just wondering if anyone experienced the same problem while installing the bosch 386cc injectors. (light blue long nose injector)
I am not able to completely push the injector into the manifold. i can't get a good view but it feels like the bottom oring doesn't go in
enough for a snug fit. i tried swapping the bottom oring with the original injector (dark blue ones) but got the same result. the injectors i bought came with
the o rings already installed. the bottom o ring is slightly bigger compared to the oem injector.
i installed the new injectors and screwed in the 2 screws for the fuel rail. i get no leaks at all. but im a little cautious because if i were to remove the 2 screws
that hold the fuel rail down, i will be able to pull out the injectors with very little force.
Has anyone else encountered this problem or is this just the way they are supposed to sit? and would spacers be of any help.
