc) requires an upgraded HPFP. However he still can't run a full tank of E85 because he has a stock tune.
    Jul 04 2008
    York, PA
    So this is why I asked the question hoping for an actual answer. Some guys have said my car will run like crap because its not "tuned" for it and another guy says his friend has seen good improvements...? Any knowledgeable please chime in.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I am stock, other than an intake like you.
    I have been running a mix of E85 and 91 for a year now and have had no codes or issues. I have on the other hand had lost performance during the summer returned. In the winter I felt little to no different between straight 91 and my mix. During the summer is a totally different story though, I absolutely feel the performance come back.
    I fill up at the same point every time. The last white line on the fuel gauge. I put in 9 gal of 91 top tier fuel and then top it off with E85 which is usually 3 to 3.5 gal. After the first take this gets me to an octane rating of just over 94. 93 octane fuel is not available at the pump so this is a great alternative. I am getting tuned this Friday and plan on doing the same thing but running the 93 octane fuel map.
    As a side note by buddy has a Supercharged V8 Jag and he did the same thing and instantly noticed the improvement as well. He now runs a mix to get him to 93-94 octane every time.
    Hope my experience helps you.
    PS I have run as much as 4 gal of E85, went beyond the white line and my guess was off. and still had no issues.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by 4Rings3Liters View Post
    He was referring to pure E85 I believe.
    Mixing in 4-5 gallons of E85 with an otherwise full tank of 93 will indeed give you a performance increase by allowing you to run more timing advance before knock occurs.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    up to 5 or 6 gallons of E85 in your tank which is about 16 gallons and you will be fine. This should bring you around E30 or so.
    I have 6 gallons of E85 in my tank right now, it's a noticeable difference over straight pump. In fact the car is faster than its been in a while even when its hot as hell out.
    Now what is true is that you can't run straight E85 with the stock fuel system. E85 contains 30% less energy than pump gas, and thus requires 30% more flow to run it. Past 40% E85 in your tank or so is where the stock fuel system just can't keep up and you will, run like crap.
    It would be great for this community if people stopped posting vague comments, or speak when they just don't know what they are talking about.
    "Your car will run like crap" is a little vague confusing for people who are just learning about this awesome option.
    I'll just add real quick that you don't need to be tuned to run up to 5 gallons of E85, you can do it stock but you won't see the same performance benefits that you would if you had a tune, that can take advantage of the increased octane and cooler charge.
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Jan 04 2013
    Phoenix, az
    ^+1 on the vague comments!
    Jun 12 2015
    CA
    Quote Originally Posted by roadawg View Post
    The stock fuel system hardware has the ability to run full E85, as long as it's tuned properly, and maintains the OEM crank and SC pulleys.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    With the heat you will definitely benefit from running an e85 blend. I would say 4 gallons, more than that in 95+ weather and you could throw a lean code. Works great for me!
    Sent from my SM-G925V using Audizine mobile app
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    What about with just a APR stage 2 tune? Any more benefit than running it stock? Will ECU detect lower knock threshold/higher octane and use more advance timing tables?
    Senior Member Three Rings BAHNSTORMER's Avatar
    Mar 26 2010
    Waukesha, WI
    Here's a handy calculator for blending: http://www.intercepteft.com/calc.html
    Daily driver: 2012 S4 P+
    Phantom Black Pearl Effect / Sports diff / Alcantara / S-tronic / MMI Navi + / B&O / 19" Peelers / Carbon Atlas inlays / advanced key / rear camera / Supercharged badges
    Previous Audis: 1984 4000S Quattro // 1989 200 Quattro // 1994 S4 // 2005 S4 // 2010 A5 3.2
    Jun 21 2004
    mpls, mn
    First, log your timing correction. If there is none, then no benefit. If there is some, then there could be some benefit.
    Jan 09 2015
    Quote Originally Posted by colby7 View Post
    I honestly did not know that, I never heard of this before.
    I read the high pressure fuel pump can't keep up with flow demands.
    Thx for clarification.
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    What is this info based on? Conflicting reports out there on this....
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Jun 12 2015
    CA
    Quote Originally Posted by Silverbullet S4 View Post
    See EPL E85 Stage 1 - it uses the OEM HPFP.
    Jan 09 2015
    When you say stage one, you mean stock pulley, EPL tune and 100% E85?
    But, if you get a smaller SC pulley, re-tune and run 100% E85 then you need an upgraded high pressure fuel pump?
    Not a fan of "stages" as descriptors. Sorry I am very technical.
    Jun 12 2015
    CA
    Yes to both questions.
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by KnewJack View Post
    Here is my plan for what it is worth as I am getting tuned this Friday with APR ECU, TCU, fully loaded ECU tune and Stage 2 pulley. My AMS Alpha cooler is on its way from the group buy EPL had so I will not have it in before I get tuned. Keep in mind I live in Phoenix where its 112 for a high and 90 for a low right now.
    I am going to run the 91 octane map with my current fuel mix that gets me about 94 octane, that I mentioned above. Once I get the Alpha cooler installed I am going to switch to the 93 octane map with the same fuel mix.
    The tunes have room to adjust, within the tables. So if it is not perfect it will pull timing and you just don't get the max power that you could get for that map. As mentioned above the best way to know is to log timing to see if it is being pulled. This will let you know if your getting all you can out of the tune your running.
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    that is correct.
    when i contacted EPL about running pure e85 vs. a mix of e85, here's what i was told. since i'm in CA, we only get 91oct. a mix of e85 and 91 can be run on the 93oct tune. running on full e85 however, will require an e85 tune.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    it does not. If it was able to run on full E85 audi would of advertised it that way.
    Running full E85 in a stock car will throw cel's You will get lean codes. They factory tune is meant and designed to run on 91-93 octane. running a little above it can compensate with fuel trims. But anything crazy high Yea it can compensate to an extent but when it gets over a certain compensation level it will throw a cel.
    If you want to run some E85 thats fine but not a ton
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by chaos2984 View Post
    Uhhh, he specifically said, that the stock hardware is capable of supporting E85 "as long as [the ECU] is tuned properly".
    AKA, an E85 tune.
    -Hayden
    Jan 14 2009
    pasadena md
    Quote Originally Posted by LINDW4LL View Post
    AKA, an E85 tune.
    guess I was more tired that I thought. Sorry just read it wrong.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    See my sig.
    I run a blend and do notice a difference in the VERY hot weather we're seeing now. Once temps drop below 80* I run just 93. If you don't regularly drive with "spirit" you will probably never notice the difference. I do 2-3 gals of E85 with 93 for the rest. Have never seen an issue or a code and logs are just fine.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jan 04 2013
    Phoenix, az
    I wish we had 93 here, you would think a place that gets as hot as the damn sun would! E85 blend is the only option we have.
