Results 1 to 12 of 12
    Active Member One Ring brownkp's Avatar
    Jul 18 2016
    2014 Toyota 4Runner Limited
    Northern VA
    Condensation under oil cap?
    Got my car a week ago and decided to check the oil this morning. Noticed a little bit of a milky looking substance under the cap. There's no gunk, just kinda looks like bubbles. From searching it looks like it could be the head gasket or condensation. I haven't noticed any smoke from the exhaust, so I'm hoping it's just condensation. I only drive about 11 miles a day, 5.5 in the morning a 5.5 in the evening. The car runs great and smoothly, no CELS. Coolant looks fine, no brown milkshake and doesn't seem to be losing any.
    Should I try taking it for a nice long, spirited drive to try to clear it out? Change the oil? Other thoughts?
    Sent from my SM-G928V using Tapatalk
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Likely condensation. Can happen with short drives, don't think you have anything to worry about.
    Jul 18 2016
    Northern VA
    Also, there wasn't any on the dipstick when I pulled it out.
    Oct 31 2014
    NH
    Quote Originally Posted by brownkp View Post
    Umm any what...? Oil or condensation?
    Jul 18 2016
    Northern VA
    Quote Originally Posted by adam044 View Post
    No condensation. I know I'd definitely have a problem if there was no oil on it! Lol
    Thanks for the quick reply!
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    I wouldn't worry about it. That's just oil that sits in the oil cap cutout of the valve cover. Doesn't get mixed up in the engine, it's probably just sat there for a while. If you just got the car it wouldn't hurt to change the oil just to feel safe but I wouldn't worry.
    Jul 18 2016
    Northern VA
    Quote Originally Posted by b7_Andy View Post
    Thanks! I was just thinking the same thing. I know Audi recommends 5w-40, but it seems harder to find in my area. Would 0w-40 be just as good?
    Jul 18 2015
    I use 5W-40 on my 3.2. I know a lot of guys run 0W-40 for winter because it starts much better in the cold so it's fine to use also. You might burn a tiny bit more oil because it's thinner but not a noticeable amount. My service manual actually recommends 5W-30 and I know that's pretty easy to find if you want to go that route. All of those I listed are fine to run in these cars, I just like 5W-40 because I think it's best for track use. Just personal opinion. I might run 0W for winter this year, haven't decided yet.
    Jul 18 2016
    Northern VA
    Awesome, thanks for the help!
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Agree - Most likely condensation. Definitely take that baby out for a good, long spirited drive to get the oil hot for at least a half hour or more to drive the water out of it. Do this once a week. A 5.5 mile drive hardly gets your engine up to operating temperature where it likes to run and is best to maintain its health. Also consider taking the long way to work or home. With such short daily drives you should consider changing your oil more often than normal.
    Jul 18 2016
    Northern VA
    Quote Originally Posted by Brillo View Post
    Can't beat a solution like that!
    Oct 24 2015
    Perth, WA
    Change the oil and do a flush.
    My respray thread
