Results 1 to 27 of 27
    Senior Member Two Rings A.Bruno6's Avatar
    Jun 02 2015
    Ontario Canada
    Supercharger Pulley Removal Help
    Hey Guys
    So I'm the idiot that decided not to buy a proper tool for removing the pulley. I'm currently in service position, attempting to pull this off. It's not budging. At this point the stock pulley is ruined, but I'm not too concerned about that... I just want to be able to get it off and get the new one on. Can anyone offer advice for getting this pulley off without the specific pulley removal tool?
    Thanks
    Adam
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Could you fit an AutoZone rental 3-claw pulley puller in there?
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jun 02 2015
    Ontario Canada
    I have one on right now, clamped with hose clamp. It's warping the pulley
    EPL Dual Pulley & TCU |3.19 PR| -- MercRacing Charge Air Cooler
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Go get a pulley tool, Audi specific or not. That thing is not going to come off otherwise.
    Edit...I see you have a tool, can you use a plate or washer?
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Jun 02 2015
    Ontario Canada
    Aug 11 2015
    Alberta
    Just keep going. Can you heat the pulley?
    Jun 02 2015
    Ontario Canada
    I could... What should I use to heat it? Don't like the idea of blasting a little propane torch towards the engine tho
    Oct 17 2014
    NorCal
    Well if it catches fire at least you dont need to remove the pulley.
    2019 RS3
    2014 S4 P+
    Jun 02 2015
    Ontario Canada
    Quote Originally Posted by Evan2 View Post
    Ahaha love this! But for real, I'm still fucked.
    Jun 29 2015
    Take pulley to autoparts store and see what type of pulley removers they have. A horseshoe style would work.
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    I used a three prong pulley as well. Yes, I destroyed my pulley too. I ended up taking of the SC out of the engine bay, and used an impact driver on the tool. It eventually came off. Run it till the impact driver no longer moves it any and go get a drink. Leaving it under tension like that will do wonders. I had to go back at it three times. On the third time, it just came off like nothing. Here's my pulley afterwards.
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    Holy shit they really don't want them falling off
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    In situations like this, I would invest in the actual pulley removal tool or have a shop that has one do it. You don't want to damage the shaft or any other part of the supercharger or else you are really screwed. When you get to the point of stage 2 and upgrading that pulley, just do it right the first time and save the headaches.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Jun 02 2015
    Ontario Canada
    Quote Originally Posted by awwturbo View Post
    I'm worried now that the proper tool won't even fit, due to the inward warping of the back pulley wall. Does the apr or awe have any wiggle room on the collars, or is it a very snug fit?
    Aug 11 2015
    Alberta
    Pulley tool will fit on a warped pulley.
    Jul 27 2011
    Northern NJ
    I had my shop do it but they heated it with a torch for a few mins and it seemed to do the trick
    __________________________________________________ ____________________________________________
    2011 S4 Premium+/6spd/Black Phantom w Blk Silk Nappa/Stainless Inlay/B&O/Navi
    APR Stage 2 & Pulley/E-Code Sways Front & Rear w Drop Links & Alu Kruz/H&R OE Sport Springs/5mm Front & 11mm Rear Spacers/JHM Shifter/Milltek Non-resonated/Stratmosphere Intake
    "There's not replacement for displacement but I'd rather be blown"
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    do you have an air cut off wheel. Cut the pulley and if you mark the S/C shaft a little bit it will be fine. Or cut it down close to the shaft and take a chisel and hit it and it will crack the rest of the way. Then it will come right off.
    I guess this post shows get the correct tool or bust lol.
    Jun 02 2015
    Ontario Canada
    Quote Originally Posted by cjw View Post
    Okay good to know. Going to try and get one rushed to me. Any Canadians in southwestern Ontario here? Ahaha
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    I know this doesn't help any, but how did you think you were going to get the stock pulley off?
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 30 2015
    Sacramento, Ca
    A torch on the pulley isn't going to hurt anything and the car isn't going to explode...that's your cheapest/easiest solution at this point to remove it and get the car running.
    Will
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by BlownOne View Post
    Will
    Not sure if a torch would actually help to get it off as you are heating the shaft also and that will also expand leaving you in the same place. Best thing to do is get the correct tool for the job before something else gets f'd.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jul 07 2015
    19RS3
    Ontario, Canada
    Where abouts in SW ontario are you I have a CTS tool in kincardine
    Aug 11 2015
    Alberta
    I would think a torch would help if you just keep it on the perimiter and be careful not to overheat everything.
    Jun 02 2015
    Ontario Canada
    Quote Originally Posted by KnightR View Post
    PM sent, thanks dude!
    Jun 02 2015
    Ontario Canada
    Yeah, it might come down to needing to heat it. But I think I still need a better tool for the job.
    Jun 02 2015
    Ontario Canada
    I've learned a valuable lesson in the last few days. Don't start a job until you have all the proper tools required to complete said job.
    Shout out to Zach at EuroSportTuning in Oakville for rushing me the APR pulley removal kit! And cheers to everyone that messaged me to help. What a great community!
    Currently waiting for the new pulley to finish heating, so still half the job to go! Icing the shaft, heating pulley to 375x1hour and then 400 for about 20 minutes. Also going to get a can of some compressed air to help with cooling the shaft.
    Nov 28 2015
    Montreal, QC
    hey bruno, is that puller kit for sale now ? lol
    S4 B8.5 no track, just enjoying spirited driving.
