Results 1 to 17 of 17
    Mar 15 2015
    Toronto/Ontario
    4-Spoke to 3-Spoke Airbag Cover Swap?
    Hello everyone again,
    As some of you know from my last thread I recently bought the vcds for my car. That also means I can put in my wheel with the flappy paddles. Now the only issue I have atm is I don't have an airbag for the 3 spoke. I read allot about the conversion but not about whether this can be done, I want to just buy a 3 spoke cover and put it on my airbag from the 4 spoke. Is this possible and will it work?
    Thanks.
    Feb 08 2012
    Dallas, GA
    I wouldn't try it. You're playing with an explosive doing that. Just go find a 3-spoke airbag.
    Mar 15 2015
    Toronto/Ontario
    Well to a point, yeah I guess. But it's an explosive that cannot be triggered without electricity, so it won't go off with it unplugged.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I've been wondering the same thing, actually. They connect identically, so it's not a matter of it exploding, and I think the shape is the same, as well. If I had a three spoke steering wheel, I'd offer to test the theory.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jun 27 2011
    Quote Originally Posted by TurboBrickTom View Post
    You really want to test that theory? They really don't need much current/voltage to be triggered...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 04 2015
    Toronto Ontario
    Step 1: disconnect battery.
    Step 2: disconnect air bag
    Step 3: remove air bag
    Step 4: test fit air bag in secondary, uninstalled wheel
    Step 5: might or might not physically fit
    Step 6: If fits, ensure connectors are identical
    Step 7: if identical, reinstall in reverse order
    Mar 15 2015
    Toronto/Ontario
    Well I've seen airbags be taken out of a cover many times before, even done it myself. Im more asking if the actual airbag from the 4-spoke wheel can fit in a 3-spoke cover and wheel. This will probably be something I do try, as from what I can tell it is a common question that never really gets answered in. Terms of swapping the wheel.
    Feb 18 2014
    toronto
    I have a 4 spoke air bag and just got a 3 spoke wheel, will try this tonight or tomorrow. Let you know how it goes...
    2008 B7 2.0T 6MT QUATTRO S-LINE
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    My understanding is that it does not fit. I believe ericw. on here tried and it just simply wouldn't fit because of the size or fitment difference.
    Mar 15 2015
    Toronto/Ontario
    Quote Originally Posted by i3oricua View Post
    Any link or anything on that? I would like to see his write up
    Mar 15 2015
    Toronto/Ontario
    My question now would be, is there any difference between the 3-spoke airbags? Or will any 3-spoke shield airbag fit with any 3-spoke wheel?
    Sep 17 2006
    Aurora, Colorado
    He has no write up that I'm aware of. He stated on the "What have you done to your b7 today" thread. Probably in the last 30 pages or so.
    Nov 15 2011
    Montreal | I sell in USD
    You could use a B8 A4/S4/A5/S5 3 spoke airbag but will have to use your own aribag harness.
    You can't use an A3 3 Spoke airbag since they're single stage but it wont fit anyway.
    *****I sell in USD*****
    Mar 15 2015
    Toronto/Ontario
    Quote Originally Posted by Axis View Post
    I think the wheel I bought might have been from an a3 anyway. I'll have to check the part numbers to be sure (although I'm not sure hownto do that yet). I know it fits, I put the wheel on without the airbag to be sure. I'm just not sure what airbag to buy. I know when I did this I put the 4 spoke airbag up to my new wheel and it didn't seem to fit right, the airbag was ever so slightly bigger then the wheel would allow.
    Nov 15 2011
    Iirc correctly you can put an A4 airbag in an A3 sw but not the other way around. (Not sure though)
    You'll need to use the screws from your A4 airbag (A3 are longer)
    Junior Member Two Rings reaL's Avatar
    Jul 08 2011
    2020 VW Tiguan 2020 VW Atlas
    Hawthorne, NJ
    - - - Updated - - -
    Quote Originally Posted by jubegnx View Post
    Was wondering what the result was I am in the exact same situation... Saw a bunch of covers online and wondered if it was possible.
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    The last time I looked (about a year ago when I switched to 3 spoke) was that the cost of the cover itself was almost the cost of the airbag assembly... could be vastly different now maybe?
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
