Results 1 to 20 of 20
    Active Member One Ring GBODT's Avatar
    Dec 10 2015
    Boston
    AUX/IPOD Cable Question
    Hey guys, i just picked up an 05.5 B7 A4 as my daily driver and i noticed that the previous owner installed an aftermarket AUX/IPOD adapter in the glovebox. The only problem is i cant for the life of me figure out how to use it. I've tried just about every button and combo on the stock stereo and still can not get it to work. Maybe someone on here can help identify it or tell me how to use it? I attached a picture of what it looks like. Its a 3 wire cable with an old ipod connector, usb input, and aux cable.
    2010 R8 V10: 6spd, TopSpeed Pro1 Exhaust
    2006 A4 2.0T: Stock 6spd
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Try hit cd? That's how most of them work
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Dec 10 2015
    Boston
    I've tried that. I believe mine has an in dash 6 disc changer and I tried loading each individual disc slot, but still nothing. Im pretty confused by it.
    Deactivated Four Rings
    Jun 23 2011
    Push CD twice and it will switch to the CD changer and it should work. I have the OEM Audi Ipod adapter and that is how mine works.
    Dec 10 2015
    Boston
    When I push it twice it just says "no CD"
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    How is it connected in the glovebox? To the OEM hookup?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 10 2015
    Boston
    The wires go through the back of the glovebox and can be seen running to the back of the stereo through the little crack on the left side of the glove box
    [IMG][/IMG]
    Oct 31 2014
    NH
    Got the tools to pull the stereo?
    2014 Audi S4 - 6MT
    2000 Audi A4
    Dec 10 2015
    Boston
    Unfortunately not, I was hoping there was just something I was missing with using it but it looks like I'm gonna have to pull it out and see what's going on.
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Send the PO a text: How does the AUX work?
    Okay.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Dec 10 2015
    Boston
    Bought it from a dealer so i'm not sure who the PO was. And I wish I could tell you how the AUX works haha, I have no idea
    Dec 23 2011
    Try the satellite radio option. That's how mine was setup
    Dec 10 2015
    Boston
    Just tried that now, doesn't seem to work either. Thanks everyone for the help so far btw
    Dec 23 2011
    I'd buy a set of radio keys online (they are cheap) and pull the radio. It's fairly straightforward and you should be able to see how it's connected or at least what brand it is.
    Dec 10 2015
    Boston
    Thanks, I will order some today.
    Jun 27 2011
    That's a symphony 2 so it doesn't have any real provision for Aux input like symphony 2+.
    My old b6 had one that interfaced through the SAT radio function. Could be yours is disabled or broken. Given that yours has usb, iPod and 3.5mm jack, my guess is that it's a "dumb" converter and uses the 3.5mm jack for audio and the iPod and usb plugs are simply for 5V power for the phone/device.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 10 2015
    Boston
    Cool thanks for the info. Yea i'm guessing that since nothing anybody has suggested is working, it must be broken/disabled somehow. I guess we'll see when the tools I ordered come in.
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    What comes up when you hit CD once?
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Dec 10 2015
    Boston
    It just says "No CD"
    Dec 10 2015
    Boston
    UPDATE:
    So I finally got the tools needed to find pull the radio out and this is what I find. A "parrot blue box MKi9200", anyone else have one of these? After searching online it seems that these are supposed to come with some sort of handheld bluetooth reading device, which my car did not come with. Could this be the reason why the cables are not working?
