Results 1 to 7 of 7
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    HPX MAF connection
    Hi guys. So I'm currently tuning my car and in the process have already pegged my MAF at 24psi on pump gas.
    I'm thinking of getting an HPX sensor for its many benefits. One problem is connecting to our harness. I really don't want to cut up the engine harness and solder in the pigtail! Does anyone know of a way to connect it with out splicing the harness?
    I'm thinking maybe swapping the electrical pins around in the oem harness? Possible to find a male connector somewhere?
    Any help is appreciated.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    HPX MAF connection
    The HPX setups that I have seen require the new connector for the HPX Maf and wires to be spliced into the harness. Butt connectors work great for this instead of soldering. As far as male connection you could cut the male end off of a old Maf and solder wire to the back side of the pins to connect to the HPX pigtail but that might be a lot of work I have never done it just throwing out an idea. If you don't want to go through all the trouble of adding the HPX Maf you can always increase your Maf housing size and have NVR recalibrate your Maf Scaling.
    Jul 07 2009
    Alberta, Canada
    Proper way to do it would be to de-pin the original connector and re-pin the HPX one.
    EDIT: Not sure what style pins each one uses but you may be required to source proper pins for the HPX connector.
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by JVD View Post
    This is what I really would like to do. Could the proper pins be sourced easily?
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    If you don't want to cut, you will have to find the correct plug to fit the MAF plug and make a jumper.
    I believe someone has done this, would be something to look into.
    Apr 07 2011
    Home of the mighty beaver
    Id like to know too... have to go this route as well.
    oh and gmdiluca, i tried to PM you, your inbox is full.
    Mar 29 2013
    Ontario, Canada
    Quote Originally Posted by NOTORIOUS VR View Post
    Ya I quickly googled to find a male hitachi MAF connector but no dice. Might need to search across another platform with the same MAF connection.
    I still think re-pining is possible. Id have to look at the pins.
