Page 1 of 23 12311 ... LastLast
Results 1 to 40 of 900
    Mar 24 2013
    Oakdale, CT
    Aluthman's FrankenB7 EFR 7163 Build
    So as many of you know, my QG B7 bit the dust about 2 weeks ago amidst a rash of senseless B7 deaths. I was pretty sure that the car was totaled as soon as I got out and looked at it, so I wasted no time looking for a replacement. After an exhaustive 45 minute search, I stumbled across the car I ended up buying. I ended up buying Kristokes Ibis DTM sedan. Where as my previous car was more go than show, Stokes' car leaned more towards the show. It did have a GT3071 BT kit installed but it was on a stock motor and clutch, which limited the setup. So what was a guy to do? Yup, combine the best of the two to make a FrankenB7.
    I put a deposit on the car and hopped on a train to head down to Jersey to pick it up. After some delays with less than stellar NJ DMV employees and a small hiccup at the bank, I was on my way back to CT. So without further ado, I hereby commence this build thread! I even broke out a real camera to take pictures instead of using my iPotato.
    Old car:
    New car:
    Stay tuned to the classified section as duplicate parts will be listed for sale along with the full part out of the old car after I pick everything off that I want.
    Current Mod list
    PERFORMANCE UPGRADES:
    DoTuning custom tune
    BW EFR 7163 turbo (T4 twin scroll .80 A/R)
    Custom (by me) 304SS tubular T4 twin scroll manifold (1.25” sch 10 pipe)
    Swain Tech White Lightning coating on turbo exhaust housing and manifold
    Custom (by me) 3” downpipe and removable v-banded 3” Magnaflow HFC
    Custom (by me) aluminum intake
    IE drop-in rifle drilled rods
    Milled BPG forged pistons (9.5:1 CR)
    Ferrea valves, springs, and titanium retainers
    IE valve guides and valve stem seals
    ARP head studs
    ARP main studs
    IE press fit crank gear
    Fluidampr
    S3 injectors
    RS4 lpfp controller
    3 bar MAP
    JHM Stage 3 clutch and aluminum lwfw
    USP metal slave cylinder w/ SS clutch line
    ECS Poly Motor Mounts
    AWE-Tuning Front Mount Intercooler
    AWE-Tuning Quad Tip Custom Axle-Back Exhaust System
    HPFPupgrade Stage 2 High Pressure Fuel Pump
    HPFPupgrade 165 Bar Performance Rail Valve
    Podi Dual Gauge pod with oil pressure and Snow VC-50 meth controller/boost gauge
    Custom (by me) in trunk 4 gal. aluminum meth tank
    034Motorsport Intake Manifold Plug w/ Boost Tap
    Optima yellow top battery
    EXTERIOR UPGRADES:
    DTM Front and Rear Bumpers
    DTM Side Skirts
    DTM Rear Door Molding Emblems
    DEVAL Rear Trunk Spoiler
    HRE 545R 18”x8.5” ET34 wheels (summer setup)
    ECS Tuning Smoked Side Marker Set
    Sonic Tuning 6000k OEM Xenon Replacement Bulbs
    OEM Rear Deck Lid Audi A8 Rings
    OEM Bi-Xenons w/ CC and blackout
    Brilliant Black Painted Roof
    Evolution Thor Aluminum Underbelly Cover Skid Plate
    Podi "Skidplate" Removable License Plate Mounting Bracket
    Debadged
    INTERIOR UPGRADES:
    Pioneer AVIC-X940BT
    Alpine SPR-60C component speakers x4
    JL Audio 10W3V3 sub
    JL Audio XD700/5 amp
    Audio Integrations sub enclosure
    Sonic Tuning S2 Interior LED Kit
    Dynamat Insulation to All Four Doors and Cargo Area
    Weathertec floor mats
    B6 S4 Recaro seats w/ bladder swap
    RS4 Pedal Set w/ dead pedal
    Gloss black interior trim
    Two-tone black and tan interior
    ENGINE BAY UPGRADES:
    RS4 Rain Tray Cover
    RS4 Battery Cover
    SUSPENSION/DRIVETRAIN UPGRADES:
    H&R Front 32mm Sway Bar
    H&R Rear 20mm Sway Bar
    KW V1 Coilovers
    Apikol (Red) Billet Aluminum Rear Differential Mount
    Black Forest Industries Snub Mount Upgrade
    JHM Sold Short Throw Shifter
    JHM Solid Shifter Stabilizer Bushing
    JHM Solid Linkage Upgrade
    AWAITING INSTALLATION:
    IE intake manifold
    IE dual pump surge tank w/ (2) AEM 380 lph pumps
    Brembo GT 328mm front BBK
    S4 rear calipers and rotors
    Goodridge stainless brake lines
    Hawk Ceramic pads
    Hyperco rear springs
    -Adam
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Are you going to take this new car to the track to see how it does in its current state?
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Jake@JHM View Post
    No because it has some issues that are preventing that. I'm trying to track down some misfires right now as well as a fuel cut issue. Already replaced the plugs, but if they are still there I have a new set of coils. I haven't logged yet, but I think my low side fuel issue is a lack of pressure at high WOT. It has a hard fuel cut (or possibly misfire) that shakes the car when you really get on it. It runs fine otherwise. It also has a remote start installed which bypasses the clutch safety switch. This will prevent me from passing safety inspection at New England Dragway and probably most other places.
