Results 1 to 29 of 29
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    DSG fluid change solved issues!
    How is this possible? I had every symptom of a failing mech unit: harsh 2-1 downshift, jerky takeoffs, sweeping RPM's in certain gears, and occasional banging/thuds. I was starting to budget for a new mech unit, and I decided to have the fluid/filter changed by a local Indy last week. Since then, it feels like a different car. None of the problems that I was experiencing before are there. I called the shop to see if they did a DSG re-adaptation, but the claim they did not.
    Some background:
    2010 DSG S4 purchased last October with 108k
    APR Stage 2 with TCU tune (TCU tune did not improve any DSG issues I was having)
    I guess it's possible the fluid was never changed by the previous owner, but I have a hard time accepting that such a simple thing could resolve so many problems. Am I crazy? Hopefully this isn't temporary...
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    I hope it holds out for you.
    But yes, it is possible it fixed the issues. I know of someone that had a similar issue with his Porsche PDK transmission. Before tearing it apart, they changed fluids and filters and it did the same thing and fixed all his issues.
    Who knows why, but sometimes just being dirty or filters not letting fluid flow freely or whatever can cause some issues.
    I probably wouldnt blow the mech unit fund just yet, but hopefully it solved your issues and you're good to go.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    108K with no fluid change when it was supposed to be changed a few times by then yikes...You would be amazed how much better a trans can feel with fresh fluid in it...hope it continues to work well for you
    [B]Current: Shopping now....
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I find it hard to believe there wasn't at least one at 35k. Doesn't the factory warranty cover the first one?
    I've been looking at a few B8.5 B8 S4 to move to possibly as a successor to my 2010 B8 S5. I'd like to be around the $30-$35k CPO range possibly. But surely I'm not touching it unless it shows the fluid wasn't changed at 35k. I wouldn't have a problem coming out of pocket 7-$800 to do it again at 75k.
    I wonder for those getting higher miles now from 2010 & 2011's is the next recommended change after 75k. I assume every 40k-ish?
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Quote Originally Posted by Vanimal View Post
    It is only covered if you buy Audi Care.
    OP - Some of the new Golf R's have been delivered with too little transmission fluid in the DSG and they displayed similar symptoms; there is a chance that your transmission was serviced at the correct intervals, but was just low on fluid.
    May 20 2015
    PA
    Quote Originally Posted by The Fat Kid View Post
    Ah ok good to know, that is the first thing i check when i look at the car fax which is usually provided for free most times via Auto trader on a CPO etc. I would still call to confirm though lol.
    Jun 21 2014
    2012 Grand Cherokee 5.7 L
    Santiago, Chile
    I remember a Wheeler Dealer episode when they bought a Boxster with auto transmission issues and a fluid and filter change fuxed it. TV show? Perhaps, but maybe not.
    Jun 21 2014
    Santiago, Chile
    [QUOTE=Westija;11688963]I remember a Wheeler Dealer episode when they bought a Boxster with auto transmission issues and a fluid and filter change fixed it. TV show? Perhaps, but maybe not.[/Q
    Established Member Two Rings JKrups06's Avatar
    Jul 01 2014
    Chicago IL
    When is the dsg fluid suppose to be changed? I'm 500 miles away from 70k miles majority highway miles but I don't think my dsg fluid has been changed once. I bought it used at 36k miles
    Sent from my SM-G935T using Tapatalk
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    At 35k and the second at 75k I believe.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Oct 06 2014
    Cleveland, OH
    Glad I stumbled upon this. I bought mine used with 37K, now I am at 50K. I looked up the service schedule the other day to see what happens at the 55K and noticed DSG service @ 75K, and 35K? Yikes, checked my carfax and see no record of any service after 25K?
    Crap. So here I am at 50K with no DSG service being done. I have read a few DSG how DIY's and it does not look bad if I can access a lift, but making that fill tool seems like a real PITA. Funds are a little tight right now and I have no VAG-COM for reading the trans temp? All that whining out of the way...
    https://www.europaparts.com/dsg-tran...5-7-speed.html
    Do I change the fluid and external filter? (myself) $105 + $13
    Do I change the fluid and both filters? (myself) $255
    Do I pay the shop to change the fluid and external filter? ($350)
    Thoughts?
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Glad to hear your issues cleared up after service op.
    I would change both filters and use oem fluid Sr.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    have a audi specialized shop do it. Not worth the hassle to save $100 .
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 10 2015
    New England
    Quote Originally Posted by SR7D1 View Post
    Thoughts?
    Is it an indie VW/Audi shop? I would NOT go to a generic mechanic for the DSG.
    The bottom line: You will potentially have a five-figure repair bill if you screw up the service.
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by jygesq View Post
    Well, it's a $225 savings.
    - - - Updated - - -
    That is an German car specialist, they do really good work.
    Aug 22 2014
    bloomfield,ct
    $350 - 255 = $95
    Oct 06 2014
    Cleveland, OH
    $350 - 255 = $95
    $350 is the external filter only. So if I did it myself it's $118. I did not get a quote from the shop for both filters.
    Aug 22 2014
    bloomfield,ct
    I am pretty much sure dealer does not replace any internal filter, they do not drop the pan, I thought I remember from posts on this board it is not necessary. I am not sure whether later DSG version 2 has two filters, maybe only one
    Established Member Two Rings mdeneso's Avatar
    Sep 11 2014
    B8 S4 15 T-Reg 05 ZX10R
    I did a DSG service around 120k miles and I would say it definitely smoothed out the transmission. I wasn't experiencing the symptoms you were, but it did smooth out the shifting a little on my car.
    Oct 06 2014
    Cleveland, OH
    So I just called the dealership and they verified this. They change the fluid and external filter @ 35K and 75K. They also quoted me $800!
    So has there been a change in the DSG/Tiptronic transmissions from the B8 to the B8.5?
    Aug 22 2014
    bloomfield,ct
    yes b8.5 uses version 2 of the DSG . Possibly the newer version has fixed the problems of the older version. There have still been some reports of DSG failures in 2015 S4s. I think 2 cases have been posted about. Not sure if a real fix or just the later cars have fewer miles so no problems reported yet.
    Aug 22 2014
    bloomfield,ct
    Oct 06 2014
    Cleveland, OH
    Where is the external filter located?
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Give it 2000 miles and report back. Changing fluid can slightly prolong the inevitable mech unit failure. Hate to be the negative one lol but your symptoms sure sound like an ailing mech unit. Hopefully it's not though!
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    There was indeed a DSG change for 8.5s as noted - but that's the dealer going rate for fluid change regardless of DSG Version..... Find an independent/performance Audi specialist - It will be cheaper - most are about 1/2 that! But FYI - it does require very specific fluid that is the expense - so it's not going to be much less than $350 (fluid/filter(s) + Labor)
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Dec 12 2005
    Buffalo
    Quote Originally Posted by mrmomo313 View Post
    aww dang :(
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by grovlet View Post
    Thanks, I got the fluid and filter already, but where is the filter located? I can't find anything online or YouTube?
    Mar 01 2006
    Kitchener, ON
    I agree with the service making the DCT feel better.
    Also, when I get an oil change, same thing, it feels like the engine is alive again (ya that can go a different way too).
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Mar 17 2017
    Trumbull, CT
    DSG issue...
    Quote Originally Posted by wack0 View Post
    Some background:
    Hi, just curious, I know this was 4 years ago.... did you DSG issues come back after you posted this in 2016? My S5 had the "gear selector" code pop-up occasionally and I just got the full service done and it feels great for now. Let me know... thanks! Ted
