Results 1 to 40 of 74
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Floor Jack Recommendations
    Does anyone have recommendations for a reliable floor jack to use for wheel changes? I'm assuming I should get a 3 ton jack. I was originally going to just go with a Craftsman but the reviews about build quality have scared me a bit. It's hard for me to justify spending $400+ on something like a Hein-Werner though just for seasonal wheel swaps.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Sep 28 2010
    NW NC / DE
    May 31 2016
    Mexico
    I got this jack on amazon. The Harbor freight goes up to 19" while this one does 24". Its an awesome jack.
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    ^ the 2 ton harbor freight does 23 and 3/4.
    I run the 3ton and its been good for 2 years and gets alot of use and dragging around the garage. Lasted alot longer than my previous craftsman for alot cheaper.(can be had for 79 most of the time)
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Yup that's the one I have. Once I was lowered it worked fine. But for the first two weeks I owned the car it needed another inch or so to get the wheel off the ground lol
    May 31 2016
    Mexico
    Quote Originally Posted by tar View Post
    Found the link, thanks. .
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by Q5OnTheMove View Post
    solid jack. the only thing is that HF's "racing" line is made of aluminum, this guy is made of steel. albeit cheaper, in the end, i couldn't even lift the damn box for the steel model. so i said fuck it and shelled out a little more for the aluminum (blue) one
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    A 2-ton is more than adequate. You're not going to be jacking up the whole car.
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by drumnjuny View Post
    Pinch weld adapter pucks solve this and Dem to add stability as well.
    S4 Build Thread
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    I got one and it was a POS so I said fuck it to my pinch welds and threw it out lmao. $6 Amazon purchase fail
    Jan 01 2016
    Tampa Bay
    I got a set off eBay. I think I paid around $25. I haven't used them on the SQ5 yet, but they have worked well on the S4.
    S4 Build Thread
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Nice, this one was too squishy I'll have to try different one!!
    Mar 21 2015
    You can't go wrong with the HF jacks. Might be the only thing I have ever bought there, probably will be the only thing too.
    Mar 26 2015
    New York, NY
    It looks like Harbor Freight is the way to go. Thanks guys. I was thinking 3 ton figuring it might last a bit longer. It will be sitting in my in-law's garage for the most part so not too worried about mobility with it. Now to find a decent jack pad.
    Current
    Past
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    ha, when u find a good jack pad, i may buy one also.
    Mar 26 2015
    New York, NY
    I was thinking of getting this. Kind of pricy but seems more likely to hold up.
    NEW! Pinch Weld Floor Jack Pad Adapter - Works with most floor jacks
    Current
    Past
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    awesome! once you buy it and say it rox your sox i'm gonna get one too. i bought one before and it was a POS. threw it out after one use.
    May 31 2016
    Mexico
    I have this jack along with this Slotted Rubber Jack Pad Frame Rail Protector. Works great on my 2016 Q5.
    Mar 26 2015
    New York, NY
    This is a potentially dumb question, but is the idea of the adapter to have the force distributed to the area around the pinch weld or just so that it spreads it evenly across the pinch weld?
    And anyone happen to have measurements of the width/height of the pinch weld on our cars? I won't see my car until the weekend.
    Current
    Past
    Sep 28 2010
    NW NC / DE
    I've been not using pads since forever. I have a thick piece of scrap rubber I use, and also will fold towel over a few times.
    HA! Same here.
    Pretty sure I have the 3 ton as I have a 2 ton Craftsman alu.
    Mar 22 2016
    I also use this along with a hockey puck
    Mar 26 2015
    New York, NY
    I just ordered the Burger Motorsports jack pad. I guess I'm a sucker for anything advertised as billet aluminum. I'll report back on how it works once I get it and a HF floor jack.
    Current
    Past
    Sep 28 2010
    NW NC / DE
    Mops on the move
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    +1 for the harbor freight aluminum jacks. Just don't get the 1.5 ton model; it doesnt go high enough.
    The 3 ton is the business though.
    On a side note, harbor freight has good and bad stuff. You just gotta read the reviews.
    I got a red cart/toolbox and that thing is boss. Waaaaayyyyyy better than any other tool box 150$ will buy. Ball bearing drawers and included mats. Even has a flat top to use as a work table.
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    +23487343 on HF .. actually rocking Harbor Freight 1.5 Ton low profile with a urethane jack pad adapter and wheel chocks. Also have a 2 Ton craftsman, but have been using the rapid pump HF more nowadays.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Apr 26 2015
    Harrison, NJ
    20364495 thats a coupon code for harbor freight for the 3 ton jack. $15 off
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Jul 07 2009
    Socal/IE
    You should click his link.. Clearly says steel in title. Their lightweight alum one is a waste of time compared to the linked one. It works but expect to replace yearly.
    Sent from my VS987 using Tapatalk
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Established Member Two Rings gaben2racin's Avatar
    Jun 15 2013
    Roseville,CA
    Harbor freight. 1.5 ton. That's all you need.
    Sent from my SM-G900T using Tapatalk
    Mar 21 2015
    ^ That's the same one I have and it's great. Mine is also missing a side handle due to it not fitting under my toolbox.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Not sure what tonnage I have but it looks just like that. Does the job well.
    Senior Member Two Rings PCHS4's Avatar
    Apr 22 2011
    Arizona
    I bought an Arcan 3 ton aluminum floor jack 3 years ago and it's been 100% trouble free.
    https://www.amazon.com/Arcan-ALJ3T-A.../dp/B0047D2FWM
    Use the Protech Products Sidelift Jack Pad - MODEL #1007
    http://protechproducts.com/index.php...&product_id=57
    2011 S4 Phm Blk, DSG, APR Stage II+, EuroCode Headers/DTS/Sway Bars/Drop Links, Milltek Resonated, APR Intake (rear backpipe), SPC UCA, KW V3, HRE FF01 19x9.5 ET45, PSS 275/35/19.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Great thread. I'm still rocking my dual Craftsman 2-tonners that were gifts...at the same time, from different people. Anyway...I would be all kinda' grateful to anyone willing to post close-up worm's-eye shots of front and rear jack points, with or without the hockey pucks.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Mar 26 2015
    New York, NY
    I was all set to order a HF floor jack, but I'm having some second thoughts given the not-particularly-confidence-inspiring 90 day warranty. If I get a Craftsman, I've at least got the one year warranty plus an extra year from Amex. My billet aluminum jack pad adapter gets here this week at least!
    Current
    Past
    Mar 21 2015
    I wouldnt worry, those jacks are one of few highest praised thing HF has.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    2nd.
    It's a good jack - buy it and don't look back.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Apr 22 2011
    Arizona
    Mops on the move
    Wow Mops, that black jack is so sleek and aerodynamic. Do you ever race it around in your garage?
    Mar 26 2015
    New York, NY
    Quote Originally Posted by PCHS4 View Post
    Stickers make everything faster and more awesome.
    Current
    Past
    Apr 26 2014
    DFW
    Not to mention...the red one looks like the Flintstone's jack.
    Veteran Member Three Rings JWreck's Avatar
    Jul 28 2014
    Cedar Park, TX
    I was gifted an Arcan 3.5 ton floor jack which has been great. Except...I realized yesterday changing my brakes (S4) its too wide to fit both the jack and a jack stand below on the jack points. Just by a hair.
    2019 RS5 Sportback | Nardo | Nappa | Dynamic | RS Driver Assist | Black Optics | Dynamic Steering | B&O
    2017 AMG C63S | Gone
    2014 S4 P+ | Gone
