Results 1 to 20 of 20
    Apr 15 2014
    Ottawa/Gatineau Canada
    Some Key matching questions.
    I have 3 different kinds of Immobo chips...
    Type 1 = the chips in the existing keys for my car
    Type 2 = a blank "virgin" ebay chip
    Type 3 = a chip from a different car, in my B7 key.
    Please bear with me and my questions here...
    Do I HAVE to use a virgin immobo chip, or can the chip in my B7 key be adapted. I am aware that chips can be swapped, if one is careful.
    I do have Vag com and I do have a confirmed working SKC to log in to the locked modules in my car.
    I want to get my new B7 Key matched. I already got the transponder working.
    I came across the following on the Ros-Tech wiki.... is this the correct procedure?
    Key Matching with 4-digit SKC
    Updated 21 Dec. 2010
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
    This procedure details how to match new keys to Immobilizer-equipped VW/Audi vehicles. As of 11 Mar. 2002, VW and Audi are providing 7-digit Secret Key Codes in place of the earlier 4-digit SKC's. Keys must be coded using the new 7-digit SKC (secret key code) method unless the owner still has the correct 4-digit code.
    VW/Audi used to give out the SKC to vehicle owners but as of 2005 they no longer do. Unless you already have that information, then you will not be able to use these instructions - you will likely need to have your dealer perform this procedure.
    Important Note: Unless you ALREADY have the SKC information for your vehicle and components then you will NOT be able to do any of the Immobilizer functions. Click this link for more information.
    Procedure for matching keys to vehicles with Immobilizer in the Instrument Cluster:
    (includes many 1999+ Golf/GTI/Jetta/New Beetle/Passat, also Audi)
    [Select]
    [17 - Instruments]
    [Login - 11]
    Enter zero followed by the 4-digit SKC.
    For example, if your SKC is 1234, enter 01234.
    [Do It!]
    [Adaptation - 10]
    Enter 21 in "Channel Number"
    [Read]
    The "Stored Value" is the number of keys currently matched.
    Enter "new value" of 0
    [Test]
    [Save]
    This clears out the old key-matchings.
    Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys
    [Test]
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Switch ignition off and remove key
    Insert next key to ignition and switch ignition on again
    The warning light for the Immobilizer will light up for ~2 seconds, then go out
    Repeat step 4 with each key until all keys have been matched.
    OR, has there already been a DIY for the B7 FOB that focuses on adapting a new/used chip?
    thanks all
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Three Rings chad99's Avatar
    Apr 21 2012
    Fremont, CA
    I have tried to pair a used key chip with my car but it refused to work, I had to dig out the old chip and install a new one, its not hard to do and finding a virgin chip is easy and cheap, just look for ID48 chips, I think I got 5 of them for cheap off ebay.
    Apr 15 2014
    Quote Originally Posted by chad99 View Post
    Thank you, and as for the process I posted? Is this what you did?
    Apr 17 2016
    kc
    Thqt is the correct procedure when I made new keys for my car. Provided you have the skc and a new immo chips. Used chip will not adapt to another car once its been paired.
    Apr 15 2014
    Quote Originally Posted by hightime80 View Post
    and a chip will not adapt to another car once its been paired.
    Thanks.
    Willy already paired to this car chips still be able to work ?
    Apr 17 2016
    kc
    Yep. I took one of my old chip out an old fob. Hot glued to a new fob and worked like a charm. No need to readapt.
    Apr 15 2014
    Understood, just to be clear so I do not brick any of my keys.
    I have to reset the number of keys pared to the car to 0 during this procedure...
    When I re learn all the keys, the old chips from my car will still be able to be re learnt? and then the virgin key will be hard coded to my car after the procedure?
    Or will I need all virgin chips?
    Thanks all.
    Apr 03 2016
    Up North
    Any chip already paired to the car will adapt again (as will a virgin obviously). You are SOL on the used B7 chip but like chad99 said, they are cheap on Ebay. Search for 'Megamos ID48 RFID'. I got 5 for $10.99 shipped from China last time I bought some.
