Results 1 to 9 of 9
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: ECS FSI Coil Pack Conversion Kits | B5 A4 1.8T
    The combustion event inside the cylinder must be carefully controlled to realize maximum power and efficiency. Upgrade to the 2.0T ignition coils to ensure your fuel mixture burns rapidly, thoroughly, and reliably, while enhancing the beauty of your engine bay.
    The Stage I ECS Kit includes everything needed for the conversion: stainless steel hardware and a 2.0T Coil Pack Conversion Plate (3 color options). The Stage II Kit adds aluminum Coil Pack Hold Downs (3 color options) to keep pressure on the coil pack—a simple and attractive solution to coils popping out of location.
    Why settle for stock?
    Fits:
    Audi B5 A4 1.8T ATW/AWM 1999-2001
    Jason
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Does the oem plastic engine cover fit over it. I have a painted one id like to keep
    Oct 02 2006
    Wadsworth,OH
    Yes it will. I have my cover still on and I'm using this kit on my B6. Although I'm not positive it will clear if you use the tie downs, that I do not know.
    Jason
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Good to know. Thanks a lot. Ill buy the initial kit and then try the hold downs later
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Fits:
    Jason
    Do you have a conversion kit for a 1999 1.8t AEB Engine code?
    Nov 03 2014
    Missouri, US
    Just a tip with these, although I have gotten away with 0.38 gap with the red tfsi coils, you're probably better off going with a 0.28 gap. A few mentions here and there about remapping your dwell times to be a bit shorter for these to improve longevity also.
    Other than that, the adapter plate fits the valve cover fine and my coils are somewhat difficult to pull out, seem securely mounted even without the hold-down brackets.
    Oct 02 2006
    Wadsworth,OH
    Appreciate the feed back!
    Jason
    Oct 02 2006
    Wadsworth,OH
    Good news these are back in stock!!!
