Results 1 to 25 of 25
    Jun 02 2016
    South Florida
    VMR V710 19x9.5 vs 19x8.5
    So I've decided on buying V710s... Im wondering the pros and cons of each width.
    I've read a couple threads that asked a similar question and most guys liked the 19x9.5 better for aesthetic reasons.
    But I wanted to add that I spoke to a wheel vendor and he said to go with 19x8.5 because the 19x9.5 would poke out and rub - and that I would have to do fender/tire modification.
    Can anyone comment on this? How noticeably different is the extra width?
    For reference I'm also putting on coils
    Jan 09 2008
    Winnipeg
    What offsets are you trying to compare? What tire are you planning on running? There is a great sticky thread about wheel fitment that you should look through as there are a lot of pics of various set-up so you should even be able to find examples of what you are looking for. Oh and also your suspension will play a roll in the look so if you are lowered then the wheels will tuck more. Be mindful of that when looking at others pic/posts so you know exactly what you are looking at.
    Established Member Two Rings Mr_Hooper's Avatar
    Jun 04 2016
    Littleton, CO
    I'll get this started, as I was just having my own discussion in my head when I ordered wheels a couple weeks back. With 9.5, you'll have better road grip, as there's greater surface area gripping the road. Your wheels will also appear more concave (can also be completely based on design too), which some people like. Some people prefer a more flush look.
    From what I've read, you'll have slightly better maneuverability with 8.5's, whereas the trade off for wider tires is better grip/traction. I ended up going with 8.5's, so I can't comment on the difference. Just the due diligence I did on my end.
    2021 S4 Premium Plus Quantum Grey
    SOLD:2016 A6 Moonlight Blue
    SOLD:2013 S4 Premium Plus Estoril Blue
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I have no issues rubbing on my setup. I run 255's however so if you get 265's I think I heard it will rub.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Established Member Two Rings audidude86's Avatar
    Mar 18 2009
    junk
    goldsboro NC
    i have these wheels in a staggered set up 19x8.5 in the front and 19x9.5 in the rear I run 235/35/19's all the way around, this is on a b6 and 19x9.5 sit flush with the fender and the front could use about 10mm spacers or bit smaller. I have no complaints about the way the wheels sit, my car is very low and I have no rubbing in the back and I have about an inch of clearance between the rim and the fender. I rub on the front sometimes but it's because the tires that I ordered, I should of ordered 235/25's for the front to give it the stretch that the rear has. I would put pics up but I'm out of town and I don't have any pics with me. As for the with they are pretty wide and it looks great from the back. I rolled the fenders myself but honestly didn't really have to and I also had to cut a section of the liner in the rear wells just so I could sit so low. But if you want a conservative drop I don't think you're going to have to do any of this.
    this is the site that I used to compare the sizes in tires and so on and I actually took measurements myself to make sure that I getting all the numbers correct. http://www.willtheyfit.com/#isPage=1
    Jun 02 2016
    South Florida
    I'm working almost 70 hours a week and admittedly know nothing about wheel fitment. Apologies in advance - if it seems like I'm trying to take the shortcut to learning this stuff, it's because I am.
    That wheel/tire thread would be helpful I'm sure; I'll see if I can learn what I need to through there.
    I live in South Florida so I think I could get away with pretty thin tires. I want to lower the car in the front as much as possible without having to do camber, huge fender mods, anything significant etc. not sure about spacers. I want to leave the back a little taller to get that rake
    Jun 02 2016
    South Florida
    quick google search for reference of approximately what i'm going for. not sure how realistic it is to achieve that kind of stance without significant upgrades. doesnt have to be quite that low
    Quote Originally Posted by eurotic View Post
    ¯\_(ツ)_/¯
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    if you want rub free on coils do not get the 9.5
    to be conservative go with 19x8.5 et45, should be rub free with your drop.
    I ran vmr 710's in 19x9.5 et33 and it did not rub at the stock ride height. Now running 19x9.5 et35 lowered and it only will rub in the rear if I hit a really really big bump above 40mph. But for how I use my car (drag racing) it does not rub. I wouldn't run the 9.5's if I had to do any high speed cornering
    Established Member Two Rings pinpointsnipe's Avatar
    Sep 24 2011
    Fairfax VA
    Granted its an 8V A3 - you can read my specific thread about the wheels here - http://www.audizine.com/forum/showth...0-Review-8V-A3
    Im running a 19x8.5 et 35 with 235/35/19s. Fits perfectly flush for my car with KW V1 Coils. Keep in mind this is a smaller car - but i do get occasional rubbing in the front on very aggressive turns or when all 4 seats are being used in the car. Theres probably about a half inch gap front and back, and the fenders have not been rolled.
