    Established Member Two Rings BKLYNAUDI's Avatar
    Sep 11 2011
    Rear axle removal help!
    Is there a DIY for a rear axle removal .......I have a ripped boot ....I want to get this axle out.....my search came up with nothing but front axle ....must not be common....please help
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Not common since the rear wheels don't turn it only rotates some cars with 200k miles still have the oem rear axles for quattro. Maybe phil can shime in.
    Sent from my C5306 using Tapatalk
    Ivan
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by BKLYNAUDI View Post
    Really Easy:
    Remove axle 32mm nut
    Remove axle shield on differential (3 screws)
    Depending if left or right side, remove exhaust silencer hanger of the incriminated side
    Remove axle flange screws (x6)
    DONE
    Phil
    Sep 11 2011
    Really Easy:
    DONE
    Phil
    thanks Phil
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Really Easy:
    DONE
    Phil
    32mm nut? My car uses a bolt with a 17mm socket head like shown below. I was also unable to collapse the cv joints enough to get the axle out without removing the lower control arms. I had to do this when replacing rear wheel bearings.
    Here are instructions from ECS. Stop at step 12 for just the axle.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...allationR1.pdf
    2018 A5 S-Line Manual
