Results 1 to 9 of 9
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Door Jamb Cleaning
    Decided to put together a quick little step by step of my S door jamb cleaning because people seem to wonder how I did it on my Eight. This probably only needs to be done once a year, if that, depends on grease application methods.
    Here is my Eight before and after:
    Order of operation needs to be considered. If washing my engine bay, I wash that first, then the exterior. Same should be done for the door jambs. I didnt here because I wasnt planning to do it, until my schedule opened up while washing the exterior. Do one door area at a time. When doing the fronts, keep the rear door closed and do that jamb at the same time. Once you are done with the front, close the front and open the rear and do it too from that angle.
    So here is what they looked like:
    Dusty more than anything. And a little bit of white grease at the front hinge.
    If you have more grease in the hinges, like my Eight had, use some spray nine, wipe with a paper towel to remove as much as you can. Then spray nine again and use a plastic brush to agitate it then jump to the mitt stage. The goal is to try and avoid getting a pile of grease on your door jamb mitt.
    If its more so dusty, then just hit it with some water:
    Grab your dirty mitt... The grey is for paint, green is for wheels and yellow is for jambs.
    And just get in there:
    Get the underside of the door too:
    Rinse:
    This will happen:
    Wipe up:
    And continue to wipe down the rest of the open areas, this is my door jamb shammy:
    I wont use my door jamb shammy on the hinge areas, so I use an unsuspecting decommissioned dish rag. Alternatively you can use compressed air here. If you dont dry it off, you'll get water spots:
    Et voila:
    Some people like to dress the rubber components, but I'd rather not as it attracts dirt quicker.
    I havent re-applied any grease to either cars yet, and probably wont until they start to creak. And when they do, I'll apply it in a more control manner, rather than the spray and pray approach.
    Enjoy your clean hinges every time you get in!
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Nice work!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Mar 27 2012
    1980 Harley Sportster
    Ocean city, nj
    Great write up, Need to do this. I have a great technique for squeaky hinges an old timer showed me that makes barely any mess compared to spray lube. CHAPSTICK, I keep a tube in my center console just for that reason.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    if you wipe them with every car wash they wont look like shit, ever. not a hard concept to follow
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Jun 05 2013
    Ottawa
    Quote Originally Posted by 19jdog View Post
    Nice work!
    Thanks.
    Quote Originally Posted by surfer1037 View Post
    Thanks, chapstick in a door jamb eh? First I hear of that.
    Quote Originally Posted by GrapeBandit View Post
    I never wipe my hinges down with every wash, not sure how many others do as well. But if you do, then good for you.
    2007 RS4 Avant
    Dec 13 2010
    FL
    Quote Originally Posted by Gosser View Post
    Thanks.
    i wipe all door jambs, open hood and wipe edges and inside the fender where the hood lays, and the same process inside the trunk. guess its a habit i had for the past 18yrs with all my cars lol. i hate dirty door jambs, i use that as a gauge of how well the owner cares for their cars
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    I so need to do this mines are FILTHY!
    This car is what I look like on the inside
    Jan 06 2009
    What he said.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jun 05 2013
    Ottawa
    Its the same way I look at curbed wheels.
    I guess all the grease on my A8 is from drive through oil stations from the PO, as there were a few receipts from them. When working at a dealer, I remember them just blasting every latch all day long. Which would make cleaning them prohibitive when simply drying your jambs, making you goto the extent of degreasing them.
    With all the construction in our new neighborhood, has dust accumulating incredibly quick. And a clean car doesnt last more than 4 hours parked out side let alone just driving down the street.
    2007 RS4 Avant
