Results 1 to 8 of 8
    Established Member Two Rings J4EZ's Avatar
    May 10 2016
    Colorado
    Car seat upholstery repair DIY?
    Has anyone fixed their seats from ripping or fixed the rip?
    Not too big, but want to plug it up before it spreads
    2009 Audi A4 Premium Quattro 2.0
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    That problem looks like it stems from poor hydration of the leather; it's cracking due to dryness.
    Have it cleaned, then repair it with those repair-DIY-kits from a leather shop...
    Or call a professional auto leather repair place and have them address it.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    May 22 2016
    N/A
    My drivers seat had a similar rip starting. I got a quote from a local upholstery place for around $300 to fix, so I checked online and found a used seat without rips for $250 on eBay.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    It depends on what kind of results you want.
    DIY is not going to hold for thst long becase its basically filler that fills the cracks and paint/dye that matches the leather.
    The cheapest option would be to buy that peice from wrecking yard and replace the cover.
    Or
    Buy the cover from the dealer or Genuineaudiparts.com
    Each seat has sections of leather that can be replaced just find the part number and check prices and see if its worth replacing yourself.
    IMHO since i did this once on my S4 recaro seats i had in my B6 I suggust buying the cushion or cover from a wrecking yard and swapping cushion or just lesther cover. Depending on what the replacement cover cost from dealer thats best option if you can get a wrecking yard to sell you that peice without buying the whole seat.
    Sent from my SM-G920T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Jul 19 2013
    Porsche 944
    Las Vegas, NV
    Since that (appears to be) the side bolster on the seat, isn't it vinyl?
    Black 09' Avant, 30% Huper Optik tint, R8 coils
    Jan 16 2011
    Earth
    Vinyl and leather repairs are done the same using the same type of repair filler snd paint/dye
    Established Member Two Rings PyroDonkey's Avatar
    Oct 08 2014
    You might be better off looking for a replacement cushion on eBay. Fixing with fillers and dyes isn't the greatest solution, but it can be done if you get a leather repair kit. Essentially what you'll do is fill the cracks with a product, then dye the filler to look similar to the leather. The problem with this is I've heard that it can be a pain to deal with when cleaning the car because the dye can come off. See if you can find a replacement cushion on eBay and just replace the whole thing if you're up for it. Also, if you want to prevent this, I'd suggest getting a leather cleaning and conditioning kit to prevent this from happening on other sections of the car's seats.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Theres alcantara seats on the ad section
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
