Page 1 of 89 1231151 ... LastLast
Results 1 to 40 of 3532
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    **NEW** 1/4 mile spreadsheet: Submit your time here
    Hi all,
    I'm going to run a spreadsheet on my google drive and link it to this original post. If you want yours submitted, please submit it in the following format below. I figured instead of digging into the 1/4 mile thread and then digging into each dragtime, this method would be easier for me to load onto the spreadsheet.
    Include the following in this order:
    Member name: Loe
    Model: B8.5 S5
    Tran: DSG
    TCU Tune: GIAC
    ECU Tune: GIAC
    Stage: 2
    File: Race
    Fuel: 93/E85
    S/C pulley + size: AWE 57.55mm
    Crank Pulley + size: JHM 179mm
    Pulley Ratio: 3.110 (take your crank pulley and divide it by your s/c pulley)
    D/A: 662
    Date: 04/09/2016
    Timeslip: http://www.audizine.com/gallery/data...ctane_RACE.JPG
    60ft: 1.xxc
    330ft: 4.xxx
    1/8 et: 7.xxx
    1/8 mph: 97.xx
    1000ft: 9.xxx
    1/4 et: 11.xxx
    1/4 mph: 122.xxx
    Here is where you can find your pulley sizes (thank you AZ member whiped) ---> **OFFICIAL** Life Beyond Stage II the higher pulley ratio development thread
    **Your Timeslip must be IHRA/NHRA cert track only (or possibly any other cert track internationally to not exclude others?) in order to be placed on the list, and it must also be the full slip showing the track, date, and time**
    I want to keep the list simple (For example, I only loaded my fastest time with a dual pulley, and also my fastest time for a single pulley).
    Here is an example of the list, there will be pretty colors added once published on a shared google file. I'll update the times as much as I can, more than likely almost daily in the beginning and then eventually as needed (more than likely weekly) once the database becomes bigger.
    **EDITED** here is a nice density altitude calculator, as well as being able to select your track, specific date, as well as a timeframe and it will automatically load the information to calculate density altitude --- > DENSITY ALTITUDE CALCULATOR
    Here is a nice live density altitude tracker which also allows you to look at forecast data, you select your track underneath your state --- > LIVE DENSITY ALTITUDE
    Here is a nice conversion you can use to calculate how well you would run in "0" ft. D/A --- > Calculator/Conversion for a near 0 ft. density altitude run
    ***KEEP IN MIND THAT NOT ALL D/A's ARE CREATED EQUAL***
    ****Here is the link to the database to view****
    Audi "3.0t" 1/4 Mile spreadsheet
    Positive vendor/tuner comments are welcomed, unless they are 100% biased towards only one tune, otherwise start your own "pat yourself on the back" thread please
    LINK TO THE OLD 1/4 mile thread here - - - > CLICK ME
    **If you need or want this updated, please PM me if it hasn't been instead of putting up a thread reply. Signed, your neighborhood moderator...**
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Good stuff, sub'd.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Member name: Vogz
    Model: S4
    Tran: 6MT
    TCU Tune: N/A
    ECU Tune: GIAC
    Stage: 2
    File: Pump
    Fuel: 93
    Crank Pulley + size: OEM 162.18mm
    Pulley Ratio: 2.818
    D/A: -180ft
    Date: 05/13/2015
    Timeslip: http://i118.photobucket.com/albums/o...psx5kjrdf8.jpg
    60ft: 1.748
    330ft: 5.128
    1/8 et: 7.885
    1/8 mph: 90.84
    1000ft: 10.251
    1/4 et: 12.245
    1/4 mph: 112.62
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Thanks for putting this together Loe. Here are my two best passes (so far )
    Member name: mrmomo313
    Model: S4
    Tran: DSG
    TCU Tune: none
    ECU Tune: APR v3.1
    Stage: 2
    File: Race
    Fuel: 100 octane
    S/C pulley + size: APR 57.75mm
    Pulley Ratio: 3.100
    D/A: -480
    Date: 11/07/2015
    Timeslip: http://s1304.photobucket.com/user/ms...xawie.jpg.html
    60ft: 1.686
    330ft: 4.876
    1/8 et: 7.511
    1/8 mph: 93.36
    1000ft: 9.767
    1/4 et: 11.679
    1/4 mph: 117.62
    Model: S4
    Tran: DSG
    TCU Tune: none
    ECU Tune: APR v3.1 + CW
    Stage: 2
    File: 93
    Fuel: 93
    Pulley Ratio: 3.100
    D/A: +2380
    Date: 06/22/2016
    Timeslip: http://i1304.photobucket.com/albums/...pszqf836on.jpg
    60ft: 1.739
    330ft: 4.986
    1/8 et: 7.511
    1/8 mph: 91.82
    1000ft: 9.951
    1/4 et: 11.879
    1/4 mph: 116.47
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Member name: pdqgp
    Model: S4
    Tran: DSG
    TCU Tune: APR DSG
    ECU Tune: APR
    Stage: 2
    File: Pump
    Fuel: 93
    S/C pulley + size: APR not sure of size
    Pulley Ratio: ?
