Results 1 to 25 of 25
    Dec 05 2007
    Battery dead and want to pop hood...
    ...without going from the bottom. Question: Can it be done?
    Front door handle has handle issue unrelated held off too long (too lazy to fix). Unlocks, locks, handle won't open door. And trunk lock is stuck. Ill spray the crap out if it tomorrow with liquid wrench and try to unlock the other doors by blowing in the locking pump lines if nobody has an answer by tomorrow. And if I can't unlock the trunk, we are back to the reason I created this thread.
    No novice, and wanted to know if I can do it through the hood grill. Already popped off and tried. But can't figure a creative enough way to get to the primary release the cable releases. This I can easily get to from the bottom. But current objective is to do this just as the car sits. If anything, I'll take the time to figure a way and post it if nobody figured a way yet. I already know many ways I can get in, including classic clothe hanger. But there has to be a way with the hood grill off and creativity.
    In a nutshell, I can get to my battery. I just want to see if there is an easier way than jumping through hoops. Car is lowered with metal skid plate. And I'm trying to avoid jacking car up, taking off metal plate, and going from bottom.
    I can also take my bumper off with ease, if you guys know a way once removed. I installed pro clips (can't recall brand name off the top of my head) to my bumper. Tuner car!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I'm no help, but why can't you just unlock the door with your key? Something broken?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Also confused.
    Dec 05 2007
    Simple answer, yes. Been holding off fixing it and paying the price now. Forgot to add that info to initial post.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Ever broke into a car?
    You know that piece of rubber/plastic that is on top of your door, you know, when you close your window fully and it slides into the rubber, creating a seal.
    Well, if all else fails, you can get a stiff enough rod, bend one end about 2-3 inches at 90 degrees or 45, whatever, get that rod between your window and that piece of rubber, carefully get it through and pop open your door with the inside door handle.
    Done this on more b5's than I can remember
    Dec 05 2007
    Giantsfan, damn good idea if I can get it to unlock. Driver side seat is down, with my farad cap sitting there. This is how I monitor my battery level and allow beats to enter the cabin .
    I have a work van and hardly ever drive my cars now (can't recall last time I paid for gas, but sometime last month...I think ). Been working like an animal last couple weeks and wish I monitored it at least once before going inside my house after a long day. But if you did what I did for a living (Commercial HVAC/ Refrigeration tech...in peak season), only thing on your mind when going home is going home.
    a4kamila6, I may end up doing this if all else fails and I'm too lazy to jack up car to move over primary latch. Was about to do this today before I even made this thread. But thought about possible seal damage.
    And for clarity, this thread is here due to laziness. But really I want to know an easier way.
    Dec 05 2007
    Just got home (had a freind pick me up) and doused the trunk key hole with penetrating oil. Played with it till the key can slide fully in and out smoothly. Cant't turn it, though. Sprayed more oil and will let that marinate till the morning.
    Car is 15+yrs old. This lock cylinder has been used maybe 5 times tops since ownership (want to say never) and that is when I purchased it, just as anybody would do when getting a new car and wanting to learn it. And once again, I can get into the car no problem by two methods (coat hanger or jack up car). That is not the purpose of this thread. I want the easiest method that doesn't have the potential of damaging anything.
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Simply jack up the car and give it 12 volts from another battery.
    Ground to chassis, and run a wire to the starter post.
    Nov 03 2011
    All Over!
    Quote Originally Posted by A1 A2 German View Post
    This is what I've done, in the past.
    1986 Type 85 Audi 90 quattro
    Feb 28 2005
    Tempe
    This mod has worked out so nice for so many reasons and would work great in this case.
    Bought one of these: http://www.google.com/search?q=12vol...cOtYiYmkt7M%3A
    Made some brackets to mount under the car, wiring goes to battery (fused), converted a charger plug to male cigarette charger:
    Mounted under car, out of sight, yet easily reachable:
    Now it's dual purpose, I can keep the car plugged up if screwing with the interior (interior lights all on) or messing with the audio system, and also have exterior power if I want to run an air pump or power an invertor, etc.
    Sep 30 2015
    Thats pretty cool good job
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    My lock cylinders were all broken on my 99.5 and I Ieft my dome light on one winter night. I jacked the car up. Put my jump box negative on a ground. Then I attached the positive on a series of long 3/8 extensions wrapped in electrical tape to avoid shorting. Then I touched the exposed end of the extension to my starter post and hit the key fob to unlock.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    wheni had shaved handles on a previous b5 and thebattery died, im pretty sure i hooked up battery charger to the starter and powered the car enough to unlock the doors
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Dec 05 2007
    Didn't get to this yet, but thinking of rigging something up. Thinking run a hidden positive and negative line from the battery to the wheel well with plastic box. Question is, what gauge wire should I use. Won't be used for anything except little bit of battery juice to unlock doors in the event this happens again.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    To answer the original question: yes you can pop the hood from below. Was at the Wuste car show in Vegas 6 weeks ago, and a B5 S4 guy had a broken hood latch release (he thought it was fixed).
    I watched him pop the hood from above so I don't exactly know how he did it, but he did it... and it was his first time.
    2001 Corvette (C5) Z06
    Dec 05 2007
    Broken hood latch is different. In my case, primary latch needs to be released first.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    You're talking about the release lever you pull from below the driver's kick panel, right? That's the one I am referring to as well.
    Dec 05 2007
    That is what I was asking in my original post. There has to be a way.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Maybe I'm confused, lol.
    In my first post I was mentioning that I watched a guy pop the hood release, because his hood release cable was disconnected. This is the same one that you pop when you pull the interior hood release lever.
    I didn't care to lay on the ground and watch how he did it, but he got it in a matter of minutes. We did look at the way my hood release worked though, so he had an idea of what needed to be pushed.
    Also you might need to remove your front bumper... probably wouldn't if you had a SMIC.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    For future, just install a trickle charger with the plug in tucked into the corner of the bumper. Or just have the quick disconnects available.
    http://www.walmart.com/ip/Schumacher...ainer/15140206
    Feb 28 2005
    Tempe
    I'm confused.
    We've given like 3 different variables to effectively open the hood.
    Sep 30 2015
    Smash the fuckin window and pop that hood open
    Dec 05 2007
    I'm confused.
    Read the initial post. Title and first sentence in post. Still confused?!?! Or how I mentioned I can get into the car no problem!?!?
    Either way, still did not get to it. I have another car and my work van runs most my errands, like food shopping before going home yesterday after work. Hence, why battery is dead in the first place.
    Apr 02 2013
    above top secret
    This will surely work for trickle charging but what is the odds of burning the fuse/wire when you connect the power supply to a flat battery?
    Feb 28 2005
    Tempe
    Quote Originally Posted by maxiz1 View Post
    10-12G wire, 30 amp fuse
