I'm going to try and charge it first and see if that works. I did catch the cluster flicker the other night when I had the lights on while parked, with AC going as well. Carista showed me some codes that some things were limited due to voltage function to high. Haven't gotten any codes since or flickers since.
IF I do need a new battery does it NEED to be registered via VAG? Or can I use the memory power saver method when you plug into the OBDII and the cigarette lighter to maintain power to the car while the battery is being changed out.
