Results 1 to 12 of 12
    Established Member Two Rings btvm92's Avatar
    May 25 2015
    2003 Audi S8 Exclusive Edition
    Jonesboro, AR
    Headlight Restoration Peeling/Flaking?
    I restored my headlights less than 6 months ago with the spar urethane/mineral spirits method.. It appeared to work perfectly and this is the only headlight I've had do this to me. It appeared to happen overnight, I just noticed it one day, now it's just slowly flaking away. I'm about to redo it but I'm wondering what caused it? Especially considering I've been swearing by this method since I've done it..
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    the coat was too thin / diluted too far? my guess. you came into contact with derbis / road acid
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    could have been surface contamination that caused a reaction with the finish.
    being spar varnish is oil based my guess is some water got under the finish
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    https://www.amazon.com/3M-39045-Head.../dp/B004GFTC0E
    urethane coating is a wrong way of doing it. Once lens plastic changed it's optical properties, it needs to be removed, not coated.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Lol, check out my headlights, someone used the wrong-grit sandpaper on my driver-side headlight *cough*
    Pictures to follow...
    I still haven't tackled the damage, but do intend to use the right grit-sandpaper in increments followed by "Clear Coat"
    Hopefully, will look great at the end
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Senior Member Three Rings bpark1210's Avatar
    Jan 08 2016
    PNW N. of Seattle
    I have the same issue on both my headlights. I went w/ the urethane spar/mineral spirits dilution but less than 6 months later it's peeling. Prob didn't help w/ all the rain we get and driving over 100mph through the mountain passes. I bit the bullet and bought some Opti Lens Permanent coating as some others have suggested. I'll be reporting back on my build thread once I get my lazy a** to start my S6 project again.
    Dec 04 2012
    Arlington VA
    why keep coating, when opposite is needed?
    Jun 04 2013
    SE MI
    so vinny youre saying to polish is the right way
    Dec 01 2012
    Charlotte, NC
    If that was my car, i'd sand that headlight down real good, then buff it good, wash it good, then spar it again.
    Jun 04 2013
    SE MI
    the spar needs a textured surface to hold onto. ok so maybe polishing is a better idea for longevity. otoh my other headlight didnt peel yet. yeah ill bet a contaminant got in there. if you do it in a garage where you smell oil in the air, well theres your answer. oil from the air got onto the headlight surface before you spar'd it. either that or derbis chipped a small bit enough for high pressure water to get into and behind the layer of urethane.
    Dec 04 2012
    Arlington VA
    https://www.amazon.com/3M-Headlight-.../dp/B00WY5L09O
    and a good corded drill is all you need, it even includes UV protecting compound. It takes a good amount of work to remove your urethane coating, then remove yellowed layer of plastic (bonus: getting rid of pitting), then polish. Headlights will look like new for years, as long as you reapply UV protectant stuff couple of times a year.
    Jul 27 2011
    Collegeville, PA
    Get the X-Pel film. Did mine almost ten years ago, still in perfect condition.
    http://www.xpel.com/headlight-protec...A6/Sedan/2.7T/
