Originally Posted by
Thruxton900
When the "S" button is actuated, should I experience a tremendous difference?
I would say there is a NOTICEABLE difference, but not "tremendous". You already hear your exhaust flaps working (opening). The RPMs will not change. The pedal response should be a bit more lively. When you go WOT, it should throw you back in the seat a bit harder than without S button. When you let off the gas, you should feel a bit more engine breaking power. Lastly, as many agree, shifting seems smoother in S-mode (around 5-6k RPMs) because the throttle response is faster.
Generally speaking from a feel standpoint (through all gears, same pedal pressure): S mode OFF = softer/smoother acceleration with less torque feel // S mode ON = harder/faster acceleration that snaps your neck back a little with more torque feel on/off the gas pedal.
Do not expect the S button to completely transform the car, it just makes throttle response snappier/more alive and gives you a little more burble/volume from the pipes. Hope this helps!!
If you're ever up in Bmore send me a PM. Nice Triumph.
