Results 1 to 25 of 25
    Jun 03 2016
    Earth
    KN air filter for S6 or not.....
    Hi guys,
    Any advice on swapping out the the stock filter with sock around it for either the K&N or another stock Mahle with the sock removed.
    I searched the forum but there was not a whole lot of feedback.
    Thanks for the comments!
    2016 S6 with VR Tuning box
    Mar 29 2014
    Hampshire, UK
    I put the K&N on my S7 within a week of purchase. Made the car sound better, but didn't feel any faster.
    The problem with modifying the intake is once you start, it can be hard to stop!
    K&N --> AWE S-Flow --> Roc-Euro
    The RocE is AWSOME
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jun 03 2016
    Earth
    Thanks! I think I can be restrained..... Filter is only $55 so I guess I should get it.
    Quote Originally Posted by jkwelsh View Post
    The RocE is AWSOME
    Established Member Two Rings SunDevil's Avatar
    Aug 18 2015
    Scottsdale, Arizona
    Is the K/N filter lightly oiled?
    Current: 2016 A7 Prestige. Ibis White. 20"s
    A8 Black
    996TT Arctic Silver, 6 manual .... my 1st dream car
    997cab Black, 6 manual .....utter disappointment
    997TT Guards Red, body colored grill, 6 manual
    R8 V10 2010 Blue, gated 6 manual
    Mar 14 2016
    Cleveland, OH
    Yes it is
    Jun 03 2016
    Earth
    Just ordered one on Amazon Prime. About 58 bucks with free two day. I'll report back later this week......
    Deactivated Four Rings
    Jun 23 2011
    I have used K&Ns in every car I have owned since 1994 and hove logged 500k miles just in VW and Audi's with them with no MAF issues. Make sure you take the filter out of the plastic and shake it and hit it in a table with a papertowel on it until the oil stops dripping off. And just leave it out in the air for a day or 2 as well. If you can drop the filter on top of a papertowel or newspaper and not have any loose oil come out you should be good.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Good thing is our cars don't have MAF sensor so nothing to worry about!
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Jun 03 2016
    Earth
    Got my filter yesterday. It was not too oily. I did not get any oil when shaking it. Installation was cake. I removed the two hoses hooking up from the engine to the air box. I was able to rotate the lid and remove the stock Mahle filter. The box did have some leaf debris in it. I was able to then install the KN and position the lid back on, locking it in place with the tab thing. I probably spent an extra five minutes studying it and making sure I did it right. I clamped the hoses back on (making sure the arrows were lined up on the hoses and plastic tubes) and voila.
    I was only expecting slightly more turbo noise. However, and maybe because I have a VR box which is likely running 25% more boost, I feel that the car is slightly more responsive and free revving. Makes some sense as the hotter 4.0TT motors utilize twin intakes for more flow. No doubt this KN greatly outflows the Mahle with sock! Hopefully this is not a placebo effect. Sure felt great last night.
    Happy with outcome.
    Aug 18 2015
    Scottsdale, Arizona
    Quote Originally Posted by Sales@EPL View Post
    You read my mind.
    A8 Black
    Jan 26 2018
    2015 Chevrolet Tahoe
    I just picked up a 2015 A6 3.0T and installed a K&N filter. The dealer tech told me that they don't recommend them because it may run a little lean. Has anyone who has a K&N filter experienced this?
    May 06 2014
    El Paso, TX
    Racing filters, especially the oiled type, filter like crap. And that's not speculation, but a fact, and an easy one to confirm by oneself. Anybody with common sense knows if holes are larger for better airflow (heck, you can almost see thru a K&N filter), they're also larger for more dirt to go thru. The issue is modern cars rarely need more air than tha stock air filter supplies, so a filter with a higher CFM rating doesn't mean the engine will get more air. You could remove the freaking filter and the car won't be any faster, to go to the extreme. Bottom line is you're allowing more dirt into your engine, and more intake noise (some like that. I don't) by installing a racing filter, with basically no performance benefit, at least on a stock car. Living in the dusty desert southwest, it'd be a stupid idea to put such a filter on your car, but I wouldn't put one anywhere even if free. But to each his own, I guess. K&N makes great racing filters, but lousy street filters, but it's incredible what a little marketing does in this country.
    2018 S6 mythos black/black; S sport, driver-assist, 20"-black-optic, C/F trim, Audi rings, all-season mats/liner, 35/20 window tint, DWS06 tires, Blendmount/MirrorTap V1, etc.
    Established Member Two Rings Krueger's Avatar
    Mar 24 2009
    Raleigh, NC
    I've upgraded my intake to the complete RS7 setup and I still run the stock air filter (well, the one that comes with the RS7 airbox). Like others have mentioned, oiled filters do not clean the air as well as the factory paper filters. There is no disputing this, just look at the designs. What percent of additional particulate matter makes it through? Well, that I can't say...it would depend on the location and driving conditions.
    I've run cold air intakes & K&N filters on many of my previous vehicles but I'm going to stick with the factory filter on this one. I've done a lot of research on this subject and my conclusion is that these aftermarket filters are a bad idea. Millions of dollars go into the design & testing of these OEM products. Regardless of what these aftermarket filter manufacturers say, their products are not held to the same standards as Original Equipment. If the intake is good enough for a +620 HP RS6 Performance, it is good enough for my stage 2 S6. I'll gladly take a 5-10HP loss in exchange for better filtration. (It is REALLY bad for dirt to get into your engine)
    That is my $0.02. Maybe I'm right, maybe I'm wrong.
