Results 1 to 32 of 32
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    How do you guys with 2 speed electric fans have them wired?
    So I bought a 2 speed electric fan in attempt to battle my high water temps when running my AC in 100º+ weather. I went with a Derale unit which flows 1500cfm at low setting and 2100cfm at high setting, which is the highest I could find for a 14" fan.
    As of now, I want to set it up so it always runs in low speed when the engine is running then wire a switch into the cabin so I can switch on high speed when I see my water temp creeping up. Anyone wire a fan like this or have any advice? I want to go this route for the ease of wiring and not having to deal with extra modules and temp sensors.
    Also wanting to see what kind of aftermarket or oem switches you guys run in the interior
    Heres a link to the fan, any advice is appreciated!:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    I'd think all youd need is two relays and a switch.
    Assuming you want the Fan controller to continue to turn on the fan as normal, Fan hooked up directly to battery switched by relay. The factory fan circuit would switch that relay. The other relay would be switched by your physical switch on the inside of the car and it would switch over the fan setting.
    Here is a diagram. Sorry it's hand drawn.
    Oct 27 2014
    Flag/Phx, AZ
    Thanks for the drawing, that's pretty much exactly what I had in mind. In that setup, when the switch is turned on, will both the high and low terminals have 12v? Cause the fan requires both wires to have power to enable high mode.
    Also the switch would need to have a switched 12v source to it as well correct?
    IG: CJ_s4
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    I live in australia and used to blast my aircon in 100+ weather all the time and it never budged once. Nothing other than to add that the stock system, if working correctly is capable of cooling sufficiently.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by CJ_ View Post
    Sorry didn't realize they both needed to be together. In that case you will connect the wire going to 30 of the relay to the left directly to the wire that goes to 87a.
    Your toggle switch will need to deliver 12v to the relay in order to power its coil. When you power it's coil, you move the internal "flap" from 87a to 87. You can come off of really any circuit for the toggle switch since it will be a very low current task. I'd just come off the 12v of a neighboring switch to make it easier.
    I'll adjust the diagram later.
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    Which fan are you replacing with the Derale unit? The front one? The one driven by the fan belt through the fan clutch? I'm pretty sure you're not going to improve flow beyond the engine driven fan with an electric unit.
    The upside to the EFK is less power taken to drive it along with less weight. Obviously the downside might be hotter running but I haven't seen that.
    Oct 27 2014
    Flag/Phx, AZ
    I'm replacing the belt driven viscous fan, it simply can't deliver enough air alone to cool the engine when the temps are above 110º. Straight from JHMs website for their EFK:
    The JHM EFK completely bypasses the stock mechanical fan pulley and fan without the need to get a new belt. This fan kit eliminates the parasitic engine load cause by the mechanical fan and since it only helps to have it on when you're going under 30mph in traffic, in most cases, it's rarely even used! But when it's needed, you (and your motor) will appreciate the increased cool air flow from the High Flow Fan.
    High Flow kits are recommended over Medium Flow kits where summer temperatures are above 90 degrees regularly and for people who may sit in traffic with the A/C on for extended periods of time in such heat.
    Which the only time Im really seeing temperature creep is in traffic and driving around town mid-day and temps get into the mid 110s here in Phoenix.
    It might be worthwhile mentioning I am also running a FMIC so the stock electric fan was deleted.
    I also installed a brand new OEM radiator with the build, so I know thats not the problem
    Quote Originally Posted by vavJETTAw36 View Post
    Appreciate it!
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Appreciate it!
    Ok, this is personally how I would wire it. This is to wire it so that the fan control module continues to run the fan when it feels it needs to. You will only have control of setting it high or low and you will not be able to turn it on when you feel like it (remember, fan control module does it)
    Also want to note that this does not depict actual wire color. The only accurate color is the EFK fan wiring, brown is high, grey is low.
    Oct 27 2014
    Flag/Phx, AZ
    It would need to be branched before the first relay like this, correct??
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Sorry must be tired. Yes, that is perfect. Though it would not cause a problem, connecting to 87a is just redundant.
    87a is normally closed meaning 30 and 87a are connected when the coil of the relay is not charged. So it's not needed since we are bypassing it anyways bi connecting before the second relay with grey (low) wire.
    Jul 04 2012
    Woodbridge, VA
    No sorry that is not right. I didnt notice your other changes you made. Let me update the diagram so its clear.
    Aug 30 2007
    nyc
    i always have mine on the high setting and comes on just like stock settings
    c5 A6 tip
    this n that
    Jul 04 2012
    Woodbridge, VA
    Here we go:
    Oct 27 2014
    Flag/Phx, AZ
    Cool thats the configuration I'm going to go with then. Now just need to figure out where to mount a switch in the interior
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    I have a solution for you and I dont need to diagram it either
    https://www.ecstuning.com/b-genuine-...8d0035775ab98/
    You can find it cheaper elsewhere, but just for reference.... But just noticed you have a ESP equipped car so where my car has a blank cover yours has ESP button... You can wire your rear and front fogs together and have one switch and add this funk switch.
