Results 1 to 19 of 19
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Best way to mount S4 badge on RS grille...
    Yes yes I know search... well I did that and I found multiple people that glued the badge on. I trimmed down the badge so the base would fit the length of the honeycomb mesh and glued it however it still feels unstable. Did anyone else find a better way of doing it?
    Mar 31 2015
    Allen, TX
    I used hot glue gun but waited till it cooled down just a little, stable as can be for me
    Garage: '23 RS6 Glacier White, Carbon Optic, Executive, Sports Exhaust, Driv Assist, B&O Adv
    2021 Glacier Whtie Q8 (wife's car)
    Junior Member Two Rings windowguy's Avatar
    Jan 08 2015
    I would suggest silicone, construction adhesive that is made for plastic or 2 part epoxy. I would not trust regular glue on the front of my grill.
    Sent from my SM-N920W8 using Tapatalk
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Install with Epoxy - have some painters tape handy to hold in place - a level so you can ensure you (have it level) - file to file areas as needed (i used a flat section to adhere to in the honeycomb)
    Ad do all of this before you install the grill....just easier to adjust things before the epoxy cures - and before it hardens so you can make final adjustments and secure where you want it w/painters tape
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I used JB Weld. Made it flat and taped it in place, then covered the back of it with the JB Quick Weld (orange and black tubes) and around the honeycomb. Can't be seen and is very sturdy.
    Established Member Two Rings deewan's Avatar
    Mar 30 2016
    2013 Audi S4
    Cedar Rapids, IA
    I used painters tape to mark the location of where I wanted the emblem and make sure it was level. I applied some Gorilla glue that works with plastic. I put glue on all the edges of the grill that would be covered by the emblem. I pressed and held the emblem to the grill for 60 seconds then let it cure with no force. An hour later I couldn't pull the emblem off the grill and I was using a fair amount of force. 2 months later the emblem is still there and it's sat through some very hot summer days and been washed weekly. I'm guessing the plastic will break before the glue fails.
    One last tip. I located the emblem on a place of the grill where the emblem touched the honeycomb with the following outline... hopefully this makes sense.
    2013 S4 S-Tronic Brilliant Black
    Premium Plus | RS4 Gloss Black Grill | LED Interior Lights | LED Fog Lamps | Alcantara | B&O | AWE Carbon Fiber Cold Air Intake
    I always use a little chewing gum on these rides. It filters out the pollutants. Of course you've got some good grillwork there to keep out the ozone. I gotta get this thing up to 95, uh, check out the fluorocarbon output.
    Apr 04 2012
    MSP
    I used epoxy. I also afixed it with the grill OFF the car so that it could lay flat while drying. It's cemented on and not going anywhere
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I left mine off. LOL.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Three Rings ShopVac's Avatar
    Feb 02 2016
    BMW M4 Comp / Abarth 124 Spider / RDX A-Spec / Jetta / Elantra
    Pittsburgh
    I carefully cut out the parking sensor that was in the grille - used a dremmel to cut a horizontal line into it...then placed the S badge into that cut. From there...hot glue. I will state that I have some concerns in cold weather, if the glue hardens, but at least I have some sort of physical connection.
    __________________________________________________ _____
    Proud owner of four turbos and one supercharger.
    Senior Member Three Rings Dasaudi mtl's Avatar
    Dec 04 2012
    Montreal & Florida
    I have use a threaded rod with a nut and washer that i have glued with epoxy and also put double sided tape in case it didn't hold up
    2018 SQ5 Black
    Oct 20 2008
    Denver
    Quote Originally Posted by blackfunk View Post
    definitely cleaner off
    Nov 25 2014
    Alabama
    Shoe Goo. Still strong and perfectly aligned as day one, almost two years and hundreds of washes.
    2018 SQ5 | Monsoon Gray | Prestige
    Veteran Member Three Rings Sniper260687's Avatar
    Jul 22 2015
    Oklahoma
    I used a grinder, made sure it was all falt, super glue, been a year now still on
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Amazing goop. It'll stay on and whenever you want to take it off it's just as easy
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I'd strongly suggest against glue and toward an epoxy. Glue may hold for a year or even more, but when it goes you'll look at your car and realize the S symbol is gone. Get a good Epoxy and the only way it's coming off is an accident.
    Active Member Two Rings aliensporez's Avatar
    May 31 2016
    Houston, Texas
    Quote Originally Posted by hotleadsingergu View Post
    +1 Gorilla Glue 2-step epoxy. Used it to attach a new "R" badge on my XFR grille.
    Sent from my SM-G930V using Tapatalk
    Active Member Two Rings lochs's Avatar
    Jan 11 2016
    ontario, Canada
    I used zip ties LOL, you can definitely move it around if you force it, but it hasn't moved while i drive
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    my grill came with a new badge and just clips on. It looks good from far but if your right up on it, you can tell its not factory.
    Active Member Two Rings sfg57's Avatar
    Aug 14 2014
    Tampa/Florida/USA
    Epoxy putty tape. Formed it around the back tab of the badge, pushed it in place, cut away the excess BEFORE it dried. It's been solid for over a year, rain, car wash, Florida heat and humidity and its solid. On the other hand, if I had to take it off for some reason I would be screwed.
