Originally Posted by
Vmax211
I have a set of the eBay reps on my S6 as winter wheels. It didn't get out much last winter, so the wheels are still perfect.
I didn't weigh them, but expect that they would be heavier and not as strong as the stockers. But for the winter use my car sees, they have been perfect so far.
No balancing problems- they balanced up fine, and higher speeds don't reveal any vibrations.
Your replica wheels are more likely lighter than your stock wheels. Replicas wheels are designed to look good but are produced as low cost as possible to maximize profit. Usually through gravity cast molds. They are designed for mass fitment and usually not tested for specific cars. Some don't even test at all....
OEM wheels are designed with safety and durability on the checklist. Your stock wheels are also tested specifically on your model. They're usually "heavier" when compared to performance aftermarket wheels. You can push your oem wheels as far as your car can handle and it shouldn't fail.
Replica wheels are usually lighter so you should notice a performance increase in accelleration, but aren't necessarily durable enough to withstand impact or stress.
If you're just a normal driver, can handle pothole/curbs, and occasionally like to accelerate in a straight line then replica wheels are absolutely fine for most.
Of course, there are wheel manufacturers that combine light weight, durability, safety, performance, etc. These wheels are usually much more expensive comparatively. Then again, you're also paying them for the time they put into R&D, safety/durability testing, etc that replica company don't usually have as an overhead.
Replica wheels are perfectly fine if you're just a normal driver that can avoid potholes/curbs and occasionally like to accelerate fast in a straight line. If you're an aspiring weekend track warrior then I wouldn't go this route.
