Results 1 to 30 of 30
    Oct 01 2009
    on the track
    considering B8 s4 reliability....?
    I sold my FBO 335i a few months ago and am looking for its replacement and was set on a CLA45 amg but can't find the perfect one. I am now seriously considering to just wait a year or two and pickup a C63 amg or the new E63.
    So i need a car to last me 1-2 years. I am looking at the b8 s4, 2011-2012 models with 40-60k miles. I am not going to modify the car do just simple cosmetics and my main concern is reliability. I don't mind spending a couple hundred here and there but I am not interested in taking my car to the shop every xyz days (which is what I was doing with my 335).
    I know the 3.0 is a good motor and is used across Audi but I was hoping for some feedback from current owners. Anything to look out for any common issues or anything to stay away from?
    I always buy low mileage CPO or new so this a first buying a car like this.
    thanks and appreciate all help
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    I would be careful as some of the early models have transmissions issues. I would say if you're not getting a B8.5 I would avoid it. Besides that they're extremely reliable and well built. Seems like a lot of money to spend for a car you would only have a year or two though. There is probably cheaper temporary solutions you could come up with
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Oct 01 2009
    on the track
    Does the b8.5 have a different transmission than the b8?
    I am all ears for a cheaper alternative that would be just as fun to drive and would look just as nice as the S4. I was considering the W204 C63, E90 M3 and E60 M5 but I think the S4 would be more fuel efficient/more reliable out of any of those.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Its a revised gen II transmission on the b8.5
    The issues on the earlier models normally centered around the mechatronic units, which have come down considerably in price if one were to go out.
    The other reliability concerns, there were a few water pump issues on the earlier models, but they have since been replaced (not all, some) with updated units. Other than that, this car doesn't appear to have as many coil pack/spark plug issues as other Audi vehicles from past experience, doesn't appear to have too many carbon build up issues as other FSI/TFSI engines, and this engine is built pretty robust IMHO for the level of power its capable of making.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Oct 01 2009
    on the track
    That doesn't sound too bad at all.
    I am coming from a N54 motor platform which has had issues with pretty much everything.
    Oct 31 2013
    Morris County, NJ
    I had an 07 335 for 35k. Excellent car and I miss it. On my 2nd b8 s4 (6mt both) they are solid as a rock.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    B8 s4 reliability
    The c63 is a awesome little POWERFUL car! Only thing that turns me off is the interior is a tad weak on the 08-11. I think it got a little update in 2012. But being used to the B8 interior it's miles better all around.
    I actually looked into possibly getting a c63 but being used to the B8 interior I was let down. It's really just a smidge upgraded over a regular c-series. Expensive MSRP car too, more than a S4 you'd think it would have a equal or better interior.
    If not under warranty the DSG problem is a little scary as they aren't cheap to fix at ALL.
    May 20 2015
    PA
    To add to my post do you need AWD? If I weren't in PA I'd probably strongly consider a C63 or even a e93/e90 M3 as a DD.
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    The b8 is a solid platform! Try to look for MY 12 and up, is my recommendation.
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by Frinkferta View Post
    I second this. Also, if you look at a MY13 pay attention to see if the car is wandering around the highway
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by 914dude View Post
    I came from one too. VANOS solenoid, fuel injector (particularly #5 on mine), coil packs, and I forget some sort of cam tray item which required the removal of the engine head. That last item threw me over the edge to unload the car. They perform well when running well, however it was a slightly iffy at times with mine.
    Interestingly, there were two N54's running against each other a few weeks back at my drag strip. Both cars managed a loud back pop running against each (within a second of each other) other and both cars had to roll to the finish line...
    Oct 01 2009
    on the track
    Cam tray sounds like cam bearing ledgings. That was one repair I managed to avoid.
    I am going to check out two 11 S4 today. They have the sports differential and one was a previous CPO and one was a one owner and both cars have full service records.
