Page 1 of 3 123 LastLast
Results 1 to 40 of 104
    May 06 2004
    W124s
    PA
    Swaybars opinions.... rear only or go with the set?
    Since the eurocode bars are on sale for a few more days, I'm getting ready to pull the trigger on those.... but I'm curious, would I be better off with just the 034 rear bar? I'm basically looking just to improve the handling feel of the car. From previous cars I think this will be better accomplished with a matched set such as the ecode bars.... Most likely leaving the factory springs and struts in place as I am not looking to lower the car at this point, I have the standard suspension.This is my daily driver, no track use in my future either unfortunately
    Keep right pass left, it's the law!!
    Oct 17 2014
    NorCal
    Not an expert but read a few threads on here. Many stated that if you have the CR15 front bar the rear sway is more than enough for non track goers. 034 states their design it to go with a stock front sway, I just installed the 034 Rear Sway and it is awesome. Though that EC price is hard to beat, I would be tempted to buy it and even sell the front.
    2019 RS3
    2014 S4 P+
    Active Member Two Rings Bmil128's Avatar
    Jun 26 2014
    I have the 034 rear bar and love it but it is key no matter which way you go is to also upgrade the end links all around.
    Nov 28 2015
    Montreal, QC
    i got the set and find no downside to it. just positive.
    S4 B8.5 no track, just enjoying spirited driving.
    Oct 17 2014
    NorCal
    Quote Originally Posted by Bmil128 View Post
    Yes, I went with moog end links in rear, will eventually do the fronts. Much cheaper option.
    2019 RS3
    2014 S4 P+
    Apr 04 2012
    MSP
    I ran a rear HR for a couple years. Good improvement.
    Added front HR (on softest setting) and improved turn in and steering response quite a bit. I also added end links all round when I did the front.
    I'd suggest start with rear and then decide if you want to dial it in more.
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Quote Originally Posted by quickglx View Post
    If you like to throw it around or casually track go rear sway only. The car will rotate very nicely - esp with the Sports Diff. My Tuner reco'd this set-up and I am very pleased.
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Junior Member One Ring
    Nov 06 2012
    Saint Paul, MN
    Quote Originally Posted by Evan2 View Post
    This
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Installed 034's rear sway w/ their end links some time ago and really love it.
    I kick the rear end a lot more often on throttle than stock on the intersection in front of my home when merging into a larger street, even with esp on.
    I am not sure if you will be faster on the track but it does add a lot of fun. I feel the rear end a lot more playful than stock.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    May 06 2004
    W124s
    PA
    I'm thinking about going with the EC setup as Evan2 suggested and trying it since it is priced nicely right now.... And sell the front if needed then. Seems the rear bars are similarly sized (26mm EC, 25.4mm for 034) Assuming similar metallurgy and design they may behave approximately the same? Definately an assumption, but guessing I would not be able to distinguish the difference in a blind test
    Mar 05 2014
    2020 SQ5
    PDX
    EC set, with links hands down... get your go-kart on!
    2020 SQ5 Quantum
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I have the EC front and rear, both set to stiff, stock endlinks, stock springs and shocks. Feels perfect, best mod I have done, minimal reduction of ride comfort, corners "on-rails". I also added the CR-15 chassis brace, a subtle improvement, not significant change like the EC anti-roll bars.
    Jan 09 2008
    Winnipeg
    That's part of it (a big part obviously) but it is also the geometry of the bar, where the mount points are in relation to each other, hence the way bars are made adjustable.
    Oct 17 2014
    NorCal
    The 034 Sway Brackets are sexy and very functional with the Zerk fittings though. I believe the EC retain the stock and those horrible Trip square bolts.
    2019 RS3
    2014 S4 P+
    Nov 23 2014
    North Carolina
    I went with the front and rear set, with moog links, and the CR-15. I don't want anything else for suspension, but will probably lower due to wanting the look but that'll be a bit before I decide on what to do. To the guy that said only rear and CR-15.... no. that will be subjective. that person would probably be fine with just a rear bar. The CR-15 stiffens the structure but does not play into the dynamics of the car like the sway bars do. but again, the car's dynamic is also dependent on the person in question.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Mar 21 2015
    I have all 3 bars and upgraded end links and wouldn't want it any other way.
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by MrFunk View Post
    The H&R sway bar description says "come equipped with exclusive Urethane/Teflon composite bushings featuring a molded-in fabric-like material that requires no maintenance or lubrication, and eliminates squeaking." How have you found these bars in regards to those claims? I looks like you get some descent snow and below freezing temps, any negative effects to your sway bar set-up.
    I'm struggling with which bars to get...thinking H&R, Hotchkis or Eurocode. ALthough it sounds like everyone likes the bars they have and the only negative things I have heard is the end-links getting noisy and needing rebuilding but it seems booting the ends helps in that regards. Do you have any experience with those issues?
