Results 1 to 4 of 4
    Apr 27 2016
    Norway
    Door Does Not Open and Stays Locked (Has fault code 02115 - Locking Unit for Central)
    Hello,
    Please help. The front passenger's door does not work (Sometimes it works sometimes not). Has fault code 02115 - Locking Unit for Central Locking. When I unlock all of the doors the front passenger's door stays locked and does not open from outside. I have tried everything but I have not been able to figure out what is causing this. Has anyone had this problem and how did you fix it? Can't find any info on this code. Below is a scan. Thanks in advance.
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 B HW: 8K0 959 792
    Component: TSG BF H10 0170
    Revision: Serial number: 0000007188372
    Coding: 011C12204400410001
    Shop #: WSC 06335 123 12345
    1 Fault Found:
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 38
    Reset counter: 234
    Mileage: 116404 km
    Time Indication: 0
    Date: 2016.03.16
    Time: 06:25:02
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Sounds like a locking drive motor or just faulty wiring.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Common problem : You need to replace the doorlock actuator assembly inside the door. If you buy the same pn from a Porsche dealer, it costs much less than if you buy it from the Audi parts dept. I think it is used in the Cayenne.
    Apr 27 2016
    Norway
    Thank you guys . I will check
