Results 1 to 36 of 36
    Mar 08 2010
    AudiLand
    C7.5 APR tuned RS6/7 cyl5 misfire
    Hi,
    Has anyone with c7.5 APR tuned RS6/7 had a misfire on cyl 5. I had it happen twice. I was hitting the kick down switch both times. It's happened 500miles apart. I'm confused as the car is fine otherwise.
    Tx
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    Quote Originally Posted by OOOO SSSS View Post
    Hi,
    My RS7 is a C7, but when I was stage 1 I had this happen quite often, especially when I got on the car before it had time to reach optimal operating temperature. I just used the iPhone app to clear it and never suffered any adverse effects otherwise. Interestingly, ever since I have been stage 2 I haven't had any faults whatsoever.
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    Quote Originally Posted by HeelBuff View Post
    Exactly. I used to get this every now and then if I switched to S mode right when it reached temp and then hammered it without giving it a little more time. Always in second gear she would hiccup.
    Mar 06 2014
    TN
    Quote Originally Posted by tonymission View Post
    She never hiccupped in AMAX mode, though. Now that we know how lack of AMAX impacts timing between shifts it's not surprising we had the occasional misfire.
    Mar 08 2010
    AudiLand
    The first time the car had the misfire, it just got to temp on a cold night. 2nd time was on the highway with the car fully up to temp.
    Do we think it could possibly be caused by the cyl on demand. The cyl on demand shuts of cyl 2-3-5-8. If I had to think about it when this happened to me, I was always cruising and then wanted the power. Could it be that the car was about to engage cyl on demand and the Ecu was confused ?
    @Tony ... Do you have a c7.5 mate ?
    Jun 30 2012
    Woodstock GA
    That's not a bad thought now that you mention it. I think one of my situations was similar to that.... steady, slow cruise and then demand for instant power.
    I do have a 7.5 RS7, yes. :)
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    Edit: C7.5 here
    YES. I was just researching this bit. I've gotten 3 misfires on cylinder 5 since I got tuned on 6/3. Found another thread before I saw this one... http://www.audizine.com/forum/showth...Feedback/page3 which references a cylinder 5 misfire from 2014.
    IIRC, two times I got the misfire was shortly after coming to temp, where the lap timer read temps around 190. The third was 3/4 throttle in 5-6 gear, accelerating to pass.
    Seems to be a pattern.
    Here's VCDS logging of the first misfire:
    2 Faults Found:
    10203 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 16216 km
    Date: 2016.06.11
    Time: 20:44:07
    Engine speed: 4720.00 /min
    Normed load value: 32.9 %
    Vehicle speed: 118 km/h
    Coolant temperature: 74 °C
    Intake air temperature: 47 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 13.570 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    10595 - Cylinder 5
    P0305 00 [032] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 16216 km
    Date: 2016.06.11
    Time: 20:44:07
    Readiness: 0000 0000
    Second/third:
    2 Faults Found:
    P0300 00 [172] - -
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 17677 km
    Date: 2016.06.21
    Time: 19:37:46
    Engine speed: 5637.00 /min
    Normed load value: 79.6 %
    Vehicle speed: 140 km/h
    Coolant temperature: 101 °C
    Intake air temperature: 38 °C
    Voltage terminal 30: 12.345 V
    10595 - Cylinder 5
    P0305 00 [172] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 17677 km
    Date: 2016.06.21
    Time: 19:37:46
    Jul 16 2007
    Long Beach, CA
    I reached out to APR and shared this thread w/them. Will let you know if/what I hear back..
    Mar 08 2010
    AudiLand
    Thanks
    My codes on VCDS are the same.
    I chatted to a UK c7.5 RS6 owner that has been tuned by a UK tuner. He says that his tuners deactivates cylinder on demand because of this issue that they have had.
    Should we get a file from APR as such ? I'd be happy to test.
    Last thing ... Could it be that spark plug gap has increased over time ? I am running NGK 7437-9 with the APR recommended gap. I fitted these about 2500 miles ago.