    Shawn
    Mar 21 2015
    ^ The new 034 rear bar has a zirk fitting for greasing the bushing which is nice. They only sell the rear though. As far as endlinks you could go with the Moog front and rear endlinks for less then $100, they are not adjustable and don't need rebuilding over time. Quite a few guys have complained about the shperical endlinks which is why I steered clear of them. I nave the Eurocode f/r sways and love them. You could also look into purchasing the cr-15 upper bar for a nice cheap mod from member u2nelson, he manufacturers them.
    Apr 04 2012
    MSP
    Quote Originally Posted by eurotic View Post
    Shawn
    I have not had any issues. These have been installed for years now.
    Sent from my SM-G925P using Tapatalk
    Jul 21 2004
    South Florida
    Shawn
    I've had hr bars on probably 5 or so cars and never had to service them and never had a peep. I've run Hotchkis bars and was very happy with them and it was quick using the zerks on them. I prefer stock links to sphericals as well for lack of need for maintenance, quietness, and longevity.
    mike
    2018 Audi S5
    Gone-
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by bhvrdr View Post
    mike
    Thanks for the replies guys. The CR-15 for sure is on my list of things to do for the car. For the price it seems like a no brainer.
    I had the Hotchkis kit installed on my B6 and was quite happy with it and the zerks made it reasonably convenient to re-grease. But I am lazy and I like the idea of "set it and forget it" and it sounds like the H&R bars might be the answer to that. Realistically would someone really feel any difference between the solid H&R bars and the hollow Eurocode or Hotchkis bars? I suspect I wouldn't be able to tell in a blind test, but who knows.
    I keep getting drawn in on the adjustable links, from what I've read I'm only going to be looking at heartache down the road with the inevitable noise and need to rebuild them. Maybe the moog endlinks would be a good option.
    Shawn
    Jan 12 2010
    SE Pennsylvania
    I had the 034 rear sw installed a few weeks ago, with the moog end links.
    In dynamic mode with Pirelli Cinturato summer tires and on a dry road, I accelerated quickly through an intersection.
    The car really surprised me with the amount of oversteer!
    No wheelspin but I had to correct my line (to avoid going into the oncoming lane). The S4 responded brilliantly.
    I later installed the CR-15.
    From my experience, it clearly reduced front end flex.
    For example, less creaking over uneven road surfaces.
    I am very impressed with this strut bar based on the low cost and ease of installation.
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    I just did the rear sway. It did seem to help with understeer, and you can enter and exit a corner a bit quicker. I went with the 034 one, and this is what was recommended.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Jun 17 2010
    Madison WI
    I had the full Eurocode setup on my 2010 and it was AMAZING! The downside is that I live in WI and we get a lot of snow, which after a year or two something in my suspension started to creak like mad all of the time, drove me crazy.
    I now have a 2015. Knowing what I know now, I will buy a set of maintenance free H&R sways when I'm ready, with either stock or MOOG endlinks.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Would a non sports diff rear bar onto a sport diff equipped car give much of a difference?
    My car has the sports diff and doesn't understeer at all even when pushed hard on track, I'd just like to be able to introduce a little more powered oversteer without ruining the balance and I can't help but think Audi must have put such a small bar on sport diff cars for a reason
    Mar 21 2015
    Quote Originally Posted by RyanJon View Post
    It's the same bar from an S4
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    I'm running H&R sways front and rear (soft setting in the front), along with Moog links. Although the Teflon bushings are maintanence free, a went ahead and wrapped the contact points on the bar with Teflon tape too. It's dead silent.
    2014 S4 DSG | Monsoon Grey | B&O | Nav | Sports Diff | Nappa Leather | Carbon Atlas Trim w/ oCarbon Dash | LED Interior w/ Red Ambient Footwells | LED Reverse & Turn Signals | Alu Kreuz | CR-15 Strut Brace | Carbon Mirrors | Llumar 50% Ceramic Tint | Trim Blacked-Out | M'Autolite LED Fogs | Eurocode Drivetrain Insert Kit | Ultra Racing Strut Brace | H&R Sways & MOOG ends | Bilstein PSS10 | SPC adj UCA | HRE FF01 IPA | PSS 275/35/19
    Jun 17 2010
    Madison WI
    Quote Originally Posted by Danny2323 View Post
    Excellent! How do you like the feel of the H&Rs with the Moogs over stock?
