Results 1 to 7 of 7
Thread: RS4 Part Out
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    RS4 Part Out
    Phantom Black
    60K miles
    Black Interior
    Premium Package
    RADIO ANTENNA - 8E5 035 225 P A0001 /$ 100
    BLUETOOTH MODULE - 8P0 862 335 R A0002 /$ 150
    SATELLITE RADIO MODULE - 8E0 035 593 N A0003 /$ 100
    COMFORT CONTROL MODULE - 8E0 959 433 CP A0004 /$ 100
    AIRBAG SENSOR - 8P0 955 557 A0005 /$ 20
    AIRBAG SENSOR - 8P0 955 557 A0006 /$ 20
    WINDOW MOTOR - 8E1 959 802 G A0007 /$ 50
    WINDOW MOTOR - 8E1 959 801G A0008 /$ 50
    MEMORY SEAT SWITCH - 8E0 959 769 A0009 /$ 30
    MEMORY SEAT SWITCH FRAME - 8E1 959 527 A0010 /$ 20
    REAR CURTAIN SWITCH - 8E1 959 903 B A0011 /$ 25
    S BUTTON SWITCH - 8E1 919 457 A A0012 /$ SOLD
    PASSENGER AIRBAG LIGHT - 8E1 919 234 B A0013 /$ 25
    ESP BUTTON - 8E1 927 134 C A0014 /$ 25
    Lock / Unlock Switch - 8E2 962 108 5PR A0016 /$ 20
    RS4 EMBLEM - 8E0 853 736 E A0017 /$ 50
    AIRBAG SENSOR - 8E0 959 643 B A0018 /$ 20
    AIRBAG SENSOR - 8E0 959 643 B A0019 /$ 20
    BRAKE LINE BRACKET - 8E0 615 133 G A0020 /$ 20
    BRAKE LINE BRACKET - 8E0 615 134 G A0021 /$ 20
    REAR SEAT HEATING SWITCHES - 8E0 963 563 A0022 /$ 50
    DOOR SWITCH ASSEMBLY (GAS/TRUNK/LIFT ALARM - A0023 /$ 50
    Right Front Carbon Trim - 8E0867410AA45X A0024 /$ 125
    Right Rear Carbon Trim - 8E0867420AA45X A0025 /$ 100
    Left Front Carbon Trim - 8E0867409L7V7 A0026 /$ 125
    Left Rear Carbon Trim - 8E0867419L7V7 A0027 /$ 100
    RIGHT SIDE DASH VENT - 8E0 820 902 F A0028 /$ 30
    CIG LIGHT CENTER CONSOLE - 8E0 863 284 C A0029 /$ 30
    REAR ASH TRAY ASSEMBLY WITH CARBON FIBER TOP - 8E0 857 961 M A0030 /$ 75
    FRONT ASH TRAY ASSEMBLY - 8E0 857 951 M A0031 /$ 50
    DRL SWITCH - 8E1 919 094 D A0032 /$ 30
    ENGINE COVER FRONT - 079 103 950 A A0033 /$ 100
    FUSE COVER - 8E0 857 085 C A0034 /$ 15
    RIGHT SIDE FUSE COVER - 8E0 87 086 C A0035 /$ 15
    VANITY LIGHT - 4D0 947 105 A A0036 /$ 10
    FLOOR VENT - 8E0 819 275 A A0037 /$ 5
    FLOOR VENT - 8E0 819 276 A A0038 /$ 5
    VANITY LIGHT - 4D0 947 105 A A0039 /$ 10
    CD CHANGER - 8E0 035 111 D A0040 /$ 75
    WIPER STALK - 4E0 953 503 B A0041 /$ 50
    COLUMN MODULLE - 8E0 953 549 T A0042 /$ 125
    BLINKER STALK - 4E0 953 513 E A0043 /$ 75
    CRUISE STALK - 4E0 953 521 A0044 /$ 50
    COLUMN SURROUND - 8E0 953 515 F / 8E0 953 497 A A0045 /$ 50
    PASSENGER AIRBAG - 8E1 880 204 D A0046 /$ 50
    SPEAKER - 8E0 035 411 B A0047 /$ 25
    SPEAKER - 8E0 035 411 B A0048 /$ 25
    Left Front Dash Trim w/Carbon Trim - 8E1853189AQ45X A0049 /$ 100
    Rear View Mirror with Compass - 4F0 857 511 F A0050 /$ 125
