Can a rear O2 be pulled out of the exhaust flow too much? About tree weeks ago I installed an 034 HFC with a rear O2 spacer. I bought them used from a member here, and the O2 spacer looks kind of home-made, and slightly longer than the 034 spacer. Anyway, last night my CEL popped on, and these are the codes I got.
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity - Intermittent - MIL ON
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - Intermittent
Can the lack of activity and slow response be from it being pulled too far out of the exhaust stream, or is my sensor just dying. It seems awfully coincidental that it's been fine all this time, then decides to die right after I change the cat and install an O2 spacer.
Also, is a "17963 - Charge Pressure P1555 - 001 - Maximum Limit Exceeded - Intermittent" code normal for a car with a stage 1+ tune? It would make sense to me that it would throw that code, since it's seeing more boost than the car was designed to see.
