Results 1 to 10 of 10
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Which 8P 2.0t quattro A3's came with an actual DSG in North America?
    Hi there. Not normally in this section, but curious to know.
    I'm fairly sure the 2011-2013 ones are DSG/S-tronic(same thing), since they have the round style shifter lever, but I'm not sure about the older years. I thought they did, but it looks like the handle from the regular auto in any interior shots I find.
    Thanks in advance!
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by VroomTT View Post
    Thanks in advance!
    All A3's that are Auto are DSG's.
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Nov 21 2013
    SE FL
    Quote Originally Posted by Das Ponto View Post
    Oh okay, that's easy enough! Idk why I thought the fwd ones and older ones were a standard automatic like the a4's. I guess the standard looking shifter is what threw me off. Even the older mk5 GTI's have the round shifter with "DSG" written on them.
    So is it safe to assume it's going to be the same DSG transmission as the GTI for the given year A3? Also, are they all the same DSG, or is there a 1st gen, 2nd gen ,etc. I think the new GTI has a dif DSG, which is the same as in the new MQB A3.
    Thanks for the info!
    Nov 21 2013
    SE FL
    BTW, I read through your thread and love what you did in the interior. Leather and upgraded shifter are choice
    And that VR6 sound awesome! Makes me miss my mk3 vr6
    Senior Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2018 Audi S4, 2012 Audi A3, 2006 Audi A3, 2017 Touareg, 86 VFR 750
    Bergen Co. NJ USA
    I've got a 2006 A3 DSG with old shift lever, and 2012 A3 DSG with the round lever.
    Same transmission.
    There are threads about swapping the old for the new floating around.
    Nov 21 2013
    SE FL
    Quote Originally Posted by Dad A3 View Post
    Same transmission.
    Much appreciated on the confirmation!
    Nov 21 2013
    SE FL
    Same transmission.
    Actually, does your 2006 A3 engage into "S" mode on the transmission by a full move into the next gear on the lever? Compared to the 2012 which I think has an click down engagement of "S" mode?
    I thought that was a distinction between two different transmissions, even if they are both DSG type transmissions. I haven't been able to find the proper transmission code info tho...
    Dec 24 2011
    Bergen Co. NJ USA
    They both function identically depress the button and drop it into "S" mode the only difference is the position of the button on the shift knob.
    Both are DQ 250 transmissions.
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    bumping against adverts.
    Ponto
    Active Member One Ring tfsi92's Avatar
    Oct 01 2016
    Niagara/GTA Ontario
    I'm pretty sure the A3's never came with a push-style Sport selection for their transmissions, always been push the button in and put it in S and it will stay there until pushed back into Drive - A4 for sure uses the slapstyle for Sport mode though
