Results 1 to 8 of 8
    Senior Member Two Rings RSFourMe's Avatar
    Apr 24 2013
    07 Q7 4.2, 73 VW Bus, GONE: 73 VW Bus, 1996 Audi Cabriolet, 05 Cayenne S, 2000 740i MSport
    Modesto, CA
    MMI/stereo Not working 2007 Q7
    My radio stopped working a few weeks ago. The splash screen will come on (with a weird red line running top-to-bottom on the far left side) and then go black. The splash screen will only come on once every 5 minutes or so...if I push the power button again after it turns off, it will not come back on. But if I wait a few minutes it will splash again...very strange!
    Reverse camera doesn't work, no sound, no other input has any affect, nothing....any ideas?
    08 RS-4 Cabriolet- Phantom Blk: k40 Calibre, JHM Stage IV Kevlar Clutch with LWFW, Solid Short-Shifter, Linkage and Bushing, CD Changer delete- Dension Aux adapter mated to Blackberry BT/NFC Stereo adapter.....to be continued...
    Active Member One Ring Bmorr33's Avatar
    Jul 01 2016
    New York City
    The 07 Q7 has a manufacture flaw. The drainage from the sunroof goes to the 4 corners of your vehicle through tubes. Unfortunately Audi didn't think this through when they placed one of the drainage tubes directly beside all the electrical components in the rear passenger side panel behind the third row seat. Your Bose amp and other electrical components are located there and most likely the moisture has caused water damage. This happened to me, I speak from experience. If so, the amp may need to be replaced. The drainage tubes regardless if thats the problem or not need to be replaced and sealed properly because if it doesn't happen now it'll happen later.
    Veteran Member Three Rings zerokiller698's Avatar
    Nov 11 2011
    NKY
    Having bad MMI controls will do that too. I had this issue when soda got spilled into my MMI controls. PITA.
    If nothing bad has happen to the MMI controls, check the amp, and everything else in the back right.
    Current: 07' Q7, B6 S4
    Past: B5 1.8t, B6 S4, MK2 VR6
    Instagram: Zerokiller698
    Apr 24 2013
    Modesto, CA
    Quote Originally Posted by zerokiller698 View Post
    I sorta think this may be the problem. The am/fm button is pretty sticky....
    But I'll go and check the electronics in the back as well.
    Thanks guys
    Nov 11 2011
    NKY
    if the button sticks, separate the buttons from the circuit board and use a little bit of soapy water the run little bits of it around the buttons.
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Quote Originally Posted by Bmorr33 View Post
    Feel like this is happening to me. Also noticed some water on passenger floor mat. Thing the drains are clogged. Any ideas on where and how best to clean the drains?
    '13 S6
    Nov 03 2016
    anyone have pics of the right back area where the water damage occurs?
    thanks
    07 Q7 3.6L 140k
    03 Crown Vic 200k
    Daughters 02 GMC Envoy 250k
    Feb 25 2015
    Ontario
    Quote Originally Posted by bspurloc View Post
    thanks
    https://www.youtube.com/watch?v=CalYXsMEmqo
