Results 1 to 27 of 27
    Established Member Two Rings Probmxstyle's Avatar
    Dec 19 2015
    Dealership Recommendation?
    What dealership is everyone using for their service needs? I am pretty close to Audi Silver Spring, but if there is another dealer that is recommended, I would love to hear your experiences. Also, if the dealer if mod friendly, that would be a plus. I am currently stock but plan on doing some upgrades.
    Nov 13 2011
    b7 s4 avant
    Silver Spring is generally the dealer of choice around here
    I drive a truck now.
    May 20 2010
    x2
    Silver Spring has never treated me wrong. In my experience the service advisors tend to be on the enthusiast side, and don't mind seeing modded cars (though be careful after you do mod in case they need to scan your engine). The techs, similarly, like asking about the cars. Service-wise, I've had Phil, Aaron, and Pete before, and they've all been good.
    Forum Moderator Four Rings DirtD1ver's Avatar
    Feb 20 2013
    2017 Allroad, 2020 Q7
    MD
    x3 Definitely Silver Spring
    Don - Forum Moderator, Audizine
    Current: 2017 Allroad Prestige Manhattan Grey
    Previous:2013 Allroad Prestige Monsoon Grey
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    DON'T GO TO Hunt Valley. Bad experiences there both times I took it in for service.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    x2
    I have to agree. The staff at Silver Spring is great! The service advisors are very helpful and the girls are cute. The parts guys are really helpful. Finally the techs are cool. I talked with the shop foreman when I went there for a MAF sensor and he is pretty well versed in the mods for the RS4 that he has. If you live close to Silver Spring then there should be no question.
    However some of us live in VA and I like Audi Arlington for VA owners that don't want to make the trip up to Silver Spring.
    Veteran Member Three Rings adamRS's Avatar
    Jul 09 2009
    Ashburn, VA
    Silver Spring for sure. I make the drive from Ashburn, VA just to go there - they are that good.
    Quote Originally Posted by JimmyBones View Post
    That's my old RS 4 that Bruno has, it's nice to see it when he has it there.
    2018 RS 3 - Daytona Gray | IG: @adam__rs
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    Well I guess that answers my question about Hunt Valley.....I need my 45k mile service done. Anyone have experience with Audi in Wilmington, DE? They are the next closest dealership to me. Or, do I even need to take it to the dealer? I have a 2013 CPO, so there is still some of the original warranty left. I'm worried if I do the work or take it to an independent mechanic, the CPO warranty could be voided....thoughts?
    1997 BMW M3
    CES Stage IV (651rwhp/615rwtq @ 24 psi)
    2020 S6
    Premium Plus, Black optic, performance exhaust
    2013 Audi A4 (sold)
    Prestige package, S-Line, 6-speed |IE Stage 2 | IE Performance Downpipe | S4 exhaust swap | ECS Luft-Technik intake | ECS Luft-Technik FMIC | RS4 grille | ECS SSK | ECS Trans/Diff Inserts |
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    ASS
    Eurosport Tuning at it's Finest
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by BMWManiac View Post
    If you or an independent shop/mechanic do the maintenance with parts that meet or exceed the OEM specs then you are fine for keeping the little bit of CPO warranty that you have left.
    That is actually what the Moss vs Magnuson laws were writen for. A lot of the tuning companies quote the Moss vs Magnuson laws out of context for modifications but they were meant for maintenance because some OEM manufacturers were voiding warranties over stupid stuff like OE engine oil filters instead of them being OEM.
    If you are located in Aberdeen MD then NGP is probably only a few minutes away from you. I would take it to NGP if you don't want to do it yourself. Otherwise Audi Silver Spring is like a hour away depending on traffic if you want a dealership to do the 45K service. The 45K service on a 2013 A4 is basically just an engine oil and filter change along with the normal small stuff like checking/topping off the fluids, setting tire pressure, and reseting the service reminder.
    EDIT: I just noticed that your 2013 A4 is a manual. That is cool! I always enjoyed when a manual B8/8.5 A4 would come in because they are peppy little cars with a stick. The slush box automatics tended to put me to sleep on test drives.
    Jan 19 2016
    Orlando, FL
    Yes, save the manuals!
    NGP is about 2 miles from my house.....I just wasn't sure if it had to be the Audi dealer servicing through the warranty/CPO period....should warranty issues happen in the future, could they point to me and say "prove you did the 45k mile maintenance." If I did it, besides buying the parts, how could I prove it?
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
    Apr 03 2010
    Northern Virginia
    Keep your receipts for the oil and filter along with a record of of the date and mileage when it was done and you are good to go. Make sure that you use an engine oil that meets the correct VW spec. Should be VW 502 for your car so the normal Mobil 1 0W-40, Castrol Edge Euro blend 5W-40, Pennsoil Platinum 5W-40, Lubo-Moly 5W-40, or Motul 5W-40 is good to go. In my experience both the B7 2.0T FSI and the B8/8.5 2.0 TFSI engines really like the Lubo-Moly engine oil. That oil tends to cut down on the oil consumption. Which helps because both 2.0 engines are a bit thirsty on engine oil.
