Results 1 to 40 of 57
Thread: HPFP Repair
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    HPFP Repair
    So APR says this is irreparable...
    I can't imagine that is the case...anyone been down the road of having a HPFP repaired? If so who did it? Looking for some options.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    If I remember correctly when I upgraded the internals on my pump I replaced those parts. Look on JHMs site and see.
    https://jhmotorsports.com/shop/catal...h=21_62_65_255
    Mar 24 2013
    Oakdale, CT
    Buying a set of pump internals will fix it. Make sure everything is clean clean clean when you put it together and listen to the torque specs that come with the kit.
    -Adam
    Jun 17 2013
    jersey city nj
    Id go with IE internals.
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I have IE internals in my pump right now. No problems at all.
    With that, I think the JHM cap at the top of the spring is a bit simpler to understand and the design is less likely to pop off.
    The IE cap at the end of the spring (the piece which touches your cam follower) has retaining clips. They have a small possibility of coming off if not perfectly seated.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Oct 14 2011
    I'm leaning towards JHM only because Jake's been an avid supporter of the forum for as long as i can remember.
    I'll do some digging tonight when I have some time to think it through. Want to have it all rebuilt this weekend (do the timing belt + other junk I've got stacked in the garage which is all due...high mileage).
    Thanks for the input...much appreciated.
    Apr 23 2011
    Sac Area, CA
    Here's a little picture I drew for you. lol
    If you press the cap in, compressing the spring but not the piston at the same time, these retaining clips can potentially slide out and get lost which leaves you with a HPFP brick. While this would never happen when the HPFP is installed, it's a risk when we're changing cam followers that requires a bit of care.
    IG @lolzhax
    //AGILITYDRIVES.US
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    I can vouch for IE internals as well.
    On your earlier pics it looked like one of the sensors were gone.. you will need that but I'm sure you already know.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Jun 17 2013
    jersey city nj
    Id IE piston design. Less likely to leak fuel into oil
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    john's hpfp. no issues with mine, over 60k miles almost and about 20k on full e85
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by seal66 View Post
    Stage 1 or stage 2?
    -Adam
    Aug 05 2011
    CO
    Stage 1 or stage 2?
    Stage 2
    Sent from my SM-G920P using Tapatalk
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Oct 14 2011
    Remind me who John is.....I recall you and JR talking about him a while back.....but I seem to recall slow response and other challenges. I suspect his stuff is great but it would take me weeks/months to get parts and I'd like to have this done by Sunday.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by mcpcartier View Post
    John @ HPFPupgrade.com
    I have their stage 1 pump and it has been problem free for over 50k miles.
    -Adam
    Sep 17 2006
    Aurora, Colorado
    I don't understand why APR won't fix it under warranty or replace it?
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    because apr sucks, theyll want you to rape yourself and buy a whole new pump so they can make more money off you
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by i3oricua View Post
    Mite be out of the warranty period
    Feb 15 2016
    Cambridge,Ontario
    What are the costs of these internals ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    $325 on sale right now
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Oct 14 2011
    That rings a bell....thanks
    Oct 14 2011
    Quote Originally Posted by ericw. View Post
    Interesting...will compare designs and see if my laymen mind feels more comfortable with one over another.
    Mar 24 2013
    Oakdale, CT
    This is the exact same style retainer that is holding all of your valvesprings in your head.
    -Adam
    Apr 23 2011
    Sac Area, CA
    but you're not removing valve springs every other oil change i hope.
    maybe it's just something that I noticed since I'm OCD with detail.. but because of the short length of the rubber hose on the HPFP, pulling/reassembling the pump without also accidentally pressing the side of the "hat"(?) on the edge of the cam lobe hole requires a bit of attention.
    That was one benefit I saw to the JHM "hat" was that it's a closed cap and you cannot compress the edge of it without also compressing the piston.
    IG @lolzhax
    //AGILITYDRIVES.US
    Mar 24 2013
    Oakdale, CT
    Banjo bolt here.
    -Adam
    Aug 05 2011
    CO
    Like aluthman said john at HPFPupgrade.com
    He used to be but I have been able to get ahold of him first call or email same day
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Feb 18 2014
    toronto
    I'm running the IE internals also with the JHM big turbo kit no issues so far.
    Main reason I chose it is because of the constant diameter piston.