    Mar 22 2013
    AK
    Do I read this right that this fan is almost 5 inches thick ? Hayden fans of similar cfm are much slimmer at less than 3 inches.
    Oct 27 2014
    Flag/Phx, AZ
    I was saving that for something better hahaha but with the front mount, I don't have front fogs for now, so I guess I could just tap into the fog light switch for the fans for the time being, at least till winter rolls around
    IG: CJ_s4
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by Drehmoment View Post
    I believe thats the packaging dimensions, cause the fan is only 14" diameter, I think I read somewhere that its 2 3/4" or something
    Edit:
    Here you go
    Specifications
    CFM high/low: 2100/1500
    Amp draw high/low: 22/16.2
    Width: 14-1/2"
    Height: 14-1/2"
    Depth: 2-5/8"
    Mounting: 8-3/4" x 13-1/4"
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Yes,
    Grab yourself a wire tap connector (I like using posi-tap as they are much more reliable) or slide the sheathing back from the wire and solder a wire directly to it (not sure what wire is 12v off of the fog light switch). run this wire to 86 of the relay to the left and that should square away the "physical switch" portion of the solution.
    Oct 27 2014
    Flag/Phx, AZ
    Sweet, thanks!
    On another note, I was able to find the instruction manual for the fan and found this diagram:
    Looks like the grey wire may just be a signal wire, and may not need the second relay?
    http://derale.com/images/stories/vir...pdfs/18214.pdf
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Sweet, thanks!
    You might be able to run it that way. As long as low speed does not draw more amperage than the fan (fan clutch, right?) you are replacing. If it doesnt, it will certainly work with only one. Grey IS NOT just a signal wire. Let me adjust my diagram with this second option in mind.
    Jul 04 2012
    Woodbridge, VA
    I recant my last statement. There is no way to do it without two relays. The options in the manual are based on either 1) manual switch, 2) thermostat switch.... You are doing both.
    Oct 27 2014
    Flag/Phx, AZ
    Does anyone know when this front fan is supposed to come on? I'm in the middle of installing my fan and Im thinking about tapping into the power for it since I have this fan deleted for the FMIC.
    (not my car)
    IG: CJ_s4
    Aug 17 2015
    Holland
    That fan turns on by a blue sensor on the left in some coolant line on the bottom. You can hotwire it by wiring pin 1 and 2 together (low) and 3 and 4 for high.
    It also turns on when going aftercool when you turned your engine off but the heat is still in there.
    2001, RS4 B5.
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by Jism View Post
    Cool so if I cut the pigtail off of the old fan and splice it in to the new fan, it will essentially run only when the engine gets to a certain temp? Does this fan have anything to do with the AC?
    IG: CJ_s4
    Aug 17 2015
    Holland
    You really should dive into a diagram because i'm not sure when that fan is actually running. You could blow your fancontroller for adding too much of a resistance with more then just 1 fan.
    Audi S4 and RS4 uses 3 fans in total from which 1 of them is from the engine itself, 2nd being the Airco-fan (this one is used on both AC and engine heat) and the third one on the front being controlled by a fan controller (right-side bottom IC) and controlled by a small sensor on the left (coolant line, bottom) with 4 wires.
    I believe there was different functionality, the front fan only turned on when coolant temp exceeds certain value. Normally any S4 driven car with proper working cooling system is suitable up to 100 degrees, and if not enough you could always turn your heater on.
    2001, RS4 B5.
    Jul 04 2012
    Woodbridge, VA
    That circuit in question is on a 40a fuse, however, who knows how much the AC condenser fan is individually drawing. I guess you could try it. If the fuse pops you'll have to rewire.
    Aug 06 2008
    Canadia
    In arizona especially i would run a low temp thermostat, i wouldnt go so crazy as the engine never got up to temp but it makes a huge difference. Of course i only recommend that provided everything else in thensystem is working properley
    the B5 S4 is like the mafia... there is only one way out!
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    dood, Idk how you feel about it, I have the JHM EFK setup, they have wiring for their relay setup and fan that's pretty straight forward and easy, that's what I used, only problem I ran into, my fan relay over heating and then not working in the stupid HOT socal weather, so I tapped in another relay and power/signal to split the load and the heat, I even ran the wiring up next to my wiper cowl(next to the box that hold the engine control unit) too keep it away from the engine heat, since I ran the second relay, no problems.....also I believe the front fans come on when you turn your AC on or if its up to temp. pm me if you have some questions, id be more than happy to take some pics of mine and send them to you.
    2008 Ibis RS4....GETing tuned
    Mar 21 2015
    Southern California
    CJ,
    Did you end up running your fan like this? If so, what two wires did you tap into on the car in order to get the low temp and high temp switches to activate? Did you fry any relays this way?
    Sweet, thanks!
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by sidewayzgt View Post
    CJ,
    That diagram is wrong. Tomorrow I’ll make one for you.
    On that diagram you want 85 to be coming from the auxiliary fan switch, 86 from the battery 12v.
    Oct 27 2014
    Flag/Phx, AZ
    CJ,
    Tbh I don’t remember, I believe I had it on 2 relays and the high speed one was triggered by a switch on the interior. Like the drawing vav posted above.
    IG: CJ_s4