    I would assume you could run the 9.5s no problem, but thats an assumption and I do not know nearly as much about the specs on this platform
    2015 A3 8V - Brilliant Black
    Jun 02 2016
    South Florida
    Quote Originally Posted by mrmomo313 View Post
    did you mean you're now running 19x8.5 lowered? if you're running 19x9.5 lowered then why are you recommending against your set up? I guess occasional rubbing is fine, just nothing too detrimental
    - - - Updated - - -
    Hey guys thank you all for your replies. incredibly helpful
    Oct 27 2010
    Michigan
    Quote Originally Posted by kcbar58 View Post
    - - - Updated - - -
    Well, I recommended against it because your OP said no rubbing lol. But, if a little is fine then go for it. I don't think you'll like it though if you plan to do hard cornering with the car. It's perfect for drag racing though
    Currently 19x9.5 et35 lowered on HR coils
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    With the V710, you're looking at either 19x9.5" ET45 or 19x8.5" ET35. As far as the wheel fitment, both will fit fine with no rubbing, etc.
    I think it just comes down to a matter of looks and what you prefer. If you don't plan to lower your car, the 8.5" wheel is a better option with 255/35 tires. Less stretch on the tire looks a lot better at stock height. I don't typically recommend over a 9" wheel at stock height and the standard 255/35 tires.
    If you are going to lower your car, the slightly more aggressive look of the 9.5" wheel and stretched tire can look just fine if that is what you are after. In this case, as long as you are OK with the stretched tire and less protection for the wheel, go for it. The 9.5" ET45 would also allow you to go up to a 265/35 tire for a meatier look too....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Oct 27 2010
    Michigan
    Quote Originally Posted by jran76 View Post
    Enter the wheel fitment guru. I'd follow this advice.
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    I've seen this retro fit. The 19" X 8.5" ET35 is a VERY common wheel/offset on the B7. I actually sold my old B7 wheels (that size and centerbore) to a B8S4 guy. In my opinion, the wheel just didn't hit right on the B8. It REALLY needed a minimum of a 5-8mm spacer to make it look right with that width.
    Now, on the other hand, the 19X9.5 with an ET45 will be nailed pretty close, and shouldn't rub.
    Right now, I run a 19X9.5 with an ET40, and run a 255/35 tire. The amount of stretch allows me to get away with the width/offset. With a 19X9.5 at ET45, you could probably get away with a 265, and run more "meat," if you wanted too...
    -DL
    EDIT: whoever the "vendor" was that said 19X9.5 would rub on a B8 and would require fender modification, was dead on the nuts WRONG.
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Jun 02 2016
    South Florida
    Perfect response. Thanks a ton. I'm gonna go with the 9.5" width. What size tires would be best if I'm trying to make it about as low as possible without camber/significant fender modification? (If that really even has anything to do with it) 255/35?
    Again apologies, I haven't found the time to browse through the wheel fitment thread. I'm sure this has been repeated ad naseum but I might as well ask since the thread is already up
    - - - Updated - - -
    Nvm just saw above post. Thank you everyone
    Apr 04 2015
    United States
    19x9.5 et35
    255/35/19
    Zero rub
    Sep 10 2008
    ashburn, va
    @rwtzero what wheel is that? And where was it purchased?
    Jun 02 2016
    South Florida
    Hnnnnng
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    i ran VMR 19x9.5 et 35 on 255 PSS's with no rub on H&R OE's
    i now run 19x8.5 et 35 on 255 PSS's with no rub on H&R OE's
    i miss the stanced look of the VMR's but happy the stretched-tire look is gone. a worthy trade off in my opinion.
    thats just my 2 cents!
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Apr 04 2015
    United States
    Quote Originally Posted by alwaysOntheGo View Post
    http://www.velocitymotoring.com/wheels/v706/
    VMR V706: 19x9.5 ET35
    Call direct, Tracy at VMR, super good dude, and I absolutely LOVE the way they look on the car! The only one thing that I think I'm going to do is have them polished over the winter.
    Sep 10 2008
    ashburn, va
    Thanks a lot!
    Established Member Two Rings kirbs69's Avatar
    Mar 19 2014
    DFW
    Quote Originally Posted by KRp220 View Post
    Did you need to run spacers with 19x9.5 et35 for the brakes or do they clear?
    Current: Stage 1+ | B8 2009 Brilliant Black A4 Avant | 2.0T | 6MT
    Previous: Stage 2+ | B5.5 2001 Laser Silver A4 Avant | 1.8T | 5MT | Stage 0 | B8 2011 Meteor Grey S4 | 3.0T | 6MT | Stage 2 | B7 2006 Dolphin Grey A4 Avant | 2.0T | 6MT
    Aug 23 2011
    NH
    Quote Originally Posted by kirbs69 View Post
    No, they fit fine without spacers
    Mar 19 2014
    DFW
    Thx!!
    Active Member Two Rings Rafuse2007's Avatar
    May 24 2020
    1990 Iroc Camaro
    Nova Scotia, Canada
    My car looks similar to the one in your pic
    Attachment 209379Attachment 209380
    I run VMR710 gunmetal 19x8.5 et 33 with 225/35/19 rubber small stearch lowered on raceland coilers can
