Results 1 to 23 of 23
    Nov 15 2011
    Montreal | I sell in USD
    DIY : RNS-E Chrome buttons install
    Here's how to install chrome buttons on an RNS-E. I'm using the Euro A4 RNS-E Chrome buttons, if you're using the A3/TT buttons you will need to mod them in order to fit properly since they're not made for our units like the ones I'm using. You will need to merge you oem volume button with the A3/TT chrome button and drill out the A3/TT mode button.
    Here's an image of how the A3/TT buttons look like at night when un-modded :
    *Image borrowed from another forum*
    In my car once installed using Euro A4 RNS-E Chrome buttons:
    Tools needed:
    4 X Radio removal keys
    1 X #0 Phillips Screwdriver
    1 X #4 Phillips Screwdriver
    1 X Jeweler flat head screw driver
    1 X Pair of long noses
    1 - First remove the RNS-E from the car. (If this is complicated for you dont attempt this DIY)
    2 - Remove the 3 top #0 Phillips
    3 - Remove the #4 Phillips, 1 on each side
    4 - Remove the top lid and put it aside.
    5 - Remove the 4 X #4 Phillips on each sides
    6 - Pull the lock ears on both sides towards the outside to unclip them (Dont remove them)
    We can see the face plate connector in this image, note where it is for later.
    7 - Remove the 2 #0 Phillips on the bottom of the unit
    8 - Pull gently on the face plate, it will move upwards as shown below and it will bring the screen up with it
    9- Push the face plate back to its original position by pushing on the exterior, the screen tray will stay in place
    10 - Remove the 3 #0 Phillips that secure the screen to the tray, dont strip them they have blue loctite, hold the screen in place once the screw are removed since the ribbon of the screen is still attached
    11 - Now to remove the ribbon, pull the brown tab towards you with your jeweler screwdriver. Once the ribbon is removed, slide one side of the screen out of its track, then the other and put the screen aside.
    12 - You can now remove the connector of the face plate and place the face plate in front of you on a towel.
    13 - Remove the 7 #0 that hold the board in the red rectangle
    14 - Lift the board gently, the ribbon is on the left. Push the black tabs away to release the ribbon using the jeweler screwdriver. Once removed, put it aside.
    Beware picture taken with potato, it show the black tab in released postion.
    15 - Remove the 6 #0 Phillips of the metal plate, remove it and put it aside
    16 - Remove the L shaped plastic spacer/shim
    17 - Remove the 5 #0 Phillips screw holding the board
    18 - Unclip the tab holding the board's ribbon like we did earlier using the flat head jeweler screwdriver
    17 - Now that you have the board in your hands, remove the power button from the board by pulling on it (Mine is chrome but its a TT button that didnt fit properly and trying to mod it to fit properly gave me nose bleeds)
    18 - Install the A4 RNS-E Chrome button
    19 - Re-install the board and ribbon.
    20 - Now back to the faceplate that you can lift without all the buttons falling because you put back the board right, RIGHT?
    21 - Pull on the mode button, remove the spring from the oem button and install it in the A4 RNS-e chrome button and install chrome button. You might need to make the tabs a bit tigher using the long noses but test the button first.
    22 - Put everything back using these steps in reverse.
    23 - Enjoy
    *****I sell in USD*****
    Nov 15 2011
    Result:
    Installed:
    Comparaison of the A3/TT button, oem RNS-E button and Euro A4 Chrome button side by side:
    Comparaison of the Power/Volume button side by side:
    Now these are the A3/TT chrome buttons, see the difference in the Power/Volume button?
    Euro chrome RNS-E buttons:
    Oct 24 2015
    Perth, WA
    Nice right up mate.
    My respray thread
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    If I bought these, I'd ship you my RNS-E lol
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Nov 15 2011
    Quote Originally Posted by jerseybrian View Post
    You can do it easily Brian but if you're really not confortable opening it up, I can pm you my address
    Not home but I think I only have one pair left.
    Veteran Member Three Rings 3.2's Avatar
    Aug 02 2011
    Fall river MA
    Temped to do this diy but the board and ribbon makes me nervous! stupid question, could you like cut the original buttons off to remove them and then install the chrome ones?
    Nov 15 2011
    Quote Originally Posted by 3.2 View Post
    Nope, you'll have to open it to remove the power button.
    You cant break the ribbon except if you try to. Especially with all the steps to follow posted.
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Picked these up from Axis and installed them, they are everything I ever wanted.
    Install was a breeze, especially with these detailed instructions.
    FyI, these fit the C5 A6 Rns-e too (which I have retrofitted in my b5)
    One thing I can say is - make sure you keep your screws organized.
    I mean sure you could look at the pictures and see which went where but it might just be easier to keep them organized.
    Also, work somewhere where they wont disappear forever if they fall. Ie. carpet.
    Here are some pics
    Also I wasn't convinced the home button was going to work for the amount I use it (no mfsw). SO... I added a bit of rubber cement to the inside and popped it on. Not a whole lot by any means, just a little dab to keep things tight!
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Nov 15 2011
    Ty for the nice review @Iamshayan
    May 16 2015
    Orange County, CA
    Great write up! Very detailed. I just dismantled my RNS-E to send out the faceplate to be retrofitted for my B5. I would be interested in re-assembling with the chrome knobs/buttons if you have a set for sale.
    Nov 15 2011
    Quote Originally Posted by tylaughter View Post
    Check your PM's
    Established Member Two Rings A4InIowa's Avatar
    Jan 28 2013
    Sioux City, Iowa
    You still selling these?
    Nov 15 2011
    Quote Originally Posted by A4InIowa View Post
    Yes I have a couple pairs left
    Established Member Two Rings a4udi55's Avatar
    Nov 16 2011
    Ankara/Turkey
    Hi whats part number Euro RNS-E chrome button ?
    İmkanın sınırını görmek için imkansızı denemek lazım.
    (Fatih Sultan Mehmet)
    Nov 15 2011
    Quote Originally Posted by a4udi55 View Post
    I never found the part number, they always remove the part number prior to shipping.
    I used to order from a European supplier but prices went up 33% so I'm not ordering again. Except if I have a few buyer ready to pre-pay to ammortize the purchase.
    Nov 16 2011
    Ankara/Turkey
    Quote Originally Posted by Axis View Post
    can you supply it again?
    Can you tell me about the current price?
    I want to buy 2 pairs. Best regards.
    My projects page: www.facebook.com/a4udi
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Dang, I wish I had found this thread sooner.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Nov 15 2011
    Quote Originally Posted by egovreau View Post
    This power button will glare all over at night. You'll need to make an hybrid with your original power button.
    Sep 08 2015
    Orting, WA
    That is the A3/TT knobs, yes?
    Veteran Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    RI
    Still have any of these?
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
    Jul 31 2020
    Greece
    Do you still have these for sale?
    Nov 15 2011
    Quote Originally Posted by nikos147 View Post
    Unfortunatly I don’t
    Jul 31 2020
    Greece
    Thanks for the immediate response... Do you have the OEM part numbers?? I searched everywhere without success...
