Hey guys, just wondering if this is a problem others have run into...
I have a hard time turning the key in the ignition lock (2008 B7 manual). Tried with both keys and its the same. I've seen this in older VW's and the ignition cylinder was the culprit. Is this an issue that you guys have seen on B7's? I can't seem to find anything regarding this in the wiki.
Thanks for any help guys
*Update for those interested
I talked to a buddy of mine who is a VW mechanic. He says VW's and Audi's have this as a common problem. Two things can cause this, which are the following:
The ignition cylinder itself, which gets worn out and makes turning the key hard (not lube related). Cost of replacement is fairly cheap
The ignition switch (mechanical portion) which is on the end of the lock cylinder, which also wears and eventually becomes defective. Cost: quite expensive (few hundred bucks)
He says that in about 20% of cases it's the ignition cylinder and in 80% of cases it's the ignition switch behind the cylinder. I've ordered the cylinder just because it's a cheap first step. If it doesn't resolve my issue i'll look into changing the ignition switch and keep you guys posted