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    looks like I am in a large minority here, but I think its good to get a counter point . I have a lot of experience in suspension tuning, do my own alignments, and have set up dozens of cars over the years, I love what a good set of sway bars do on most cars, and have upgraded just about every Audi I have owned with either RS bars or aftermarket ones. I was excited to put the H&R bars on my 2012 S4 with sport dif. installed them took it out for a ride, and immediately did not like what the big bars did to the feel of the car for street driving. Really didn't notice much of a difference on turn in on my sports dif car, and ride quality was diminished noticeably IMO. felt like someone put a straight jacket on my multi link suspension. --which is pretty much what oversize bars do--you lose a decent % of your independent suspension. tried just the rear bar, and didn't like the balance of the car with it and the stock front either. took them off and sold them to a forum member to put on his track car. pretty big disappointment. The big bar added to the back of my B6 A4 just transformed that car.
    Right now I have the car set up with Koni sports, a beefed up lower front brace, upgraded endlinks on stock bars, and the CR15 brace. Car has a great balance between ride quality and cornering for the street--I couldn't be happier with it. Best handling street sedan i have ever driven. I could see for heavy duty track use, a set of bigger sway bars would be invaluable, but IMO, they suck for the street on an upscale car like an S4 unless where you live has nearly perfect roads (like Germany ) or you are not very sensitive to ride quality.
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Sure I read that the rear bar on a sports diff car is the smallest 1 that Audi make and even a non Quattro diesel has a bigger rear bar
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I have the 034 rear bar and it was a great upgrade, I prefer the way the car steers now. But if you like the factory balance of the car maybe stick with a front and rear set.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I bet the non sports diff bar with moog end links would be a nice little upgrade. I believe its a 6mm difference between the two.
    Apr 04 2015
    United States
    Question: What does it take to install the front sway? Anything crazy like having to drop the steering rack?
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    I installed just the rear for about 3-4 weeks (time, rain every weekend etc) when I did my Awe exhaust, the rear bar and accessing the end links is a minor PITA especially due to the bar being larger.
    I installed the front about 3-4 weeks later and it took longer to remove the splash shield than to install the bar. I mean honestly access couldn't be any easier unless you hit a button and it fell from the car. You could do the front in <=30 minutes
    I loved just the rear setup as I have ran similar setups on previous cars, turn in and throttle lift oversteer are something to get use to but I noticed a bit of float in the front during turn in so went ahead and installed the front bar to stiffen the front up some, this was before my AK Brace. Now i have all 3, will get the CR15 bar one day but the car is pretty solid now especially with the forum recommneded Michelin PSS.
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Oct 30 2012
    Oxford, MS
    EC front (soft) and rear (stiff), Moog end links, and CR-15 brace. Love it. Should have come from the factory like this.
    Dec 01 2013
    '93 RX-7
    San Francisco
    Shawn
    I have the h and r on my car, which I bought from onlyaudis for the track, and drove it through a normalish winter in Tahoe many times. So far they seem to be holding up well. I had someone else install them and they did use the tape and I haven't heard any noise at all.
    I certainly agree with him that the car rides rougher with the bars. Especially on the craptastic streets of the bay area, but they work really well on the track.
    I even powered my way out of this mess of snow once
    And probably burned up some clutch in the process, but bars are fine
    2012 S4 MT6 | Prestige | Sports Diff | Phantom Black Pearl | Black Optic Package | Titanium Package | H & R sport Sways | CR-15 | CTS Intake | EPL Stage 1 | 034 Track Spec Upper Control arms | 034 drivetrain/trans inserts | JHM Shifter
    Jan 09 2008
    Winnipeg
    Thanks for all the insight about the bars everyone.
    @onlyaudis, I appreciate the counterpoint and I agree with you that the rear bar on the B6 chassis made a huge difference. I had a B6 S4 with the rear Hotchkis bar (how odd that I can't remember if I had the front bar too) but whatever the set-up it was fantastic compared to stock. I do not find the B8 horrible for being pushy in the corners (comparatively) and I am not sure if giving up some compliance is what I really want to do. Our roads are pretty bad as is the decommissioned runway we autocross on. As much as I would like to stiffen and flatten things out I wonder if I might then suffer from the ill effects of have a less independent suspension.
    I might just have to buy a set and try them out.
    Jul 01 2015
    NS Canada
    I'm getting Front and Back Eurocodes installed without endlinks today. I'll probably add endlinks next year but wanted to try without first.
    Dec 01 2013
    '93 RX-7
    San Francisco
    Quote Originally Posted by moophone View Post
    Cool, please update if you get the end links and do the comparison -- I don't have them and I'm not sure if they're worthwhile. The sways by themselves seem to make such a significant difference, that I'd be surprised if the endlinks are worth it. The adjustable ones are also not cheap compared to the bars themselves.
    Mar 05 2014
    2020 SQ5
    PDX
    It's a noticeable difference. The car is amazing with the full EC setup. I did full-stiff rear, soft-front. I still have stock non-ADS suspension so it retains a good daily driving experience and I don't rub body parts, or exhaust parts on the shitty roads in PDX.
    I also had my installer put the EC dust boots on the endlinks and pack with lithium grease to keep them fresh and noise-free.
    2020 SQ5 Quantum
