Results 1 to 12 of 12
    Dec 14 2009
    Houston, TX
    VCDS- I think I messed up
    Ok so I just got an S3 and this is the 4th vehicle I've done mods to, this however has been a definitely different than some of the others, but I think it was when I did the exhaust valve mod that I messed something up. I adjusted the exhaust valve all fine and dandy in acc mode, I always check for faults before I close out, which there was faults and being tired I closed out too quickly. To add on to the cluster fuck I decided to start it since I was hot from sitting in the garage.
    Long story short my car doesn't go into acc mode just straight to starting and after I stop the engine it doesn't go into acc mode. I think I found the issue I don't know if I switched or adjusting the exhaust flaps made it switch my car to a manual transmission, but its reading it as a manual instead of a DSG. Hindsight is always 20/20 and pretty frustrated, any help would be appreciated.
    Feb 13 2016
    are you trying to put it in acc with your foot on the brake?
    2018 S4- KW HAS Suspension, AWE Front mount, AWE Track catback, DTUK Piggy+Pedal Box, ECS Intake
    IG: Urbn.S4
    Dec 14 2009
    Houston, TX
    Quote Originally Posted by vbelisle View Post
    Nope, foot off the brake. Car starts right up and acc mode for when you shut it off is not active either.
    Established Member Two Rings sub-zero's Avatar
    Jan 25 2016
    Cleveland, OH
    that is odd
    Dec 14 2009
    Houston, TX
    I figured out how to hack it, I put the car in drive and turned it off. Still shut off so I closed my eyes and tried to start it and it went into acc mode. Fixed one problem, now on to the others
    Nov 13 2009
    the OC, SOCAL
    you can go to the dealership and have them reset the whole thing back to the original.
    Dec 14 2009
    Houston, TX
    Well before I didn't want to drive it when it thought it was a manual lol, but now it's a possibility I like fixing my fuck ups on my own, but we'll see. Today is my last day off for the month.
    Nov 13 2009
    the OC, SOCAL
    what exactly do you mean by manual?
    there is no clutch and it doesn't have a manual gear stick transmission to shift . I am confused.
    Dec 14 2009
    Houston, TX
    When I was going to engine it would say it was a manual transmission. That was why I couldn't access accessory mode, it would just start like the clutch was always engaged. Blew my mind for awhile.
    Dec 14 2009
    Houston, TX
    Time to probably call Audi
    VCDS Version Release 15.7.4 Running on Windows 7 x86(VMWare)
    Data version: 20160216
    www.Ross-Tech.com
    Tuesday,24,May,2016,13:06:14:05306
    Chassis Type: FF (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
    A9
    VIN: WAUFFGFF3F1117634 Mileage: 20362km-12652miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
    Part No SW: 8V0 906 259 E HW: 06K 907 425 E
    Component: 2.0l R4 TFSI H13 0002
    Revision: --H13---
    Coding: 0A1D00322426000E3004
    Shop #: WSC 06385 790 00016
    ASAM Dataset: EV_ECM20TFS0208V0906259E 001003
    ROD: EV_ECM20TFS0208V0906259E_AU37.rod
    VCID: 428B048ED59B6B2E28-8017
    1 Fault Found:
    17178 - Databus
    U1123 00 [039] - Received Error Message
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 12:56:58
    Readiness: 1010 0101
    Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
    Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
    Component: DQ250-6A MQB H53 4521
    Revision: 05853104 Serial number: TFK01502121140
    Coding: 0014
    Shop #: WSC 04742 780 00200
    ASAM Dataset: EV_TCMDQ250021 001001
    ROD: EV_TCMDQ250021_AU37.rod
    VCID: 1F4DADFA06A966C667-804B
    4 Faults Found:
    21153 - Gear 1
    P072C 00 [002] - Not Selectable
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    21159 - Gear R
    P072B 00 [002] - Not Selectable
    Freeze Frame:
    10731 - Valve 3 in Transmission Part 1
    P174A 00 [002] - Electrical malfunction
    Freeze Frame:
    10906 - Cooling Oil Valve
    P179D 00 [002] - Electrical Malfunction
    Freeze Frame:
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
    Component: ESC H42 0610
    Revision: 00000000 Serial number: 60515000003755
    Coding: 31FF6B9254210A73017D030341C7698CD62A5080C08296B602 4100588208
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 489F16A6F3A7417EF6-801D
    4 Faults Found:
    0297 - Steering Angle Sensor
    B1168 F2 [137] - Not Initialized
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 164
    Date: 2016.05.24
    Time: 09:55:16
    16412 - Display for Tire Pressure Monitoring
    C1146 02 [137] - Signal Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:28
    16413 - Display for Tire Pressure Monitoring
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:28
    32997 - Clutch Position Sensor
    C10BF 15 [009] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 164
    Date: 2016.05.24
    Time: 09:55:16
    Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
    Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
    Component: VWKESSYMQB 021 0604
    Revision: 00021000 Serial number: 0360012678
    Coding: 030C0C
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_KessyHellaMQBAB 002011
    ROD: EV_KessyHellaMQBAB_AU37.rod
    VCID: 3A7B7C6EBD4B23EE70-806F
    No fault code found.
    Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
    Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
    Component: AC Automat H13 0060
    Revision: 20027000 Serial number: 00000000568757
    Coding: 03000014010000000000000000001400
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 3365514A9A21D2A6B3-8067
    Address 09: Cent. Elect. (J519) Labels: None
    Part No HW: 5Q0 937 085 AC
    Component: BCM MQBAB HNA H18 0137
    Serial number: 01011503700603
    Coding: 04151C46C04106FD41C04004511807A0080000000000000000 0000000000
    ASAM Dataset: EV_BCMCONTI Unknown
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 55A1CFD23415EC967D-8001
    Slave 1:
    Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS371 150209 042 0585
    Serial number: 150214130134
    Coding: 0A47F7
    Slave 2:
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 23719321
    Coding: 00006C
    Slave 3:
    Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
    Component: E1 - LDS MQB H05 0032
    Serial number: 13 12 2014 00000685
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000061736876
    Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
    Component: J245 PS73.404 H03 0004
    Serial number: 0000FST0005EEPM00000
    Coding: 101F00
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
    Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
    Component: PARKHILFE 8K H03 0051
    Revision: -------- Serial number: 39391504202534
    Coding: 0030150011
    ASAM Dataset: EV_EPHVA18AU3700000 002024
    ROD: EV_EPHVA18AU3700000_AU37.rod
    1 Fault Found:
    13637426 - Databus
    U1123 00 [009] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:15
    Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
    Component: AirbagVW20 009 0825
    Serial number: 003GCR01F81/
    Coding: 9DCCFCC0000000005000001AC24800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
    ROD: EV_AirbaVW20SMEVW37X_AU37.rod
    VCID: 479D159AFEB94E06FF-8013
    Seat belt tensioner; left:
    Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
    Component: BeltPretRevFL H36 0350
    Serial number: 34178311B20021540297
    Coding: 333135
    Seat belt tensioner; right:
    Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
    Component: BeltPretRevFR H36 0350
    Serial number: 34178312B20021540449
    Coding: 333135
    Seat occupant detection; front passenger side:
    Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H10 0046
    Serial number: 6940000Y150001AS970S
    Coding: 303233
    Crash sensor for side airbag; driver side:
    Subsystem 4 - Part No SW: ----------- HW: 480 001 102 15
    Component: SideSensor_Df 001 0887
    Serial number: 35700000000D7244E21J
    Coding: 2D2D2D
    Crash sensor for side airbag; front passenger side:
    Subsystem 5 - Part No SW: ---------- HW: 480 001 102 15
    Component: SideSensor_Pf 001 0887
    Serial number: 3580000000013C24E21C
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; driver side:
    Subsystem 6 - Part No SW: ----------- HW: 480 400 502 15
    Component: SideSensor_Dr 001 6149
    Serial number: 3510002C3196FF506210
    Coding: 2D2D2D
    Crash sensor for side airbag; rear; passenger side:
    Subsystem 7 - Part No SW: ----------- HW: 480 400 502 15
    Component: SideSensor_Pr 001 6149
    Serial number: 3520002AB196FF5250FK
    Coding: 2D2D2D
    Crash sensor for front airbag; driver side:
    Subsystem 8 - Part No SW: ----------- HW: 480 400 801 15
    Component: FrontSensor_D 001 6149
    Serial number: 3550002B51901DA3420V
    Coding: 2D2D2D
    Crash sensor for front airbag; front passenger side:
    Subsystem 9 - Part No SW: ----------- HW: 480 400 801 15
    Component: FrontSensor_P 001 6149
    Serial number: 3560002B31901DA2738+
    Coding: 2D2D2D
    1 Fault Found:
    1050117 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:17
    Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
    Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
    Component: Lenks. Modul 002 0110
    Revision: -------- Serial number: 19021508490962
    Coding: A018
    ASAM Dataset: EV_SMLSKLOMQB 017001
    ROD: EV_SMLSKLOMQB_AU37.rod
    VCID: 0A1BECAEAD2BF36E20-805F
    Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
    Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
    Component: KOMBI H02 4292
    Coding: 0BED181B2B88D7050201EA001800000000000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 009046
    ROD: EV_DashBoardVDDMQBAB_AU37.rod
    VCID: 4C972AB6E7DFAD5ED2-8019
    Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
    Component: GW MQB High 212 2203
    Revision: -------- Serial number: 13021510802125
    Coding: 0101000830085A005B00022C180B0000000101000000000000 0000000000
    ASAM Dataset: EV_GatewConti 011020
    ROD: EV_GatewConti.rod
    VCID: 72EB944EA5BB9BAE78-8027
