Results 1 to 7 of 7
    Established Member Two Rings mmadlang's Avatar
    Jan 15 2011
    Dallas, TX
    Broken bolt in Timing Chain Tensioner
    So I managed to break one of the head bolts for the Timing Chain Tensioner. I tried to extract the stuck bolt with an angled drill, but there's just little room to work with. Any suggestions? Do I need to remove the head?
    Feb 24 2004
    Minneapolis
    What if you remove bumper, radiator, condenser. That's less work than a head job.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jan 15 2011
    Dallas, TX
    So the bolt is actually on the other end; almost against the firewall. If I remove the front, how can I gain more access on the other side of the cylinder head?
    Jun 17 2013
    jersey city nj
    You need to the cylinder head
    Jan 15 2011
    Dallas, TX
    That's what I thought. I guess I need to search for a DIY on removing the cylinder head. Unless someone has an easier idea. :(
    Feb 15 2016
    Cambridge,Ontario
    If it broke coz its seized in there do not even mess around with a drill. Remove head and take to a machine shop
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by mmadlang View Post
    Sorry, thought it was a timing belt tensioner bolt. Guess I should learn to read some day....
