Results 1 to 17 of 17
    Veteran Member Four Rings impulse's Avatar
    Mar 06 2014
    2006 B7 A4 - 2.7t Swapped. 2008 8P A3 - 3.2L VR6
    Connecticut
    Steering Wheel Controls Not Working
    Hi all,
    My steering wheel controls such as the volume control and track change function don't work. Any insight on how to fix this? I looked in the fuse box and saw nothing. Is there an under dash relay that controls this?
    Thanks in advance
    Joe
    @jg_iii_
    Check out my progression thread - http://www.audizine.com/forum/showth...Picture-Heavy)
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Quote Originally Posted by impulse View Post
    Hi all,
    Thanks in advance
    did you remove your steering wheel by any chance and moved the clockspring with your hand?
    Ivan
    Mar 06 2014
    Connecticut
    I did not remove the steering wheel. What happened leading up to it was this
    I was tapping into the power source underneath the steering wheel to run a power wire for my compressor. Did that and when I was hooking it up my battery was still connected and I kept hearing the speakers make noise. Disconnected my battery and the controls didn't work anymore
    Joe
    @jg_iii_
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    I'm curious about this as well. However, my volume toggle works but the track change (left side) doesn't. I also noticed at night the left side of my steering wheel when lit is very dim compared to the volume switch.
    Mar 06 2014
    Connecticut
    Edit: didn't work anymore after hooking the battery back up
    Sorry I thought I edited my original post
    Joe
    @jg_iii_
    Aug 19 2013
    Miami
    Quote Originally Posted by QuattriumMT6 View Post
    that happen to me when i moved my clock spring out of the position it sits. removed the wheel and kind of played with it and got it ride and it was lit again not dim. but that's just what i did idk if that's your problem.
    Ivan
    Oct 24 2015
    Perth, WA
    Same issue for me. Interested if anyone has a fix.
    My respray thread
    Aug 24 2013
    Stockton, CA
    Quote Originally Posted by Okedokey View Post
    Sadly for the past year+ I've just learned to live with it. Hoping the solution to fix it is rather simple and/or cheap. Otherwise I'll just continue to extend my right arm to reach over to the center console and switch stations.
    Mar 06 2014
    Connecticut
    Bump
    Joe
    @jg_iii_
    Oct 24 2015
    Perth, WA
    To assist in fault finding, I have the aftermarket 7" Erisin 2028AM stereo. When I first installed it, the controls worked fine. I messed around with settings and then decided to do a factory reset. This resulted in the car not communicating with stereo properly, in particular the mfsw controls. VCDS detects the steering controls, however the radio no longer is detected.
    Any clues?
    My respray thread
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    I've never touched my steering wheel and this happened to me too once last month...Both sides light up and everything but actually never did anything...Came to a stop, turned car off and on, and everything was back to normal
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Mar 06 2014
    Connecticut
    Bump. Same scenario as BenMTL except it never came back on
    Joe
    @jg_iii_
    Jun 28 2016
    RAMSTEIN AB Germany
    At the risk of sounding stupid, what does VCDS stand for? I'm having an issue with my SWC's also. I am installing a new Aftermarket HU, with a built-in CAN-BUS decoder. However, it still has wires out the back for SWC's, Illumination, ACC, Reverse, Grnd. I was under the impression that all of those functions are controlled by your CAN-BUS system, but maybe I am mistaken. Does anyone know or have seen where the SWC wires go once they leave the steering wheel column?
    Aug 19 2013
    Miami
    Guys no one knows a fix. it doesn't happen often or is an issue. like i said it happend to me and all i did was remove my wheel and turned the clockspring not a full turn just played with it and that's it it got fix. is it a fix? no is not but i'm saying try it to see what happens.
    Ivan
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by Aviator_35 View Post
    VAG-COM Diagnostic Software. Everything you need to know is here: http://www.ross-tech.com/
    Feb 24 2004
    Minneapolis
    I have both left and right steering wheel control units if anyone is in the market.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Active Member One Ring Bigunit's Avatar
    Jul 04 2020
    Va
    I have a 2004 Audi A8 , I had the dealership a long time ago install a new MMI control module head , but ever since then the steering wheel buttons do not work but when I go in with the VCDS software and check everything out and test the buttons all the buttons test are good stealing angle sensor is good rotation is good and it seems like all the programming is good so why do I see all the buttons working with my VCDS software but the buttons don't work for the car stereo or voice speech activation , if anyone could help me on this I would much appreciate it.