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Thanks
    The information we have at the moment: The Cyl 5 misfire is temperature related and caused by a huge increase in load at low RPM. It's proven to be a nasty little bugger to track down. We have managed to duplicate it somewhat reliably, but we only get a couple tests per day because of it requiring the car to be cool.
    We're conducting more tests on an S8 now, I'll let you know how that turns out.
    Jul 16 2007
    Long Beach, CA
    Quote Originally Posted by Sean@APR View Post
    Sean thanks for the info.
    To elaborate on my experience, if it helps:
    Misfire #1. Engine was warm but not hot, having sat for maybe 3 hours. Pulled out from park and drove about 1/4 mile before pressing down, but not WOT. Got misfire as it approached 4K RPM.
    Misfire #2. Engine was definitely hot after a canyon run. Running 100 octane file on 100 octane fuel. I think it was Sonoco SS100. Misfire happened on the cruise back home in a higher gear. I was accelerating to pass and got the misfire. Didn't notice it except for the CEL blinking.
    Misfire #3. Engine warmed up to ~150 degrees after a short route. Accelerating was maybe 1/2 throttle, not WOT up a 10% grade hill in second from a stop. Hit about 5k RPM and engine misfired. This was a bad one as it felt like the car hit the brakes when it lost power.
    I'm still on my trial so am happy to explore any options before its up. Knowing that there's attention to solve it and that it won't damage anything will help me decide to stay with the tune despite the problem.
    Thanks.
    Mar 08 2010
    AudiLand
    Thanks for sharing the info.
    Mar 08 2010
    AudiLand
    For what it's worth ... I got this off another forum
    May 30 2016
    Lake Forest, CA
    I'm having the same issue. My misfire occurred after getting the APR Stage 1. Both times oil temps were probably around 210-215 and I was in S mode. Both times I stepped on it and as it changed from 3rd to 4th or 4th to 5th engine power just dropped and I could feel the misfire.
    Hopefully it's just a stage 1 problem that is fixed with the downpipes. Should be getting them installed Thursday.
    Current:
    2016 RS7 - Nardo Grey - APR Stage 2 - TCU Tune
    2015 Cayenne S Hybrid
    2015 SQ5
    2013 C63 AMG Coupe
    Mar 06 2014
    TN
    Quote Originally Posted by janthony6 View Post
    That's been my experience. Commonly had them while stage 1, haven't had one since I went stage 2 several months ago.
    Jul 16 2007
    Long Beach, CA
    Did your CEL light flash? If not, that's traction control engaging when your wheel slips between gears. I've seen this happen when I'm on the throttle maybe 60-70%.
    Jul 16 2007
    Long Beach, CA
    Interesting. Thanks for sharing.
    Aug 31 2016
    South Riding, VA
    Any updates on this? I just had my second cylinder 5 misfire event in my C7.5 RS7 (Stage 1) and was hoping the gremlin had been sorted out. Pretty much same conditions as everyone else, under hard acceleration with both cold engine and cold temps. They were ~ a month apart so I'm not too concerned about it but it's a bit unnerving whenever it happens.
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Sounds like a software update for the Engine ECU will be coming from Audi, which once released I assume will be updated/retuned by APR.
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    I had a misfire code once. It was about 25 degrees outside, the car maybe 150 degrees on the oil and i gunned it in 3rd gear on a ramp! Very violent cutoff, probably a boost cut and the light went on...
    I called it my fault and i never did it again... in most cases with subzero celcius temps, i am running the stock map. With the tune the car slides with all 4. Very scary! Lol!
    About 7500 miles on the tune...
    2015 Porsche 911 Turbo S
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Quote Originally Posted by ekpyr View Post
    TD1 awaits
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Apr 17 2016
    LONG ISLAND NY
    My 16' S6 Stage 1 with RocEuro Intake has a similar problem but never when the car is in auto or S. Only under one circumstance does it happen, no lights are triggered, no Fault Codes come up.
