Results 1 to 8 of 8
    Oct 20 2014
    Laredo, TX
    Vacuum line where to connect?
    Hello everyone, I've been having constant issues with lack of turbo. My car is running NA aparently...
    When I bought it it came with bov so Im removing that butI noticed theres one vacuum line connected to the bov. Where should the line originally connect?
    Im planning to have it stock and then find more possible issues.
    Right now Ive checked westgate and turbo and they looked ok.
    Im replacing turbo solenoid valve today.
    Thanks for your help guys
    Sent from my E6653 using Tapatalk
    Oct 20 2014
    Laredo, TX
    Anyone with their 2.0 tfsi motor picture :(??
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Can you post a better picture? I'm having a hard time distinguishing what is specifically is based on the angle of the picture you took.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jun 26 2009
    Bremerton WA
    On the intake manifold there should only be the hose that goes from the manifold to the PCV. The N80 purge valve will plumb into the intake manifold as well. Most systems that need contant vacum connect to a separate vacuum pump. I can make out some sort of adapter between the intake manifold and pcv hose. this is where a vacuum line going to a BOV would tap into, usually a boost gauge is tapped here as well. If you aren't going to be using those remove the adapter and reconnect the hose directly to the manifold or insert screws into the unused holes to mantain vacuum. If someone did tap into the always in vacuum system you would never have boost as the BOV will stay open indefinitely. The location shown in your photo is at the false port on the intake manifold. It looks like something should be there but the hole is filled in(unless they tapped a port there)
    VMR 710's, APR software, Eurocode HFC
    Oct 20 2014
    Laredo, TX
    Thank you. Bov was doing its function as I used to have turbo going in and out...
    These are some better pictures of the hose from intake to bov(which I have placed a screw in for now)
    The only one I installed was the adapter for boost gauge which you can also see there.
    So then, this vaccum port connection shouldnt even be there correct?
    Oct 20 2014
    Laredo, TX
    Another picture...
    Jun 26 2009
    Bremerton WA
    The last pictures shows the hose going to what I called the false port. Normally that looks like its a fitting but is solid in the middle. I assume it was drilled out to make a vacuum port. Normally nothing goes there.
    Oct 20 2014
    Laredo, TX
    Mistery solved! Thank you!
    BTW just picked the car from the shop and sofar looks like the n75 was the problem!
    Im getting 15psi 😁😁😁
