The problem of the day is rear brake line fittings.
I am putting rebuilt B7 rear calipers onto the car and was going to install new StopTech SS flex lines, but that's just not gonna happen. My fittings are completely corroded similar to this thread. On the passenger side, there's no nut left to turn and the spring clip is crumbled and gone. On the driver's side, the nut is still there, but I won't even try to turn it.
My passenger side caliper was/is leaking and it looks like it's leaking from the banjo bolt connection - likely the crush washers are gone and letting some fluid out.
So, at this point, I'm thinking about these two options:
Option 1.
Install the B7 calipers onto the existing flex lines and install my new B7 pads and rotors etc. (the carriers and shields are fitted already). When installing the banjo bolt, fit another copper crush washer (anyone know the size?) between the banjo bolt and caliper. This is because I believe that the OEM flex hose has the banjo bolt fitted in the line and the crush washers are integrated with it unlike aftermarket lines, which have the washers available separately. See here for OEM and here for aftermarket to see what I mean. Then I would just take the car to a local shop to have the lines replaced and get them to cut off the old fitting and flare the line and install a new flare nut and the new SS lines in the rear. My worry is that putting on new B7 brakes and flushing the system, I will need to go bed everything in and that crush washer leak may be on the other side of the banjo fitting and it will leak and the whole bed-in drive may not go as planned!
Option 2.
I don't even know whether this is possible, but can I cut the rear hard line just above the flare nut and then use one of those brake line flare tools (like this one?) to flare the line and fit a new flare nut onto it? I've never done this and every DIY on this shows it being done with brake lines off the car, which I won't be able to do. Is it possible to it with the line still on the car? Besides the space being incredibly tight and dirty I think I would loose all brake fluid and run the master dry, correct?
If I go down the #2 path, it's a path with no return as once I cut that line, the car is going nowhere and I have to finish it in my garage. Or perhaps I'll go with Option 1 and instead of proper bedding in, I just limp slowly to the nearest garage and get them to flare the line and install the new SS lines and I'll bed everything in afterwards. Sure, I may have some glazing from slow braking, but I should be able to get rid of it through a few proper bedding cycles, right?
This near the end of my B7 brake upgrade saga, which was supposed to be a weekend affair, but it's now dragging on week 4 as after every completed step I discover a problem before I can continue.
But I'm so close now, I can smell the brake pads burning during the break-in!
Thanks guys!
