Results 1 to 17 of 17
    May 22 2013
    Southern ME
    asfastas63 Build Thread 100k+ and Counting
    2010 Deep Sea Blue Pearl P+ Quattro
    Mod List:
    Wheels, Suspension & Brakes:
    Velocity Motoring V718 19x8.5 ET35
    Michelin Pilot Super Sport Tires
    18" OEM Wheels
    Bridgestone Blizzaks
    Sport Package Suspension
    Gloss Black G2 Caliper Paint (front/rear)
    ECS Dimpled and Slotted Rotors (front/rear)
    Akebono Euro Ceramic Brake Pads (front/rear)
    034 Transmission Mount Bracket
    ESC Differential Front/Rear Mounts
    CR15 Brace
    Engine:
    APR Stage II V2.0
    AFE Pro Dry Air Filter
    ECS Turbo Inlet Hose
    Treadstone TR8C Intercooler
    034 Catch Can
    R8 Coil Packs
    NGK Laser Platinum Spark Plugs @ .028
    034 HFC
    90 Degree O2 Spacer
    Soundbox Delete
    GFB DV+ Diverter valve
    USP Stainless Clutch Line
    S5 Quad Tip Exhaust
    Interior:
    Full LED Interior Bulb Swap
    JHM Solid Short Shifter
    Fly-Designs FBSW
    Tint - 35% Rear
    S4 Auto Dimming Mirror
    WeatherTech Mats
    Always on 12v Mod
    Hardwired Escort Passport Max Radar Detector
    Peerless by Tymphany XT25SC90-04 1" Dash Tweeters
    Peerless by Tymphany NE65W-04 2" Dash Center Speaker
    Pioneer TS-W261D4 10" Subwoofer
    Rockford Fosgate RX250x1 Amplifier
    Various VAG Coding
    Exterior:
    "J-Code" Wrapped Side Markers
    Tail Lights wrapped in Orcal 8300 074 Film
    Door Trim wrapped with Shadowline Trim Tape
    LED License Plate Bulbs
    LED Reverse Bulbs
    LED Fog Bulbs
    RS4 Style Grille
    RS4 Style Fog Grilles
    Towhook Plate
    Honeycomb Quad Rear Valance
    Caractere Replica Trunk Lip
    Bought her with 50k miles back in 2013
    First few mods, RS4 Grill/Fog Grilles, VMR Wheels
    After some misfires at idle, performed a carbon cleaning at ~60k
    Getting Ready For Winter - Plastidipped Winter Wheels and roof racks
    Wrapped Lights in Orcal 8300, Headlight film was shortly removed
    Installing the trans mount
    Shadlowline Trim Wrap
    Switched to a Tow Hook Plate. Drilled out plate to remove without complete disassembly
    Treadstone TR8C Install
    Wrapped side markers
    034 Catch Can with Valve for Easy Draining
    May 22 2013
    Southern ME
    Front/Rear Pads + Rotors + Painted Calipers
    Quad Valance + Exhaust Hanger Install (prepping for S5 OEM Exhaust)
    Subwoofer Upgrade
    Fly-Designs FBSW Install
    Turning 100k
    Adding some sticker bling
    May 22 2013
    Southern ME
    GFBDV+ Install
    No pictures but this went on pretty quickly. I heard some nasty things about trying to get to the top bolt but it wasn't too bad with a short extension. Being a MY2010 I had the latest revision OEM DV and wasn't sure I would notice any improvements so I was pleasantly surprised with the results. It seems to have smoothed out the power band and completely got rid of some mild hesitations I was having modulating around half throttle and above. Power is very smooth and consistent all the way to redline. Overall well worth the price!
    Subwoofer Update
    I'm having two vibration issues, first I need to change my mounting strategy of the sub/mdf ring to use lag bolts and nuts straight through the sub/mdf/rear deck because my screws have already started backing themselves out enough to cause some vibrating. This shouldn't be too bad, just need to get some hardware and drill some holes. I'm getting very good at taking the rear deck apart so shouldn't be too much of a hassle. My second vibration issue is with the speaker grille directly on top of the sub. I had to snip off one mounting location and notch the front because it was too close to the driver which may have something to do with it. Didn't have much time tonight to further diagnose but this may take some more thought.
