Results 1 to 21 of 21
    Apr 11 2016
    Phoenix, Arizona
    Got the PLM Heat Exchanger installed today!
    I decided to pull the plug and get my heat exchanger installed today! I live in Arizona so it's been 108 out lately and my car has been hitting 175 IAT on just a normal cruise. On the cruise home it was 108 outside, and my IAT was 129.
    **IAT was read through a wifi obd2 reader with OBD Fusion**
    21 RS6 Stage 2
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    I wish I would've done before and after logs. From recent logs the plm does it job and IATs recover quickly
    Edit: man I gotta start proofreading lol
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice!!! Can't wait to get mine so I can install both my crank pulley and hx at the same time!!
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    awesome!
    Nov 28 2015
    Montreal, QC
    I wouldn've painted that core black.. in fact, why dont plm do it from factory ? i mean.. who really want a silver core ? lol
    S4 B8.5 no track, just enjoying spirited driving.
    Apr 27 2015
    canada
    for a point of reference because I always see that temp posted w/ cold fronts - what would that engine coolant temp and iat read without a coldfront in similar conditions (close estimation plz)?
    Does this keep things cooler all the time, even when idling over stock set up or just that it cools down *quicker* than stock when the car is inhaling air at speed?
    May 31 2014
    Alabama
    Interested in this.
    In the high climate I'm in, temperatures are 100+ every day as well. Engine temps can get up to 225F (normally sits around 200F). It would be nice to cool that down a bit.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Can't wait to put mine in!
    Keep posting updated number if you are able.
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Oct 06 2014
    Cleveland, OH
    So you paid a shop to install it? If I may ask, how much was that labor? (I don't have any service position bolts?)
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Thurston View Post
    He says in the first post, he was seeing about 175 deg IATs.
    This will both keep it cooler and allow it to recover quicker. In all reality you are just adding a bigger HE and more coolant capacity. (Takes longer to heat up because of the capacity and cools down quicker because of the larger HE. Win win)
    Quote Originally Posted by SR7D1 View Post
    Most shops for the AWE system where charging 3-5 hours for an install including the pump. Since this does not have the pump it should be a bit less. So, 3-4 hours * your shop rate.
    Geoff
    Apr 11 2016
    Phoenix, Arizona
    Driving normally in traffic in "Auto Mode" not Dynamic, I was seeing 160-170 IAT normally. This morning driving to work it was 102 out and my intake air temp was 108F all the way to work with 194F coolant temp. Idle temps before in 100+ degree weather were over 170F and today they were about 130F. Definitely a huge improvement.
    Quote Originally Posted by waxxonMTL View Post
    Yes I agree completely. I wish I just had the shop paint it while they were installing it :/
    Quote Originally Posted by AudiS4SD View Post
    Interested in this.
    Last night I saw temps of 195 ish on average. I saw 205ish before the cooler.
    I paid $450 for the install and it took about 4 hours. All I did was bring them the boxes from PLM exactly how they came, and my car. That's it :)
    21 RS6 Stage 2
    Apr 11 2016
    Phoenix, Arizona
    So after picking my car up from the shop my car warned me that my coolant was low. I pulled into the gas station and opened the hood and it was almost completely out. The shop told me they added over 1 gallon of the coolant/water mix, but after driving it a little hard on the way home I guess it burped more air out. I filled it with an additional gallon and it seemed to be fine last night. I drove to work today and checked it when I got here and it was still at the line where I filled it.
    21 RS6 Stage 2
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Quote Originally Posted by speedy0339 View Post
    That's a great point Speedy. I'll be looking for that for sure when I get one and have it installed.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Oct 20 2014
    Pittsburgh, PA
    Does painting it black affect the cooling ability at all? I would think so, but maybe someone would have more data than opinion like me lol.
    Edit - I probably won't paint mine either tbh...
    Previous:
    Oct 20 2014
    Pittsburgh, PA
    dangit, forgot to ask a question - Speedy - is there anyone out in your area with one of the other systems like AWE coldfronts to compare? I'd be curious to see a comparison in same environment settings what the relative temps would be!
    Previous:
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Quote Originally Posted by jokingjimmy View Post
    If you use the correct type of paint it should improve cooling (minimally)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Apr 11 2016
    Phoenix, Arizona
    There is someone else in the forum that painted it black. I don't think it will affect anything but I can't confirm anything. I think it would look better black on my car because the car is blacked out.
    I'm sure there are other people in Arizona with it, but I don't know anyone. I will have to look out for other S4's at the car meets I go to. At the same time though--the AWE cold front is twice the price. The AMS is almost 2.5x the price. So I feel like this is plenty for the price you're paying. I live in Arizona so I feel like my conditions will be hotter than most others, and my car is running super cool.
    21 RS6 Stage 2
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by xpoweruk View Post
    Rustoleum, knew it.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Apr 05 2016
    Portland, OR
    This.
    I will be painting my AWE unit and the protective screen the same color black once it arrives. (Don't want the silver visible through the RS grille )
    Geoff
    Feb 05 2016
    UK
    Apr 11 2016
    Phoenix, Arizona
    Quote Originally Posted by whiped View Post
    This.
    I do want to paint mine black as well. However, it does look super aggressive with the giant heat exchanger showing through. I had a friend drive my car so I could see what it looks like from outside the car and it looks menacing. If you want to make your car more sleeper though, I would definitely recommend painting it.
    21 RS6 Stage 2