    2023 RS6- Daytona Gray Matte
    2015 RS5 Cabrio- Panther Black
    (sold) 2014 RS7- Estoril Blue
    (sold) 2017 S6- Brilliant Black
    (sold) 2015 S3- Glacier White
    (sold) 2005 S4- Dolphin Gray
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by elp_jc View Post
    Beat me to it. If you're doing it for noise, great, but don't think you'll get any other meaningful gains from it. The gains you will get will be more dirt and contaminants in your engine and oil. Not worth it long-term IMO.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Quote Originally Posted by GilliamOS View Post
    Plus 1!
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Quote Originally Posted by Krueger View Post
    If you have the Revo RS7 airbox with their filter it is an oiled filter. I've run oiled and washable filters (Afe pro dry) in my past BMW, Mercedes and S4 without any issues. I agree there probably aren't any HP gains and only a little difference in sound. If you live in a dusty environment they probably aren't the filter for you. Personally I think they filter pretty well whether they are oiled or not. I cleaned my filters at each oil change on all my cars and noticed that they were definitely doing their job. If you are waiting 20-30k to change/clean your filter that might be a little too long. Just my two cents.
    Mar 24 2009
    Raleigh, NC
    Quote Originally Posted by Kczach View Post
    No, I have the RS7 airbox & inlet pipes with the factory filter. It's looks to me like the Revo filter is foam w/ oil. That type does perform marginally better than the cotton-gauze style K&N in filtration. Still, I would rather stick with the factory paper. Not worth it IMHO.
    Jan 26 2018
    Thanks for the feedback. It's greatly appreciated.
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    I installed mine yesterday.. the response is A little better. have not notice much in sound. my fiancé asked if I did something to my car because it sounded different .
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by 4Chio View Post
    Hmm, I guess I'll order it for the car then and see for myself.
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Quote Originally Posted by The Infiltrator View Post
    If you put a couple of additional holes in the air box (where the RS7 has then) and fit the KN air filter, you get a nice turbo whine when getting on the accelerator. Two 1 inch holes in my S6 box sounded just nice and not over the top.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by MadAboutCars View Post
    lol, thanks but drilling holes isn't what I'd do. I'm doing little things until the warranty goes away and then I'm going all out.
    Junior Member Two Rings
    Nov 25 2018
    2016 Audi S6 : DS-1 Stage 3 : EPL TCU : SRM Long Intake : SRM RS7 Turbos : AMS Catted DP
    Anchorage, AK
    This!
    I've owned turbo diesel trucks for decades and did the K&N thing way way back. Truth is that a stock paper filter will let just as much air in when it is clean as any of the oiled filter replacements. The difference is that the paper filter will clog up and restrict airflow faster. Might sound good for the oiled filter, until you realize the only reason the oiled filters flow better over the long term is because it's letting more dirt (particulates) in............... If you really want to increase the air intake of your vehicle, find a real intake solution that uses a real filter, not one that simply lets more air in because it doesn't stop any dirt. ;)
    That being said, I will agree that a WELL maintained and PROPERLY oiled re-usable filter is probably no worse for your turbo's than a cheap paper air filter. Whether they are more inexpensive over the long term is debatable. If you start buying the "special" cleaner and oil, costs quickly add up... and they will never filter as well as a quality paper air filter.
    *note I use the term "paper" but don't really know what they are made of, it looks like a type of paper/cloth etc......
    Lastly, when you over oil your re-usable filter (and you will ;) ) you will find that oil and some of the dirt that gets past your filter stick to the sides of the intake piping, in the turbo intake and intercooler.................
    2016 Audi S6 Prestige DS-1 Stage 3 w/AMS Catted DP, SRM RS7 Turbos, SRM Long Intakes, EPL TCU
    2022 Audi e-tron Prestige Plus (delivery expected the week before x-mas 2021) ;)
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by acruxksa View Post
    This!
    Good info and I know it doesn't do the better at filtering and I guess I'll hold off on the K&N.
    What filter do you use?
    Nov 25 2018
    Anchorage, AK
    My S6 is stock, so Stock air filter.
    I don't own a diesel truck anymore, but when I did, I ran the largest Baldwin cylindrical filter I could find that fit in the K&N filter housing I had installed with my K&N filter shortly after buying the truck.
    I run a wix cylindrical air filter on my jeep, but it's NA so it doesn't need to be very large to give it all the air it can ever use.
    These are completely different engines and vehicles than our Audi's, but when you replace a few turbo's, you get a very good look at the intake system and just how well your air filter works. :D Also, a huge cylindrical air filter doesn't look out of place under the hood of a 3/4 ton diesel truck, but certainly would under the hood of an Audi. It's a trade-off either way. I was religious about cleaning and oiling my K&N filter(s) used them on several trucks without any apparent issues for years. It wasn't until I was several years into my most recent turbo diesel truck that I had to rebuild the turbo (just installed a new CHRA) and then about 18 months later a new/upgraded turbo that I was able to see just how dirty my intake piping was. Despite taking care not to over oil, oil from the filter still coated the intake pipe and to some extent the charge piping. This causes dust/dirt particles to stick to the oil which got me thinking.........that's just the dirt I could see.....
    Here is one of the threads that helped with my decision to replace the K&N. Old, but when combined with my own observations of my turbo intake???
    https://www.thedieselpageforums.com/...ad.php?t=11674