    Established Member Two Rings mrw's Avatar
    Aug 20 2008
    RS5 Cab sold, 2009 A4 Avant 3.0 6mt swap-sold, 2021 Jeep 392, 77 Datsun 280Z V8 2017 S6-sold
    Delaware
    Audi Wilmington has been great for me for years. AVAutoworx is about 10 minutes south of Wilmington (10 minutes North of the DE MD state line and also does nice work at reasonable prices. The owner is a former Audi Tech and has Saturday hours for those who want to come in for small repairs/oil changes while you wait.
    Active Member Two Rings Myriad's Avatar
    Apr 03 2016
    Delaware
    Just bought my Audi from Wilm (live in DE). Entire team there is awesome and definitely on the enthusiast side. Highly recommend them if it's reasonably close. Jeremy was great last time I went for service.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    #JimmyBonesKnows
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by Probmxstyle View Post
    Audi of Silver Spring is super cool and even if you are modded they will give you a chance to flash back to stock... Im friends with once of the SA's over there... They are all good peeps..
    Dec 18 2014
    DMV
    Quote Originally Posted by HeymyA4 View Post
    Yea, Audi Silver Spring is good peeps. Who do you know over there?
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Senior Member Two Rings Matthew_VA's Avatar
    Jul 05 2016
    Alexandria, VA
    Had a question. Does anyone have experience with Audi of Arlington and mods? I wanted to do a few basic mods (RS4 grille, Transmission Mount Bushing Insert, & Drivetrain stabilizer, maybe rear sway bar) but don't want to get TD1 flagged. Would Audi of Arlington give me grief for these types of mods? I have about 20 months left on a CPO extended warrany.
    Mar 02 2013
    DC
    Quote Originally Posted by Matthew_VA View Post
    Just. Go. To. ASS.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    Cant speak to Arlington, but if you want to stay in VA, then you can try Chantilly. I had a poor experience with them the first time, but their service manager contacted me right away and talked a good talk, so I gave them a second chance and they were fine the second time. My SA there has a badass modified B6 S4 Avant and the manager also drives a modded car, so you can talk to them and they wont TD1 you unless they have no choice due to computer. I'm lowered and had no issues, just tell them. Brian Kennedy is my SA.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Jan 19 2016
    Orlando, FL
    Nothing but great things to say about Audi of Wilmington.....got me in and out for the 45k mile maintenance in about an hour. Also will replace my start/stop button under warranty!
    1997 BMW M3
    2020 S6
    2013 Audi A4 (sold)
    Jul 31 2016
    SC PA
    Another positive experience for Audi Wilmington. I re-entered the VAG family this past weekend, picking up a CPO SQ5 Prestige from Wilmington. They were great to deal with on the sales side. Car was missing the Audi Protection package mats from the original window sticker, they ordered them for me and shipped them to me. That was a couple days *AFTER* the deal was done, and I realized what the protection package included.
    May 20 2010
    I had a great experience a week and some ago at Audi Turnersville, in Turnersville NJ. My C5 allroad had TERRIBLE alignment, even before replacing the control arms, etc. Used their online chat function to schedule up the appointment, and they were very friendly (even when I had to reschedule). When I arrived, drove right into the center, got out and spoke to the service advisor. One of my rear calipers was sticking so I made sure they didn't actuate the parking brake--and they didn't the entire time. While they couldn't loan me a car, they did drive me down the road to grab some breakfast (Q5) and picked me up (B9 A4). Nice waiting area and soon after the car was done, with both a multipoint inspection and the alignment results. Great, friendly people there, and alignment was definitely done right!
    Established Member Two Rings sandros1's Avatar
    Oct 01 2012
    2007 RS4 - Daytona Grey, 2021 Etron, 2021 Volvo XC40 Recharge, 2019 F250 Lariat, 1960 Ford F-100
    NorCal
    I bought a Q5 from Audi Wilmington last night to add to the stable. Steve and Joe in the sales department were outstanding. Took the time to answer my wife's questions until past 7pm. Very much appreciated them.
    -----Nothing Witty-----
    2007 RS4 - Daytona Grey - Mine
    2021 - Etron, Catalunya Red - Hers
    2021 Volvo XC40 Recharge, Sage Green - my daily
    2019 Ford F-250 Lariat
    2009 Airstream Interstate
    2010 Audi A4 - The Nanny Car
    Senior Member Three Rings Prh's Avatar
    Mar 28 2015
    Q5, Land Cruiser 200, John Deere
    Northern VA
    Quote Originally Posted by Race Shooter View Post
    I had the same experience with Chantilly on my first visit. On the second visit, I met with Matt the service manager who is a really good guy. I echo what Race Shooter says.
    2014 S6 Black - APR Stage 2 ECU+TCU, APR DP, AWE Exhaust, HRE-FF01, Black Optics, P3, ALP, Escort Redline 360, Blackvue, 034, carbon diffuser, carbon mirror covers, Roc-Euro intake, ECS Tuning sways, H&R lowering module
    Established Member Two Rings AWDfreak's Avatar
    Jun 02 2016
    I had a good experience with Audi of Tysons. My local Audi buds use S2 Dynamics (Rockville) for all post-warranty work.
    2012 B8 S5 Prestige 4.2, 6MT, Phantom Black/Black
    Mar 21 2015
    Quote Originally Posted by Party_Marty View Post
    Me too, what a joke