    It happens in Second gear in M, if I floor it and shift at 4000-5000 without going through the entire gear, after the shift the car falls flat with almost no power until you let go of the pedal and hit it again. After logging the data using the dongle I found it was misfiring just for one second and then it would go back to normal as soon as I release the throttle and hit it again .
    I called RocEuro because I noticed it after installing the intake. They said it is most likely an APR glitch and that the cars computer is expecting you to go through the entire gear instead of shifting early.
    When any gear goes all the way to the shifting point and shifts or even just before but over 4000 rpm it will not do it. Didn't look into the temperature when it happens, I will pay attention to that. I know the head tech at my local dealer and he won't TD1 me but I will run it by him on my next service in about a month or two. Any one else experiencing this when shifting early?
    2016 S6 APR Stage 1 , Roc-Euro Intake, Lowered using VCDS
    Veteran Member Three Rings 3rdBNCC's Avatar
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    Mine fell on it's face this morning while passing a farm bus and tractor on my way to work. Engine light flashed a few times and went back off. The oil temp was at 197 so that wasn't the issue. I had my iPad with me but no fault codes were listed. Curious why it happened, further down the road I jumped on it again. Smooth as silk and left off at 148 mph. First time though at temp this has happened to me.
    2014 RS7 Daytona Gray Pearl APR Stage 2
    10.319 @ 131.82 on GT260+
    Video:https://youtu.be/qnqCdZK3KnE
    IG: @Spikes_RS7
    2018 RS3 Mexico Blue Stage 2 (For Sale)
    2017 RS7 Performance Glacier White (Stock for now)
    2016 S5 Cab Black APR Stage 1 (Sold)
    2014 A5 Cab Black APR Stage 1 (Sold)
    2013 S7 White APR Stage 1 (Sold)
    2011 A6 Silver APR Stage 2 (Sold)
    Dec 29 2017
    Northern Illinois
    Hi Gang,
    Has this issue ever been rectified? My RS7 with stage 1 apr tune just starting doing this as the weather got cold. Not one issue all summer! grrr...did APR ever fix this? Is there a way to fix this?
    [FONT=Impact]2015 Audi RS7
    APR Stage 1
    10.7@129
    2015 Corvette A8 Z06 with Z07
    Ported Blower, Pulley, Intake, Tune
    9.9@141 mph
    Established Member Two Rings sWxdesigns's Avatar
    Jul 03 2019
    2020 Volvo S60 R AWD Polestar birch white
    Clearwater
    I purchased the stage two on to my 2017 Audi rs7. Lokey Clearwater was told by me to gap my plugs from apr they said never heard of or done or seen on apr. I contact apr they tell em plugs ngk and 0.024 needed lokey says we didn't know. So they quote me 400 with new plugs I hobho ahead been a week now can't get on it without the dim light going on. Didn't have issue first two weeks. Now I am waiting the plugs to go in. But have 10 000 miles on my car so not happy . Buy the single to reset light and drive normal until installed. Not happy. They should have know to install cold plugs from getco . It started after fueling up and car hot and at 70mph hit now it does it all the time .
    Wtf.
    I also get a fuel something they go we never seen that .
    I buy my single and app and see that they didn't a tivate valet 100104 and stock mode options so they said we will activate that. Feel like they really not know what they were doing installing my apr stage two but will see after I get my new plugs installed. They said apr to just regapp my stock plugs for now but I don't feel like retapping them and pay for since out might as well put new in. Glad to see I'm not only one with issue if I knew not sure I ever spent the 6k to do it . Frustrated with APR after great start new car then bad run out deal.
    Feb 15 2017
    Rochester Hills, MI
    Quote Originally Posted by sWxdesigns View Post
    Wtf.
    That is old issue at least for me. I did get misfire when it was cold before, after changing the spark plug, it minimizes the chance. But ultimately, it is software issue which has been already corrected. After installing the updated software, I did not have misfire anymore.
