Results 1 to 23 of 23
    Jun 19 2007
    North/Central NJ
    what is an average 1/4 mile time for a tuned s4 on 93 octane
    12.5/12.6? Is that accurate for an auto and 93 octane and stock tires with a fair 60'?
    Thinking of mods but want to be able to return to stock quick if i need to go to dealer
    Mar 21 2015
    An intake is about the easiest mod to change back to stock if need be.
    1 post a month for 9 yrs, crazy!
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Stage 1, DSG, intake.
    Jun 19 2007
    North/Central NJ
    Quote Originally Posted by cjw View Post
    What does that car run on 93 octane w stock tires.
    Jul 21 2004
    South Florida
    I think you are pretty spot on with your expectations. More importantly I'd expect trap speeds to increase from around 104mph to around 110mph in a healthy car.
    Mike
    2018 Audi S5
    Gone-
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    mid 12's would be reasonable from any ECU tune on 93 octane
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    I'm Stage 2 with TCU as well.
    I would say low 12's. That's what I've seen for my car and others with the same at National Trails. Has run 11.9 though. All depends on track prep and how well you hook. I ran 12.2's all day with a full tank of 93 and my tires at the stock 41psi pulling just under 1.9 60ft times. (ran it just like she sits every day). Drop the psi down and hook better and bingo you're pulling 1.7-1.8 60ft times and you're in the 11's.
    I wouldn't worry about reverting back to stock too much. Honestly, if you ever have a "major" issue with a drivetrain component techs will still be able to dig into the ECU and logs seeing you were tuned. Flash counters only tell one part of the story.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by pdqgp View Post
    I think he's specifically asking about stage 1.
    If you want to have the ability to flash back to stock at a moments notice, without having to drive to an APR/GIAC dealer potentially miles and miles away, check out EPL. Or you sound like you may be a perfect candidate for chipwerkes.
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Aug 09 2015
    Sarasota, FL
    Good point about tire pressures. O/P yes this does matter, and yes it is track dependent so there is no correct answer on what is the magic number. I run 39 front/ 38 rear on mine and can land 1.58x 60 foots (you wont hit that with stage 1, but it gives you a picture on how high pressures can lead to good 60ft times with a good track prep).
    Nov 28 2015
    Montreal, QC
    seems like the best of the best 93 octane stg 2 ran 11.7-11,8. Unless, you have R compound, LW+rotor wheel, all mount , everything on check maintenance-wise yada yada, i think any stg2 should run constant off any street red light low 12 and a 0-100 in 4 sec. with LC and all the other mods, you could try to it a bit lower number, but then its not relevant in term of daily driving day to day situation.
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Generally:
    Stock: ~12.9
    Stg1: ~12.5
    Stg2: ~12.0
    Different cars may be all around that range, but it's at least close.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by jackals View Post
    Mine went 12.3 @ 111 with a 1.6 60' on the stock dws's with a cold pressure of 36psi
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Not sure of a better place to ask, but how can I see if my car is tuned (and by who) without emailing every tuner? I've had her for a couple years and never really cared but now I'm out of warranty and want to start playing. It was flashed back to stock before I bought it so I have no idea.
    2012 S4 (sold)
    Mar 21 2015
    Quote Originally Posted by 4RCFED View Post
    I don't think it even matters at this point, just go get a tune and call it a day.
    Aug 27 2014
    Sandy Springs, GA
    Probably true but if it's already tuned isn't it just a flash fee to load it up again vs. paying full price?
    2012 S4 (sold)
    Mar 21 2015
    Maybe, not sure how that would work but you would have to contact the main vendors to find out what tune was on it.
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    I'm APR stage 2 93oct and best I could muster so far is a 12.51 @ 111mph DA of 1834 and 90dg. 60ft was a 1.808. Seems really slow compared to others times with stage 2. Even after letting the car cool for 45min the SC was still too hot touch for more than a moment. Does heat make that much of a difference? For comparison there was an E55 who says he normally traps 122 who was only trapping 117-118mph. Could the car pick up 4mph with just some decent air?
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Quote Originally Posted by KnewJack View Post
    http://www.hardtail.com/techtips/altitude.html will give you an idea of what your car is capable of :)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Not sure the main vendors transfer tunes to other owners... Do they? I know its VIN dependent but Im sure they will argue that the owner forfeited the tune when he sold the car.
    Apr 28 2016
    Quote Originally Posted by GRUMPY-S4 View Post
    Cost me $145 to transfer the APR stage 2 tune that was on my car when I bought it to me. They also upgraded the flash from v1.02 to v3.0. which was worth almost 3mph in the 1/4.
    Apr 04 2012
    MSP
    There is a sticky with all this info - http://www.audizine.com/forum/showth...ag-Strip-Times
    Pay to play.
    Nov 16 2015
    DFW
    Nice!!! I didnt know that!
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I don't know yet but cant wait for it to cool of so I can find out. I am hoping for low 12s but the DAs always seem to suck here.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