    Bigger issue is getting your SKC to be able to pair the keys with your cluster. I don't recommend messing with your cluster with VAG Commander or VAG Tacho. Much safer to pull your SKC from your ECU. The cluster is encrypted and easy to brick with clone tools. Here is a link on how to do it: http://www.audiworld.com/forums/a8-s...01-s8-2873134/
    (Its based on an A8 but Argdub's tool will work on the B6 too- any ME7.1.1.or ME7.5 for that matter, maybe other Bosch ECUs on Alfas and Peugeot too)
    I haven't paired keys on my Audi as I got a full set with the car. I have done it on multiple Immo3 VWs. The procedure in the link above works every time.
    Apr 17 2016
    kc
    Vag eprom programmer! Download it. Use an ebay blue cable and it retrieved the skc good as gold. Tbanks to my man k0mpressed for the tip. It is golden.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by Luxus Panzer View Post
    Thanks all.
    you need all existing keys and all new keys and you enter the total number of keys you have and perform the on off process watching the immo light until the end, then I believe it flashes twice and you're done, its been a few months since I've done a b6 but I just did a B5.5 passat a few weeks ago and I believe thats how it went. I don't think I've ever zero'd out the number of keys and entered a new value, I think I just went straight to new value.
    edit: here is they way ross tech says, you have to use the cluster way since the B6s store the key data in the cluster.
    Apr 15 2014
    Right on.
    I put a new virgin chip in that I had (no idea if it is a ID48 RFID)
    I got my SKC by suing my Vag com cable, VCP drivers and Vag K CAN commander.
    Did this a while ago and if I had to do it again, I would use a $20 ebay cable as once the VCP drivers were correctly configured in Vagcom, I could not get my vag com to work again (VCDS) until I removed the VCP drivers.
    I used this how to..
    https://sites.google.com/site/imnuts/
    I put a blank into this key as well tonight. Once I find somewhere in Ottawa/Gatineau to cut the key for me then I will attempt this adaptation.
    Thanks all.
    Feb 27 2011
    Winnipeg
    Right on.
    Thanks all.
    before you try and adapt the process is there to check to see if the key can be adapted, saves tons of trouble shooting time if you run the measuring blocks before hand and make sure your virgin chip is good, had a dud one time that would not adapt.
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    A Everset Locksmith on Bank cut 4 keys for me, I think it was 20 bucks each. Dropped them off and picked them up the next day. He complained that my ebay blanks were super hard to cut... He also had this unit that could read the immo chips and then program virgin chips. Once my ID48s come in, I'll be trying this.
    I already busted one of my S4 immo chips trying to remove it... down to one key now :/
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Apr 15 2014
    Quote Originally Posted by Gosser View Post
    How many ID48's did you order?
    Jun 05 2013
    Ottawa
    Just two, but really only need one. I'll let you know when I get them and we can meet at the Everest and check it. Buy me a small coffee and you can have my spare ID48. :p
    2007 RS4 Avant
    Apr 15 2014
    Word.
    Apr 03 2016
    Up North
    ...He complained that my ebay blanks were super hard to cut...
    Lucky he cut them! My locksmith will refuse and throw them back if they are hard. Like he told me, the cutter he trashes on the Chinese mystery metal comes out of his profit margin. Your guy probably just broke even on the deal lol.
    Apr 15 2014
    Quote Originally Posted by seanf86 View Post
    before you try and adapt the process is there to check to see if the key can be adapted.
    How?
    Feb 27 2011
    Winnipeg
    How?
    http://wiki.ross-tech.com/wiki/index...hing_(Cluster)
    My first link didn't work first few paragraphs, basically put new key in, go into cluster and check the measuring block and it will be a 1 or 0. 1means it can be adapted, 0 is a bad key
    Apr 15 2014
    Roger. Guess I need to get a key cut first, lol
    Let me know when you are going.