    SHARK FIN ANTENNA - A0051 /$ SOLD
    FOG LIGHT - 8E0 941 700B A0052 /$ 25
    BRAKE BOOSTER VACUUM PUMP - 8E0 927 317 E A0053 /$ 35
    FRONT RIGHT WHEEL SPEED SENSOR - A0054 /$ 25
    DOOR SILL DRIVERS FRONT - 8E0 853 373 Q A0056 /$ 100
    DOOR SILL PASSENGER - 8E0 853 374 Q A0057 /$ 100
    DOOR SILLER PASSENGER REAR - 8E0 853 376 Q A0058 /$ 100
    DOOR SILL DRIVER REAR - 8E0 853 375 Q A0059 /$ 100
    ENGINE COVER LEFT CF - A0060 /$ 200
    Battery Cover Rear - 4F0 915 429 C A0061 /$ 15
    WINDOW REGULATOR DRIVERS - 8E0 837 461 C A0062 /$ 50
    BRUSHED DOOR TRIM INT RR - 8E0 867 420 A0063 /$ 100
    BRUSHED DOOR TRIM INT LR - 8E0 867 419 A0064 /$ 100
    RS4 REAR BUMPER FILLER - 8E0 807 833 A0065 /$ 100
    PRESSURE SENSOR - 036 906 051 C A0066 /$ 15
    REAR PARKING SENSOR HARNESS - 8E0 971 085 A A0067 /$ 50
    WINDOW MOTOR - 8E0 959 801 E A0068 /$ 25
    REAR PARKING SENSOR MODULE - 8E0 907 277 A0069 /$ 75
    CONSOLE INSERT - 8E0 863 276 C A0070 /$ 15
    RAIN SENSOR - 4E0 955 559 E A0071 /$ 100
    DRIVER AIRBAG - 8E0 880 201 DH A0072 /$ 150
    AIRBAG AND WHEEL B6 SPORT - 8E0 419 091 AT / 8E0 880 201 AT A0073 /$ 100
    TPMS MODULE - 8E0 907 273 A A0076 /$ 50
    PARK ASSIST MODULE - 8E0 919 283 D A0077 /$ 50
    HEADLIGHT RANGE CONTROL MODULE - 4F0 907 357 F A0078 /$ 50
    POWER SUPPLY MODULE - 8E0 907 279 N A0079 /$ 125
    ESP MODULE - 8E0 907 637 B A0080 /$ 20
    FLAT TIRE SEALANT - 8D0 012 619 A A0086 /$ 40
    AIR COMPRESSOR - 8P0 012 615 A A0087 /$ 40
    AMP - 8E5 035 223 E A0088 /$ 100
    AMP BRACKET - 8E5 035 464 A A0089 /$ 20
    DECK SPEAKER - 8E5 035 412 E A0090 /$ 25
    SPEAKER - 8E0 035 411 B A0091 /$ 20
    SPEAKER - 8E0 035 411 B A0092 /$ 20
    STEERING WHEEL - 8E0 419 091 EC A0093 /$ 200
    LICENSE PLATE MOUNT REAR - 8E0 827 113 C A0095 /$ 45
    REAR TRUNK LATCH - 4F5 827 505 D A0096 /$ 35
    LATCH TRIM - 4E0 827 520 B01C A0097 /$ 10
    TRUNK HANDLE SWTICH - 8E0 827 574 C A0098 /$ 75
    ENGINGE COVER REAR RS4 - 079 103 926 M A0099 /$ 150
    GLOVE BOX COMPARTMENT - 8E1 880 302 F A0100 /$ 75
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    I'll take the alarm module.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Apr 21 2014
    montreal
    Hi how much for the glovebox compartment shipped to canada ?
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    hazard switch is mine!!!
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Nov 25 2006
    Austin, TX
    do you still have the ESP button?
    B6 Mods:
    RS4 Mods (sprint):
    Jul 28 2007
    V8's
    In an Audi
    List updated
    Jul 28 2007
    V8's
    In an Audi
    Bump