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    If you're into a 6MT the 2011 is just as solid as the 2012. Having said that my motor has oil burn challenges that led to a piston & ring swap covered under warranty. Plus PCV values, thermostats, axels, etc are all common issues every MY will experience.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    You didn't mention an important piece of information. 6MT or DSG? The 6-speed cars' transmissions are rock-solid, aside from a weak clutch that depending on your driving style (and the PO's) may need to be replaced at some point before 100K. The DSG cars have possible mechatronics issues, as was mentioned earlier. Aside from that, there aren't too many things to watch out for. Early waterpump failures and thermostats sticking closed, but those may have already been replaced on whatever car you pick up. Most owners drive these cars for years and put little into them aside from gas, brakes, and tires.
    Good luck on your search.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    2012 doesn't have the issues the 10s and 11s are known for and you don't have the electronic steering that the 8.5 (13+) got.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Aug 06 2015
    MA
    My 2013 B8.5 has had 6 TSBs applied prior to 50k miles. None of them were powertrain related, which is what it sounds like you are concerned about.
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by cspcrx View Post
    Besides water pumps (which are covered under warranty) what are these issues people talk about with 2011 vs 2012 cars?
    Oct 31 2013
    Morris County, NJ
    Quote Originally Posted by kcobourn View Post
    Trans issues on the s-tronic. As previously stated the 6mt 2011 is going to be fine.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by mmm def View Post
    Same here, but I'm on my 3rd B8 S4 and don't miss the 335i coupe. The S4 is really better in so many ways. Gas mileage and exhaust sound are better on the 335i. Otherwise, S4 come out on top. Would never go back even to a newer 3 series.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by jsh139 View Post
    Agree. Just remember only 20% were built with a 6MT. They are hard but not impossible to find.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Nothing. All B8 s4s have had T Stat issues. Some also with the PCV valve. 2013s went to electronic steering which many feel is not as good as the previous mechanical steering. But really, forget about one year being better than another. The 2013 and newer have a different front grille, flat bottom steering wheel and advanced MMI with google maps. These are nice to have but the driving experience in a 2010 and a 2016 is EXACTLY the same. What you should be looking for is one with the lowest mileage, best condition, and the options, trans and color you want. BTW, you should really be looking for one with the Sport dif. IMHO, it is THE option that makes this car special. Also consider either a CPO car. If not, get an extended warranty when factory warranty is done.
    Oct 01 2009
    on the track
    I checked out the two cars. One had so much damage and was dirty so I ruled it out the other one was in for service at Audi but was clean.
    I have a chance to get a 14 for good price. It was ex CPO car it's 3 hours away before I make the drive I was wondering how I can tell if it has sports differential?
    Is there a vin decoder?
    Mar 21 2015
    Call AOA with the vin and they can tell you. They will also email you the window sticker.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by Dr GP View Post
    Yup. Took me months to find what I was looking for. And even then I had to compromise on color and mileage. Buying used is tough when you have a bunch of criteria.
    Oct 01 2009
    on the track
    Thanks for the reply. I did exactly that and discovered the car was ordered with absolutely no options besides a front license plate bracket :(
    At this point I like the 2011. It's clean and was also ex CPO and has a year left of it. It also has the sports differential and good service records, the fluid for transmission was just changed as well.
    Mar 21 2015
    No problem, might want to look into some other stuff too.
    https://www.audiusa.com/content/dam/...-Year-2011.pdf
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    There is also a rear CV axle TSB on 2011 models, and it never got recalled so many owners are unaware of it. Look underneath and make sure it doesn't look like there's oil seeping out of the joint between the CV axle and sport diff. If it is leaking it's no big deal, it's just the oil component of the CV grease. Though it may ultimately lead to premature CV axle failure, that's not exactly a surprise failure that damages other components. Nor one that'll likely occur before 100k miles.
    Otherwise it's an incredibly reliable platform. Even my auto-up windows still work!
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by ZGskibum View Post
    Yup I had issues with the rear axel a few years ago. Still only stranded twice & consider that reliable on Audi standards ;-)
    Aug 09 2015
    Sarasota, FL
    Yes, that would be correct, the cam ledger. It would come on every so often, however it wasn't on a daily basis (maybe a CEL once a month). Good luck on your search!
    Aug 09 2015
    Sarasota, FL
    lol nice! yeah, thankfully this particular Audi engine series has come a long way from the HPFP, coil pack, spark plug, issue days of Audi's in the low-mid 2000's.