    May 22 2013
    Southern ME
    Worked on the rattling today, have 99% of it worked out, I need to add something to stiffen the entire rear deck near the back of the speaker grille. Only happens when really cranked up though.
    Also mounted the bass control knob.
    Mounted the paint matched trunk lip from eBay. Damn good quality, not sure how I feel about it yet but if I pull it off I'm only down $149.
    May 22 2013
    Southern ME
    Finally manned up and put the new fuel filter in.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Damn! Nice lip spoiler.
    2016 S3
    Instagram- @Thisisastickup
    May 22 2013
    Southern ME
    APR K04 in hand.
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Quote Originally Posted by asfastas63 View Post
    APR K04 in hand.
    Bam! That is a thing of beauty. Love my Ko4, and I hope you will too!
    Oz
    May 22 2013
    Southern ME
    Dash Speaker Upgrade
    Peerless by Tymphany XT25SC90-04 1" Dual Ring Radiator Tweeter
    Peerless by Tymphany NE65W-04 2" Full Range Woofer
    Instead of trying to make adapters to mount them I just cannibalized the existing speakers and used some 5 minute epoxy to attach the new speakers to the frames. Came out really well and the sound is great. Now I just need to swap out the door woofers for the leftover polk's from my last car.
    May 22 2013
    Southern ME
    USP MT Solid Clutch Line
    Got the clutch line in yesterday and couldn't bleed the damn thing so I'm stranded waiting for a power bleeder to show up on Tuesday. I thought between the old fashion way and my vacuum bleeder I could get it working but no dice so far.
    Edit: Power bleeder arrived and had it bled in 10min. I can't believe how great this thing is. This is something that everyone should own. Went with the Motive Black Label Edition.
    Install and Review: This clutch line is a huge improvement over stock and I would say a must do for every MT owner. The car no longer falls on it's face when launching in first and performs like a normal clutch. I only have a hundred miles on it so far but very pleased with the results for the cost of a line and the power bleeder (which I should have had anyways). The actual install was somewhat of a pain in the ass and even after cutting the old line in half from below where it goes through the firewall, I still had a hell of a time ripping it out. You'll look at where the line plugs in on top and think "no way anyone was able to do this". I used a pair of long needle nosed pliers to pull back the clip and then you can just yank the line from wherever you can get a hand on it. From underneath the car look for the rubber drain grommet and yank it out, you won't see it from above because it's probably covered in dirt and crap, and there's no way you're sending the new line through where the old one went.
    APR K04
    On another note, I started getting the K04 ready to go in. Don't know how much the wrap will help but for the minimal cost, it can't hurt. I have more to do the HFC as well.
    Coming Soon:
    - OEM S5 Exhaust Retrofit (on hand)
    - Replace Door Woofers (on hand)
    - Paint Correction (on hand)
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Hey nice work so far! I grew up in Hollis/Nashua, NH myself. I also have a deep sea blue. How did you get those grilles off in your rear deck to sound deaden them? I just did my whole trunk but didn't want to break those plates by yanking them out.
    18' RS3 Stage II and all the Fixn’s
    21' SQ8
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    May 22 2013
    Southern ME
    Quote Originally Posted by Roadtrippn View Post
    Very carefully. I had them on and off so many times that I ended up breaking both and buying another set from a part out. There is a trick to it using trim tools to pop them out, you need to pop a few across the front, one on each side, and then the rear clips will just pull out. Check out the subwoofer upgrade thread for tips.
    Sep 15 2011
    Hilton Head Island
    Yeah i'll be doing that very soon. Just have to borrow my buddies tools. I already cracked one of them
    21' SQ8
    2001 A4 Stage II
    Aug 04 2010
    Queenz/Westchester
    Subbed, nice work so far! Looking forward to seeing more
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    Fantastic build
    May 22 2013
    Southern ME
    Thanks guys!
    Looks like my clutch master needs replacing.... Add it to the list :(
    Sep 18 2018
    ca
    Great build thread wish you had kept it going
