Results 1 to 9 of 9
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Newb Question: Shifting out of gear without the clutch..good or bad?
    Hey Guys,
    So this is going to be probably a dumb newb question for some, but my B6 is my FIRST manual transmission car.....and I want to make sure I'm not wearing anything out prematurely / hurting the transmission.
    Question:
    I recently discovered on my own that it is possible to pull my car out of gear without using the clutch (i.e. 3rd to N). This happens when I'm pulling up to a stop light or something, the stick will seamlessly go to neutral, saving my clutch. Is this a smart thing to do or am I eventually going to rip my tranny apart and damage something?
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    I know what you're talking about. I've been doing it for years without any issues. Though you're not saving your clutch by doing it that way. Generally speaking your clutch gets consumed when you're shifting into a new gear, not out of one.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    As long as there is no load applied to the transmission it couldn't care less if you have the clutch released or not.
    Jan 31 2015
    Boise Id
    Quote Originally Posted by claudiovagkraft View Post
    False. The only way a clutch disc gains wear is due to slippage. This should only occur when starting from a stop but can happen due to riding the clutch, overpowered/undersized clutch, poor shifting techniques and other bad driving habits.
    You may be thinking of the syncronizers. Those do only wear during a shift into a gear as they do the task of making shaft speed and gear speed the same.
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Its usually best to put load on the engine and as soon as you let off, throw it into neutral without the clutch. You'll feel almost no resistance in it that way. Have been doing that since ive learned to drive a manual.
    If you really want to get adventurous, you can try shifting without the clutch as well. Same principle, except that you have to match the revs when you're shifting into the next gear. This may wear your tranny a bit if you grind the gears haha.
    19' Glacier S4 Black Optics
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I always do it, not a huge deal. There's no wear going on by doing it that way.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    called floating the gears. Do it all the time in my semi... I wouldn't do it in my car though, just personal preference
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by seal66 View Post
    Semi transmission are a ton different. There's not even synchros in them
    2000 S4- Working?
    Aug 05 2011
    CO
    Quote Originally Posted by redline380 View Post
    I know this, which is why I said I float gears in my rig but not my car.
    Sent from my SM-G920P using Tapatalk
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
