Originally Posted by
TTRStud
There is another recent thread of an a5 owner who apparently had a terrible experience with the Meyle curved arms. He described an extreme amount of shaking which I am unable to explain. Yes, Meyle creates arms with solid bushings instead of hydraulic, which should translate to MAYBE a little more feel on the steering wheel (if any at all), but definitely not the extreme shaking that he describes. They are affordable enough to where you could possibly return them in case they don't work out for you (maybe you'll want to be the person to either validate or dismiss other claims), but I understand that the labor itself is not as quick as to make most people want to gamble with the choices.
Hi TTRStud, I read that same post and was also confused/surprised: Here is what I think happened. Since this member probably did not do the install himself, he didn't see the actual arms being installed. And as we know (or are learning) these arms are vin/prod. date specific. So, his mechanic probably installed the incorrect arms.
I say this because I have both styles sitting right in front of me: early prod. date and later prod. date. And
in this case the focus is on the Ball Join on the end of the arm. You see, this is also different! The early prod. date arms have a narrow "cone" taper where as the later prod. date arms have a larger diameter "cone" (over 2mm difference in diameter). So, if the mechanic placed a early arm on a later prod. date car , they would bolt on and tighen up...... but there would be so much distance between the cone on the joint and the collar in the spindle/knuckle that .....can you say Vibration!!! You would have over a 1mm gap within the collar on the knuckle and although it looks tight ; it isn't.
The other scenario would be a later prod. date on a early prod. date car. Also focusing on the ball joint shaft on the end of the arm. It would most likely enter the collar on the knuckle just over half way and perhaps expose enough of the threads to start the nut. It may even appear to be seated since the rubber boot will cover much of the shaft. But, in reality very little of the tapered ball joint shaft is seated in the collar (maybe 1/3 at best) . This too would .....vibraaaate.
Note the arm ball joint shaft Diameter also!