    2016 RS 7 Sepang Blue, Milltek Non-Res Exhaust, AWE S-Flo 2.0 Intake, APR Stage 1, Neon Yellow Caliper, Black RS7 Performance Wheels, Escort Passport 9500ci Radar Detector with AL Priority Laser Jammer
    Jul 03 2019
    Clearwater
    I hope it will get fixed after new plugs go in. I just start it now and apr Mobil app reads no fault codes now even when it comes on and I just start the car clear it still there and smell a lot of fuel . So I see fuel issue to now only 10k miles on car hope the plugs will solve it. Interesting enough started after I installed roc cold air intake not before that so unistalled roceuro and no difference hoes in to limp mode when hitting gas. But hot here now and humid in Florida not sure if that makes any difference to. Can’t wait to see effect of new Ngk plugs go in. Will update once new in
    Jul 03 2019
    Clearwater
    Got all new software uploaded again today and did it so hopefully just new plugs saw no fuel issue after reinstall of software
    sWx designs all apparel and graphics done in house
    2017 RS 7 - APR II, apr downpipes, eVenturi cold air intake, fuel pump, NGK cold plugs, servini FS-4 glossy black 10.5 21”, Michelin 4S 295/30/21, ppf, ceramic pro ceramic coat
    Signworx.org our new Audi sport window banners ready to ship.
    Facebook/flaudi
    Aug 08 2018
    New Hampshire
    Well my RS7 just started giving me the flashing CEL on kick-down and a cyl5 misfire code, APR stage 2. Happened 3 times now, all when temps are sub 30F. Car feels fine otherwise. Never had a problem all summer with many 1/4mile runs etc so I’m presuming it’s the same issue others have been seeing when the air temps get cold, but I only got my APR stage 2 this summer so shouldn’t I already have the fixed software?
    My plugs are OEM and have less than 3k miles on them, but are OEM gap. I guess I could have them regapped but hate to spend the money for no reason. 🤔
    Senior Member Three Rings Nosferatu's Avatar
    Aug 19 2019
    C7.5 RS7 Performance, McLaren 720S Spider, Tesla Model S Plaid
    Tampa, FL
    Still no clear cut answer from APR?
    2018 Audi RS7 Performance in Mythos Black with DS1 Stage 1, Milltek (non-resonated) Catback, Uniden R7 Blendmount, Viofo A129 Duo
    10.8 @ 128.7 MPH
    Other Toys:
    2019 McLaren 720S Performance Spider Keeping the ICE dream alive!
    2021 Tesla Model S PLAID the Silent ICE killer
    9.33 @ 150.2 MPH
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by Nosferatu View Post
    Called them, they said there was a new update to address it as of 11/5/19, I’m currently at my APR dealer waiting for it (and CoD removal) to be installed. Will update the thread with if the update fixes it or not when I’ve had a chance to drive it around for a bit post-update.
    Aug 08 2018
    New Hampshire
    Annnnd it’s done. Apparently the 4.0T has now switched from v1.0 to V2.0 but they didn’t have any release notes so could only tell me that it “addresses the cylinder 5 issue”, not sure if anything else changed. Maybe Arin or someone can confirm.
    So far so good anyway, drove 40mins home and no misfires so far. Also so nice not having the annoying CoD noise on the highway, won’t miss that!
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    Quote Originally Posted by kebabman View Post
    good to hear!! I'm going APR stage2 next month on my S6. (not using apr dwn pipes, but am using their tcu tune also). I am doing oem rs7 plugs gapped for APR specs on my car.
    2016 S6 - sport - optx- atlas - AE nardo
    Jan 17 2017
    How can they not have release notes? Are current APR customers eligible for the free upgrade?
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by NardoRS7 View Post
    My APR dealer didn’t have them is all I know. I paid $50 labor for the reflash.
    Feb 15 2017
    Rochester Hills, MI
    I think I had the version 2.0 long time ago, probably around September 2018 timeframe, which fix the misfire problem. They had updated stage 2 file even earlier.
    Unless my dealer told me wrong about the version, I'm supprised to see you still have the old version