    D/A: N/A
    Date: 04/29/2016
    Timeslip: http://i1379.photobucket.com/albums/...ps3vurrul6.jpg
    60ft: 1.811
    330ft: 5.146
    1/8 et: 7.898
    1/8 mph: 89.48
    1000ft: 10.247
    1/4 et: 12.239
    1/4 mph: 113.33
    Full tank of gas and Stock Conti's at full 41psi. Run just like I would on the street.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    Member name: OnEaNgRyBuNnY
    Model: S4 B8.5
    Tran: DSG
    TCU Tune: APR
    ECU Tune: APR v3.1
    Stage: 2
    File: 93 oct
    Fuel: E85/93 1:3
    Pulley Ratio: 3.100 (take your crank pulley and divide it by your s/c pulley)
    D/A: ~325
    Date: 06/17/2016
    Timeslip:
    60ft: 1.621
    330ft: 4.786
    1/8 et: 7.442
    1/8 mph: 91.52
    1000ft: 9.716
    1/4 et: 11.646
    1/4 mph: 115.70
    Aug 09 2015
    Sarasota, FL
    everyone who posted yesterday has been added
    Established Member Two Rings Moloki's Avatar
    May 25 2014
    mass
    Member name: Moloki
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: APR
    Stage: 1
    File: Pump
    Fuel: 93
    S/C pulley + size: stock
    Crank Pulley + size: stock
    Pulley Ratio: stock
    D/A: +1148 ft
    Date: 06/22/2016
    Timeslip:
    60ft: 1.795
    330ft: 5.164
    1/8 et: 7.928
    1/8 mph: 89.16
    1000ft: 10.30
    1/4 et: 12.300
    1/4 mph: 112.93
    No spare or tools, over a third of a tank of gas.
    Sent from my XT1254 using Tapatalk
    2012 S4 | Moonlight Blue | sports Diff | interior under glow | DSG | APR TCU flash | Rs4 Grille | ECS Valved Exhaust | APR stage 2 DP | ECS luft-technik intake silicone version | 034 Motorsports transmission mounts and Diff mounts | P3 multi gauge | Michelin PILOT SPORT A/S | A4 weather mats
    2003 A4 | loudest sound system possible | :( sold
    Aug 09 2015
    Sarasota, FL
    ^^ that is an incredible time for a stage 1, especially since I keep hearing other members stating that NED isn't a track for the quickest time. Way to represent the stage 1 guys!
    Veteran Member Four Rings FLYINGLEGGS's Avatar
    May 04 2009
    18 Q3, Chevy Cruze T DD
    Florida
    Member name: FLYINGLEGGS
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: APR
    Stage: 1
    File: 93
    Fuel: 103
    S/C pulley + size: Stock
    Crank Pulley + size: Stock
    Pulley Ratio: Stock
    D/A: +520
    Date: 3/17/16
    Timeslip:
    60ft: 1.728
    330ft: 5.008
    1/8 et: 7.752
    1/8 mph: 90.29
    1000ft: 10.090
    1/4 et: 12.071
    1/4 mph: 113.72
    [/SIZE]
    -2019 RS3 DG, BO. APR Plus
    -2014 S4 Misano, BO, Sports Diff, DSG.
    Apr Stage 1 ECU/TCU, Intake
    Stage 1 104 Octane: 11.64
    Stage 1 93 Octane 11.94
    *Sold*
    -2007 A4 2.0T S-Line APR BT Stage III and much more. Sold
    May 22 2015
    DFW
    Member name: andthen
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: EPL
    Stage: 2
    File: E85 Dual Pulley
    Fuel: E85
    Pulley Ratio: 3.100
    D/A: -800
    Date: 1/23/16
    Timeslip:
    60ft: 1.6180
    330ft: 4.7153
    1/8 et: 7.2969
    1/8 mph: 94.08
    1000ft: 9.5227
    1/4 et: 11.4072
    1/4 mph: 119.74
    Senior Member Three Rings Alessandro's Avatar
    Sep 23 2010
    Audi Q3 2017
    Member name: Alessandro
    Model: S5
    Tran: DSG
    TCU Tune: GIAC
    ECU Tune: GIAC
    Stage: 2
    File: Race
    Fuel: 104
    Crank Pulley stock
    D/A: 327
    Date: 23/10/2015
    Timeslip: https://1drv.ms/i/s!As64ik-3WBMcn2A5h9bF1FPCzT8E
    60ft: 1.6771
    330ft: 4.88
    1/8 et: 7.5579
    1/8 mph: 92.45
    1/4 et: 11.7511
    1/4 mph: 116.24
    new times should be update soon once weather is good ;)
    2018 Audi S5 SB /Glacier White/ Fully Loaded /
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Member name: jran76
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: APR
    Stage: 2
    File: Race
    Fuel: 100
    Pulley Ratio: 2.808
    D/A: 560
    Date: 04/08/2016
    Timeslip:
    60ft: 1.714
    330ft: 4.934
    1/8 et: 7.627
    1/8 mph: 90.25
    1000ft: 9.927
    1/4 et: 11.869
    1/4 mph: 118.36
    I have a slightly faster run somewhere I believe, but I've moved and can't find the slip right now....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jun 06 2016
    Florida
    Quote Originally Posted by FLYINGLEGGS View Post
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: APR
    Stage: 1
    File: 93
    Fuel: 103
    Pulley Ratio: Stock
    D/A: +520
    Date: 3/17/16
    Timeslip:
    60ft: 1.728
    330ft: 5.008
    1/8 et: 7.752
    1/8 mph: 90.29
    1000ft: 10.090
    1/4 et: 12.071
    1/4 mph: 113.72
    [/SIZE]
    My local track! Nice time, btw.
