Results 1 to 20 of 20
    Established Member Two Rings Keaney's Avatar
    Oct 09 2014
    Uk
    A7 Eibach springs - pics please
    My local garage are offering 10% off and free fitting at the moment and I've contemplated the Eibach springs... My car has the sports suspension already so I know it won't drop as much but can anyone with just the springs on a a7 lost some pics up please?
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Can't speak to Eibach springs on an A7 but I had them on my Lexus and they were great. Getting them put on for free is like saving at least $300 bucks so it seems like a no brainer to me.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 01 2014
    Las Vegas, Nv
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Oct 09 2014
    Uk
    So here's mine currently
    Front gap
    Rear gap
    Established Member Two Rings notaclue's Avatar
    Sep 16 2015
    ATL GA
    Here's my A7 with sports suspension and eibach springs...
    Stock ride height w/ 265/35/20 was 28.25" from ground
    After 6 mos with springs and 285/30/20, ride height is 26.5
    Wheel gap is visibly less
    2016 Sepang S6
    Oct 09 2014
    Uk
    Rear gap looks loads less!
    Sep 16 2015
    ATL GA
    Quote Originally Posted by Keaney View Post
    For sure....very happy with overall ride and look
    2016 Sepang S6
    Oct 09 2014
    Uk
    Any issues hitting the ground at all?
    Sep 16 2015
    ATL GA
    Quote Originally Posted by notaclue View Post
    Closer shots of rear and front-
    2016 Sepang S6
    Oct 09 2014
    Uk
    Ah cheers for the extra pics looks loads better than mine, why did you change the tyre dimensions?
    Sep 16 2015
    ATL GA
    Not a problem...went to a 10.5" rim width from the 9" OEM
    2016 Sepang S6
    Oct 09 2014
    Uk
    Ah cool thanks
    Sep 16 2015
    ATL GA
    Good luck and be sure to post the after mod pics :)
    2016 Sepang S6
    Oct 09 2014
    Uk
    Ah cool thanks
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Any bounce with just springs? Concerned it might ruin the shocks??? Only reason I've been contemplating could instead of just springs and also to get s more flush level look (rid of rake) instead of springs just doing what they want.... :) thoughts?
    May 28 2016
    Denmark
    @notaclue The springs you've put on, how much do they drop? 35mm?
    It looks really good. :-)
    Oct 09 2014
    Uk
    Well I've ordered them, at £219 supply and fit it's too good a deal I think. Pictures to follow
    Sep 16 2015
    ATL GA
    Quote Originally Posted by Sd76 View Post
    No issues with any bounce - seems to ride well, but the roads here around ATL are in good shape. Heard it may put more strain on shocks over time ?!? we shall see. only have about 8-9k miles on this setup
    Hoping to install Eurocode sways in a month or so
    Quote Originally Posted by badebolden View Post
    It's probably a 25-30mm wheel gap drop. add'l ride height drop of 10-15mm with change in tire size
    2016 Sepang S6
    Jan 03 2016
    Houston, TX
    I've personally always preferred springs over coilovers. I have the Eibach springs and have no regrets with them at all. Rides pretty much like factory but maybe a hair stiffer. Hardly noticeable. My only wish is that the front was a bit lower to sit even with the rear.