    2008 B7 2.0T 6MT QUATTRO S-LINE
    Feb 15 2016
    Cambridge,Ontario
    I guess if you are upgrading this is the way to go. I just wanted to repair my car so 230 for a brand new hitachi pump was the way to go vs 325 for parts.
    1976 Yamaha XS 360
    Oct 14 2011
    Not sure....I'd like to get a new tappet (cap) for the end of the piston....I think the rest of the pump is in perfect condition. Their only reply was its "irreparable". I'll reach out to them again and see if they'll elaborate. Maybe the tappet is permanently attached to the piston during the assembly process and theoretically can't be replaced. If I could get that part I'd give it a go.
    Oct 14 2011
    They did elaborate a little....
    "When the button of the pump fails in that manner the internals can not be repaired at that point. This is the same damage that is apparent when cam follower failure occurs and unfortunately is catastrophic to the high pressure fuel pump."
    I suspect this could be the case, but I don't think its always the case. I'm guessing my internals are fine...but maybe an off-center blow to the piston messes up the internals. The tolerances are very tight...
    I really wish they'd disassemble, put in some new seals and cap and test it. I bet it would be fine. But they do not appear to be interested in providing that kind of service.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    I am not familiar with what APR does in their HPFP upgrades so I cannot say for sure if our replacement kit will work. There is a good chance though.
    Oct 14 2011
    Quote Originally Posted by Jake@JHM View Post
    APR has the larger piston so the JHM piston diameter is too small to work with the APR seals.
    Aug 31 2011
    Lathrop
    We actually have a larger piston than APR. It's just our piston shaft reduces to OEM size to fit OEM seals.
    Oct 14 2011
    Good point....The APR piston is the same diameter for the majority of it's length. I think that diameter is larger than the OEM diameter which makes the seals the incorrect size. I'll measure it when I get back to the somewhere with calipers.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    The APR shaft/piston diameter is significantly larger than OEM which is why it is capable of pumping about 30% greater volume of fuel at the regulated pressure at high RPMs. This also explains why the higher volume HPFPs result in greater wear of the follower, and therefore need to be checked more often.
    Dec 04 2011
    Kansas City, KS
    I think the accelerated wear is due more to a higher rate spring isnt it? IE, more pressure on the follower
    Sep 30 2009
    Indiana
    No, the spring back pressure is only a minor component of the contact stress between the follower and cam surface. Remember, the piston is pressurizing the fuel to about 1400 psi. That pressure divided by the piston/shaft cross section is about 130 to 140 pounds of force pushing back against the follower/cam. The spring probably adds only about and extra 20 to 30 pounds. If you increase the piston diameter by 30% to get more fuel volume, the fuel back pressure would increase by the same percent. You are now up to 176 pounds plus the spring pressure. That's a lot of force between the cam and follower and explains why they have a propensity to wear.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    All I know is to be careful when switching it out NOT NOT NOT NOT NOT NOT NOT to break the fuel pressure regulator valve on the top. Wanna guess how much that would cost to replace it.. IF YOU CAN EVEN FIND ONE! Pain in the ass.
    Not that this happened..
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Oct 14 2011
    So I end up helicoiling the housing and it worked great.
    Then Jake at JHM sold me a tappet that I threw on the pump.
    Put it back in (with other new parts that were damaged) and all seems good. Did about 300 miles so far and the only thing I noticed is a boost leak (did timing belt/thermostat while it was apart). But fueling is awesome and averaged about 30 mpg commuting this week, better than before.
    To make life easier to remove the pump in the future I'm going to replace the barbed low pressure fitting on the pump with a nipple (like the high pressure side) then get an elbow (threaded on one end, barb on the other...like the middle one in the pic below) so I don't need to slide that dang hose on and off every time I want to take the pump out.
    Anyone know the thread spec's for the low pressure side? Once I know that I'll know what nipple to get and find the appropriate elbow.
    Apr 23 2011
    Sac Area, CA
    Nice work! glad it's back together and performing.
    I think it's pretty rare that you need to remove that rubber hose. It's flexible enough that you can change cam follower with it still attached. I never removed mine except when I rebuilt the pump.
    IG @lolzhax
    //AGILITYDRIVES.US
    Oct 14 2011
    Wasn't a boost leak...my Revo tune had lost it's settings....acquire came back with 0/0/0....reset to 6/2/9...back to normal.