    Aug 09 2015
    Sarasota, FL
    everyone has been updated. Thanks guys!
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    is year needed the B8 vs B8.5 thing? Different gears in transmission I believe.
    Admins need to sticky this.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Mar 21 2015
    Quote Originally Posted by cspcrx View Post
    Good luck with that, not one around for a couple hundred miles. It should be stuck though.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by andthen View Post
    Model: S4
    Tran: DSG
    TCU Tune: APR
    ECU Tune: EPL
    Stage: 2
    Fuel: E85
    Pulley Ratio: 3.100
    D/A: -800
    Date: 1/23/16
    Timeslip:
    60ft: 1.6180
    330ft: 4.7153
    1/8 et: 7.2969
    1/8 mph: 94.08
    1000ft: 9.5227
    1/4 et: 11.4072
    1/4 mph: 119.74
    Are you running 100% e85 with the EPL tune? Just wondering because Loe's time with STG2+CW is working really well with the 93/e85 blend and would think that a dedicated e85 tune/dual-pulley tune would be stronger.
    Also,
    LOE's times are pretty awesome. His 1/8mile traps would let him hang with some high power cars, especially given the traction advantage he would have in the real world and would probably surprise a lot of people. To give you a hint of his power compared to a stock S4 running let's say a 12.9@108mph
    Comparison in the real world
    1/4 mile - 117.44 ft/second vs 101.89 ft/second (stock s4) = 11+ car lengths when finishing the 1/4 mile
    1/8 mile - 91.54 ft/second vs 78.80 ft/second (stock s4) = almost 6 car lengths passing the 1/8 mile
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Jan 04 2013
    Phoenix, az
    That 12.9 is generous I think very few stock S4s get out of the 13s.
    Aug 09 2015
    Sarasota, FL
    1/4 et: 12.071
    1/4 mph: 113.72
    Give me a shot in driving it next time, I bet I can get it into the 11's
    Aug 09 2015
    Sarasota, FL
    Do you feel its important? Has there been data to confirm if one gear set is better than the other? I can certainly add, no problem.
    ***EDIT*** added for all so far and edited my first post for future guys entering
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by shoe3k View Post
    To put things into perspective, have no problem running neck-to-beck with a JB4 F10 M5 from a low speed roll to 100-110mph, the torque and the ability to put it down is very nice indeed They start to slowly walk away after that because of their superior HP and long gears though.
    Jan 04 2013
    Phoenix, az
    Thanks Loe and thanks for taking this on.
    Now for the most dumb question, where is the list? I see the link to the SC size file.
    If its obvious I am blaming the Polish side of the family!
    Aug 09 2015
    Sarasota, FL
    I went ahead and edited my original post to include a viewable link. I'll keep updating it and the link as we go. Lets keep it going and get more entered from across the board, unitronic/epl/giac/solo/034/apr/CW
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Member name: 613B6
    Model: B8S4
    Tran: DSG
    TCU Tune: EPL
    ECU Tune: EPL
    Stage: 2
    File: Pump Gas
    Fuel: 94
    S/C pulley + size: CTS 57.02mm
    Pulley Ratio: 2.844
    D/A: 145
    Date: 04/23/2016
    Timeslip: http://i54.photobucket.com/albums/g1...pstd5fp1vy.jpg
    60ft: 1.693
    330ft: 5.161
    1/8 et: 7.586
    1/8 mph: 91.60
    1000ft: 0.0
    1/4 et: 11.819
    1/4 mph: 116.75
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Oct 27 2010
    Michigan
    Quote Originally Posted by Loe View Post
    I ran 100 octane on the apr 100 map for the 11.6 pass. Please update when you have a chance
    Feb 01 2015
    Lancaster, PA
    I was just plucking through some BMW info on the n54/55 engines and stock turbo, bolt-on performance figures. I'm surprised no one made mention before that, as demonstrated by my dyno and times, we have significantly surpassed what they can do with a like level of modification
    ~400rwhp with e85 and meth tuned vs ~400awp on 93 oct tune (pre-cw)
    ~11.7x @116.xx vs [email protected]
    However, the power curve is entirely different...