    Alternator:
    Multifunction unit control module:
    Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
    Component: E221 - MFL H02 0014
    Serial number: 07 02 2015 F0023173
    Address 22: AWD (J492) Labels: 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
    Component: Haldex4Motion H52 7082
    Serial number: HA1-00014.01.15
    Coding: 0001
    ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
    ROD: EV_AllWheelContrHA1VW37X_AU21.rod
    VCID: 4683189EF9B3570E04-8013
    Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
    Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
    Component: ELV-MQBA H01 0120
    Revision: 00000000 Serial number: 15000037223001
    Coding: 5D00000000000000
    ASAM Dataset: EV_ELVMarquMQB 004111
    ROD: EV_ELVMarquMQB_AU37.rod
    VCID: 346752569F2FD59EAA-8061
    Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
    Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
    Component: SWA Master H05 0071
    Serial number: 0356947489
    Coding: 030211
    ASAM Dataset: EV_LaneChangAssis 001020
    ROD: EV_LaneChangAssis_AU37.rod
    VCID: 387F6666834731FE86-806D
    Lane Change Assistant 2:
    Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
    Component: TSG FS 020 0028
    Serial number: 180115BAH10397
    Coding: 005D1F205C00048000000002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
    Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5061
    Coding: 8102
    ASAM Dataset: EV_SteerAssisMQB 012140
    ROD: EV_SteerAssisMQB.rod
    VCID: 377D655A8E593E868F-8063
    1 Fault Found:
    16135 - Steering Angle Sensor
    B1168 F2 [009] - Not Initialized
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:15
    Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
    Component: TSG BFS 020 0028
    Serial number: 070215BB511062
    Coding: 005D17205E00048000000002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
    VCID: 41890B82D09D703631-8015
    Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
    Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
    Component: AFS-ECU H01 0091
    Revision: -------- Serial number: --------------
    Coding: 012A000123200400
    ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
    ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
    VCID: 3F8D0D7AA66906C647-806B
    Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H07 7530
    Coding: E00100
    Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H07 7530
    Coding: E00100
    Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
    Component: LeiMo links H01 7040
    Coding: E00100
    Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
    Component: LeiMo rechts H01 7000
    Coding: E00100
    Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-HGH1.clb
    Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
    Component: MU-H-LNS-US H43 0394
    Serial number: A302B0FB009764
    Coding: 017301020000000021220002041A00102F000225010001047E
    ASAM Dataset: EV_MUHig6C3HBAS 001040
    ROD: EV_MUHig6C3HBAS_AU37.rod
    Engine Control Module 2:
    Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
    Component: NAR 2015 --- 0035
    Serial number: --------------------
    Seat Adjustment Driver Side:
    Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
    Component: DU High H49 0014
    Serial number: AUZ8Z9EY202LMZ
    Sound System:
    Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
    Component: ControlUnit_H H81 0816
    Serial number: C1000020121400010101
    Door Electronics Rear Left:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote --- 3006
    Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
    Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
    Component: MQB RVC Mid H07 0140
    Coding: 027300010201000300
    ASAM Dataset: EV_2CamSysRearPASE 006016
    ROD: EV_CamSysRearPANAAU914.rod
    VCID: 306F5E466B37E9BECE-8065
    1 Fault Found:
    9529428 - Steering angle sensor
    B1168 F2 [009] - Unknown Error Elaboration
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 20362 km
    Date: 2016.05.24
    Time: 09:55:16
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 8V0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0012
    Serial number: 150131202102
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 7DF1B772ECE5D4D615-8029
    End-------------------------(Elapsed Time: 05:41)--------------------------
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    Uhhhh....yeah. Important safety tip, don't screw with the car.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Dec 14 2009
    Houston, TX
    Oh I will I just will start keeping a log again. See when you get cocky or its late at night, you don't do the things you should do and they turn into bad habits, spare parts, and broken cars lol
