Results 1 to 16 of 16
    Active Member Two Rings DylanFulton's Avatar
    Jul 31 2015
    Barrie, ON
    Oxygen Sensor Fuse?
    Just replaced my bank 1 sensor 2 O2 sensor. I'm still getting a P0036 heater circuit code/P0141 heater circuit malfunction code. I'm hoping it's just the fuse/relay is blown and not something more in depth. I've done some searching and can't find where it's located. Any idea of the fuse/relay location and number? Thanks in advance
    Cambridge Green Pearl B7 S4 6MT
    Jul 31 2015
    Barrie, ON
    Bump
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    if i recall, the O2 sensors run through the fuel pump or engine electronics relays and share a fuse with the ECU and other stuff. if the relay or fuse were out you'd be getting a lot more codes. i'll double check the wiring diagram later today.
    - emilio
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    What o2 sensor did you buy and use? You replaced the sensor after the cat on bank 1? You're sure? What engine and which side did you change driver's or passenger's side?
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jan 11 2007
    texas
    Should be passenger side after cat
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jul 31 2015
    Barrie, ON
    Quote Originally Posted by audinutt View Post
    That's correct, and I used an OEM sensor.
    Jan 11 2007
    texas
    Oem? Denso? Bosch?
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jul 31 2015
    Barrie, ON
    Oem? Denso? Bosch?
    It was Bosch
    Jul 31 2015
    Barrie, ON
    Quote Originally Posted by emilio View Post
    - emilio
    Would you mind sharing your wiring diagram?
    Apr 18 2012
    Central Texas
    sure - strap in if you've never read a VAG diagram before! note that the header says "A4", but this is the BHF diagram - these are all A4's to Ingolstadt.
    J17 is the Fuel Pump Relay, which should actually be called Half The Engine Relay. that connects the battery to numerous engine electronics via fuse S234; if this fuse were out you would lose a lot more than O2 sensors. that connects via box #62 (those numbered boxes match up to the numbers along the bottom of other pages)...
    ...to box #26 that leads to tons of engine electronics, including boxes #118, 125, 132, and 139...
    ... that supply the other side of the O2 sensor heaters:
    - emilio
    Apr 18 2012
    Central Texas
    Jul 31 2015
    Barrie, ON
    Lol, thanks very much
    Mar 07 2014
    United States
    Going to bump an old thread because I'm getting a similar issue.
    I've been getting a code on startup Heater Circuit Malfunction: Open Circuit.
    I replaced the bank 1 post cat O2 sensor (the one it specified) with an OEM one this afternoon and am still getting the code.
    Any thoughts or ideas as to why replacing the sensor would still net the same code?
    Cheers,
    ~Mic
    Mar 07 2014
    United States
    Might have misspoke, the old code was Warmup Catalyst; Bank 1: Efficiency below threshold now that I think about it.
    So that lead me to bank 1 sensor 2 because that's post cat. Now that it's been replaced I'm getting the heater code.
    Mar 20 2018
    Hanover, Maryland
    Pump
    What was the fix for P0036 heater circuit (below threshold code)?
    Junior Member One Ring
    Apr 28 2022
    Columbia, MD
    Anybody fix this issue?