    Absolutely! This is a significant improvement over the last 1/4 mile thread. Thanks again, Loe.
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by OnEaNgRyBuNnY View Post
    Going through some of their dyno sheets I noticed that a lot of their runs are done with e85 on dynojets. Those results don't seem to reflect what I have run in the real world with JB4 tuned n55 motors on "93 octane or e85 blend".
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Member name: infinkc
    Model: B8 S4
    Tran: 6MT
    TCU Tune: N/A
    ECU Tune: APR
    Stage: 2
    File: 100
    Fuel: 91/E85/Meth
    Pulley Ratio: 2.808
    D/A: 321
    Date: 03/11/2015
    Timeslip: http://oi62.tinypic.com/e5mstu.jpg
    60ft: 1.743
    330ft: 5.103
    1/8 et: 7.876
    1/8 mph: 88.73
    1000ft: 10.254
    1/4 et: 12.263
    1/4 mph: 113.43
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 01 2015
    Lancaster, PA
    What have you seen and experienced?
    Aug 09 2015
    Sarasota, FL
    Thanks all, everyone will be updated shortly
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Can't find my 12.31 slip posted but I should have it in my cabinet so I will post it when I find it. In the mean time I'll give you some more numbers to crunch brotha lol
    Member name: BlownOne
    Model: B8 S4
    Tran: Dsg
    TCU Tune: 034
    ECU Tune: APR034
    Stage: 1
    File: 91
    Fuel: 91/E85
    Pulley Ratio: Stock
    D/A: +398
    Date: 02/27/2016
    Timeslip:
    60ft: 1.730
    330ft: 5.137
    1/8 et: 7.933
    1/8 mph: 87.99
    1000ft: 10.328
    1/4 et: 12.342
    1/4 mph: 111.57
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Aug 09 2015
    Sarasota, FL
    all items have now been updated. Thank you all for contributing to this!
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Member name: xpoweruk
    Model: B8 S4
    Tran: 6MT
    TCU Tune: NA
    ECU Tune: REVO
    Stage: 1+
    File: 100RON
    Fuel: 99RON/Ethanol
    S/C pulley + size: REVO 57.65
    Crank Pulley + size:OE 162.18
    Pulley Ratio: 2.813
    D/A: 1,389
    Date: 03/19/2016
    Timeslip: http://i63.photobucket.com/albums/h1...160319_004.jpg
    60ft: 1.97
    330ft: 5.3147
    1/8 et: 8.0194
    1/8 mph: 92.34
    1000ft: NA
    1/4 et: 12.266
    1/4 mph: 116.86
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Aug 09 2015
    Sarasota, FL
    updated!
    xpoweruk, that's strong trap for a stage 2 6MT!
    Feb 05 2016
    UK
    updated!
    Cheers Loe.
    It was a shame it was a wet morning with poor track condition once it dried off.
    Traction was a mare (as can be seen with my 60ft) I'm hoping to get to the strip again later this year (fingers crossed).got uprated cooling now too :)
    @Loe I'm out of place on the chart ;) & my pulley size (crank) is wrong should be 2 spots higher
    Aug 09 2015
    Sarasota, FL
    Corrected, forgot to sort after adding the last few actually.
    Feb 05 2016
    UK
    Cheers Loe
    Dec 30 2015
    Sacramento, Ca
    Model: B8 S4
    Tran: Dsg
    TCU Tune: 034
    ECU Tune: 034
    Stage: 2
    File: 100 octane
    Fuel: 91/e85 blend
    S/C pulley + size: 034 57.xx
    Pulley Ratio: 2.xx
    D/A: 1,771
    Date: 07/17/2016
    Timeslip: Pictured
    60ft: 1.702
    330ft: 4.934
    1/8 et: xx
    1/8 mph: xx
    1000ft: 9.906
    1/4 et: 11.840
    1/4 mph: 118.09
    Dec 30 2015
    Sacramento, Ca
    Went to a track rental at sac raceway today and had a blast!! Laid down some great times consistently for a stage2 car in the heat without ideal da's. Really happy and fairly sure I just set a record with the best pass of the day which I posted. Can't wait to get my lower pulley and hx put on, get retuned and then we can see what she will really do!!😎
    Big thanks to 034 Motorsports for the awesome tuning...without them, this wouldn't be possible.