    I want to get everything straightened out because I'm doing all the interior stuff (including meth and stereo install) before swapping the EFR, built engine, and JHM clutch in. Undecided on whether I want to keep the solid engine mounts or swap my 034 street density mounts over.
    -Adam
    Aug 31 2011
    Lathrop
    Oh gotcha.
    Got a CEL?
    Sounds like a fun build though
    Mar 24 2013
    Oakdale, CT
    Oh gotcha.
    Got a CEL?
    I got a CEL about halfway home from Jersey. Not sure whether is was the misfires or the fuel cut that caused it.
    -Adam
    Aug 31 2011
    Lathrop
    What was the code?
    Jun 17 2013
    jersey city nj
    Did it go into limp mode
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    Yes
    - - - Updated - - -
    What was the code?
    Don't remember. It wasn't the P310B I thought it was going to be. I'll post it here if it comes back.
    -Adam
    Jun 17 2013
    jersey city nj
    Does he have a RS4 lpfp module
    Mar 24 2013
    Oakdale, CT
    Didn't look yet, but it wasn't on the mod list. I can swap that over from the other car easy enough.
    -Adam
    Jun 17 2013
    jersey city nj
    Imo Id into that
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Old car:
    New car:
    That S10 though
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by derrek View Post
    That S10 though
    It's the beast of the fleet. It only looks shiny because it's wet lol.
    -Adam
    Jul 23 2010
    arizona
    Most reliable that's for sure
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    In for the progress... I'm glad it went to another Audi enthusiast
    B8.5 Audi SQ5 | APR Stage 1
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    I'll be interested in one of those injectors.
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Is this done yet? j/.k
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by xRenesis View Post
    Which ones?
    -Adam
    Jan 14 2015
    South Dakota
    Just a stock 2.0 one. :D
    Jun 27 2011
    Just one? Why not try ebay?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 24 2013
    Oakdale, CT
    Because ebay is more expensive that Awesome Adam's Used Parts Emporium!
    -Adam
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Adams emporium should sell a top mount turbo manifold!!!
    Mar 24 2013
    Oakdale, CT
    Adam's Emporium does sell a top mount manifold...
    -Adam
    Feb 10 2012
    parts
    Napanee, ON
    Then Adams emporium should send me some details!!! Lol I didnt know you was selling such unicorns from your emporium. I thought this was a Adam 1 of 1 or 2 since now you have multiple 2.0 cars. Let me know doesn't needs to be full stainless I'm looking for something moderatley quick since im having serious fitment issues w the 2867.
    Mar 24 2013
    Oakdale, CT
    Unfortunately, with the backlog of shit that I need to get done, I won't be able to do another manifold in the near term. Maybe in a few months.
    -Adam
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I am subscribed for a part out!
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Mar 24 2013
    Oakdale, CT
    Small update. Managed to get the HREs swapped over.
    -Adam
    Oct 09 2014
    Norway
    I love it, DTM style looks very good. the cheapest true DTMs in my country with high milage starts about 32k$ its insane!
    [ B7 2.0TFSI Avant Quattro 07 ] [ Maestro tuned ] [ EFR 6258 .80 Twinscroll QSV ] [ S3 injectors ] [ Autotech HPFP ] [ ER FMIC ] [ Neuspeed Catback ] [ ARD V-Band Manifold ] [ TTRS LPFP + Torqbyte PM3 + CM5-LT ] - Build Thread
    Mar 24 2013
    Oakdale, CT
    Dropping these off today to get blasted and powder coated black along with S4 rear calipers and carriers.
    -Adam
    Jun 27 2011
    Quote Originally Posted by al3k View Post
    At least your DTMs come with a more powerful engine to somewhat justify the cost.
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    Sooooooooooo jelly!
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
    Jun 17 2013
    jersey city nj
    Definitely a BBK when you have a stage 3 BT kit on board
    Mar 24 2013
    Oakdale, CT
    I hope I don't regret the 2 piece rotors. The damn rings are $710/pair. I hope I can get at least 2 sets of pads out of them.
    -Adam
    Jul 23 2010
    arizona
    one of my buddys has 70k on his alcons and they still have a lot of life left
    Jun 27 2011
    Jhm two piece?
    -CP
    2017 Q7 3.0t
    Jul 23 2010
    arizona
    Jhm two piece?
    Dont think JHM makes rotors for Brembo GT BBK's
    Jun 27 2011
    Oh? I have no clue about brakes above OEM stuff, haha. Adam! What rotors did you get?!
    -CP
    2017 Q7 3.0t
    Jun 17 2013
    jersey city nj
    Jhm two piece?
    Read a few not so reviews about the rotors being unbalanced causing vibrations
    Mar 24 2013
    Oakdale, CT
    I bought a used Brembo GT kit, so the rotors are brembo. I'm using StopTech replacement rotor rings though.
    -Adam
    Jun 27 2011
    Huh. Never heard that. A few isolated cases doesn't really bother me much. The price however...
    Ahh. I missed that, thanks.
    -CP
    2017 Q7 3.0t
